MullinRJ
  • Content Count
    1,498
Everything posted by MullinRJ
  1. Hi Sam, What Pat said. If you still need to call, please feel free at any time. Raymond
  2. Hi @Taproot , You have a good eye, but there is not an easy way in VS to describe how to determine the font assigned to a text block. Rather than try to guide you through it, I made the changes to the previous script and posted it below. As you can see, it still took me about an hour to do this and I still took the easy way out by only checking the first character of a text block to check the font assignment. See next paragraph. I modified the previous script to only change the font type of Arial text blocks. You can specify the font to be changed by changing the constant "kFontNm" at the top of the program. There is one caveat, this script assumes that if a text block starts with a character in the Arial font, the whole text block is Arial. This script does not change individual characters within a text block. That can be done, but requires a bit more time to code. <<< THIS SCRIPT IS LIGHTLY TESTED — VERY LIGHTLY TESTED. USE AT YOUR OWN RISK, AND PLEASE TRY IT ON A TEST FILE FIRST. >>> Also, I corrected a mistake in the previous script that did not pass back the point size in variable "PointSize" from the FormatTextDialog() procedure. That is now corrected in the above script and in the one posted below. If anyone finds any problems with this script, please write back and I'll have @PatStanford get right on it. 😉 PROCEDURE ChangeSomeFonts; { Changes the font of all text on a drawing to the selected font } { Traverses into groups, symbols and viewport annotations } { January 6, 2012 } { © 2012, Coviana, Inc - Pat Stanford pat@coviana.com } { Licensed under the GNU Lesser General Public License } { 17 February 2020 - R. Mullin } { Added ability to set the Point Size of all text objects at the same time. } { Same GNU License as above. } { 7 October 2020 - R. Mullin } { Only change Text Blocks with name specified in constant "kFontNm" to target font name "kNewFontNm". } { Same GNU License as above. } CONST kFontNm = 'Arial'; { change from this font name } VAR Hd :Handle; NewFontNm :String; FontID, dummyInt :Integer; PointSize, dummyReal :Real; Procedure ChangeFont(Hd :Handle); Var FID :Integer; Begin if (GetTypeN(Hd) = 10) then begin FID := GetTextFont(Hd, 0); { assumes all characters in txtBlk are the same fontID } if (FontID = FID) then begin SetTextFont(Hd, 0, len(GetText(Hd)), GetFontID(NewFontNm)); SetTextSize(Hd, 0, len(GetText(Hd)), PointSize); end; { if (FontID = FID) } end; { if GetTypeN() } End; { ChangeFont } BEGIN FontID := GetFontID(kFontNm); { existing FontID } FormatTextDialog(NewFontNm, dummyInt, PointSize, dummyInt, dummyReal, dummyInt, dummyInt, 60); ForEachObject(ChangeFont, INSYMBOL & INOBJECT & INVIEWPORT & ALL); END; Run(ChangeSomeFonts); HTH, Raymond
  3. On further thought, have you looked at the CLIP commands? They might do what you are looking for. ClipPolygon() ClipSurface() ClipSurfaceN() HTH, Raymond
  4. Hi @josue Corona , There is not a single command that will do that. There are commands in the VS language that will return intersection points between objects: LineCircleIntersect() LineEllipseIntersect() LineLineIntersection() EllipseEllipseIntersect() And there are other commands that will determine if the points in question are on Line segments, or Arc segments: PtOnArc() PtOnLine() But to use these the way you are probably hoping for will require a fair amount of coding to take the points they return and manipulate your target object to break at the right spots. If you like Analytic Geometry you can get there from here. If not, you might consider hiring someone who does. Not sure if this helps, Raymond
  5. @WhoCanDo , I don't know what changed with the DMTBN() command. However, there are 32 new VS commands in VW 2021 that interface with Excel files. I have not used them so I cannot comment on them beyond their existence. Perhaps you can loop through your Worksheet's cells and export each cell to an Excel file. It seems more tedious than simply exporting to a text file, but it may give you more control. If you're lucky, @Pat Stanford has dabbled with these and can shed some light. These are the commands listed in the Script reference. Documentation is what you'd expect – thin. Excel_Convert EXL_AddSheet EXL_CloseBook EXL_DeleteSheet EXL_GetCellAlignment EXL_GetCellBordeDiff EXL_GetCellBorderB EXL_GetCellBorderL EXL_GetCellBorderR EXL_GetCellBorderT EXL_GetCellFill EXL_GetCellFont EXL_GetCellStyle EXL_GetCellValue EXL_GetSheetCnt EXL_GetSheetIndex EXL_GetSheetName EXL_GetSheetSize EXL_IsCellValid EXL_NewBook EXL_ReadFile EXL_SaveAndCloseBook EXL_SetCellAlignment EXL_SetCellBorderB EXL_SetCellBorderL EXL_SetCellBorderR EXL_SetCellBorderT EXL_SetCellFont EXL_SetCellNumber EXL_SetCellNumFormula EXL_SetCellStrFormula EXL_SetCellString Good luck, Raymond
  6. Gentlemen, Please check out this page in the VW Help. It's the only place I know that lists the WS Functions. https://app-help.vectorworks.net/2021/eng/index.htm#t=VW2021_Guide%2FWorksheets%2FWorksheet_functions.htm%23XREF_16089_Worksheet_Functions Raymond
  7. Hi @Sebastiaan , I'm seeing that. After too much trial and error, I've come to the same conclusion. Oddly, this works to show all 40 of the LDs'. =DATABASE((NOTINREFDLVP & NOTINDLVP & (PON='Lighting Device') & ('Lighting Device'.'Channel'>'0'))) BUT, this does not work as expected: =DATABASE((NOTINREFDLVP & NOTINDLVP & (PON='Lighting Device') & ('Lighting Device'.'Channel'>'1'))) It only shows LD's with channels 3-9, and 20. What I've noticed is that the DATABASE() engine is comparing strings, and not numerical values (as you'd like). Strings starting with "2xxx" through "9xxx" satisfy the equation, but strings "10" to "19" and "101" to "120" don't satisfy it because the first character in each string is a "1". You really need a VALUE() function, and that only appears to work in a worksheet cell, and not in a Database row. Sorry, I'm stumped. Raymond
  8. @Sebastiaan , Like Pat, I don't have a file to test this, but if a LD does not yet have a channel then this might work. =DATABASE( (NOTINREFDLVP & NOTINDLVP & (PON='Lighting Device') & ('Lighting Device'.'Channel'<>'') & (VALUE('Lighting Device'.'Channel')>=1) & (VALUE('Lighting Device'.'Channel')<=100)) ) This expression checks for an empty channel string before it tests the values in the channel HTH, Raymond
  9. Hi @matteoluigi , You can get the handle to any named object using GetObject() like this: H := GetObject('Wohnungstypen-Auto'); if (H <> nil) & (GetTypeN(H) = 18) then begin { type 18 = Worksheet } { do worksheet stuff here } end; { if } It is always wise to check a handle's validity and type before using it. HTH, Raymond
  10. @matteoluigi , There is a problem with your syntax of the 6 IF statements. Where you have " ))=1) " you should have " ))) =1 " Your last parenthesis should be to the left of the "=". The syntax is essentially " COUNT ( ... ) = aNumber ". Yes you can have statements lilke: if ( ) then begin end else if ( ) begin end else if ( ) begin end else begin end; Notice there is only 1 semicolon at the end, and not after each else if clause. HTH, Raymond
  11. I knew someone (@Pat Stanford) would have an elegant way to get inside. Thanks, Pat. Raymond
  12. Using: Message(GetTypeN(FSActLayer)); If I select a free standing Door I get type 86 (Plug-In object). If I select a a Door in a Wall I get type 68 (Wall object). To see the Door on a test wall I have in an open document, I needed to use: Message(GetTypeN(NextObj(NextObj(NextObj(NextObj(NextObj(NextObj(NextObj(FIn3D(FSActLayer)))))))))); As you can see, the door object is deep inside the Wall object. The number of objects in front of it are not exact, and are determined by the wall's construction. You should use a loop to look for the Door, or possibly try ForEachObjectAtPoint(). There may be a more direct way to get to the Door-in-Wall that someone else can point to. I've just done a cursory quick dive at this. Again, make sure your handle is pointing to a Door object before trying to access its record. HTH, Raymond
  13. Are you sure you have a handle to the Door and not the Wall? Raymond
  14. @Paolo , I did a quick test and it looks like the function HasPlugin() only returns TRUE if you have the plug-in installed in your workspace. Loading a plug-in after you have a resource/object of the same name will cause a conflict, but I don't know how VW responds in that scenario. I can only assume it causes more confusion. Raymond
  15. @Pat Stanford , You must know, as I do, that you have to get up pretty early if you want to beat @Pat Stanford to the post. 😉 LOL, Raymond
  16. Hi @Paolo , No, Plug-in names use the same name space as custom objects that you name manually, or by script. The only name space that I know of that is managed separately are the Layer Names. You can have objects, like Symbols, with the same name as a Layer and VW will not raise a conflict. I know this is confusing, but you are now on the right track. Raymond
  17. @herbieherb , It requires accessing two preference numbers – 45 & 6728 – to determine or set the current NavGraphics State. Use GetPref() and SetPref() to read and set these parameters respectively. If you still need help writing your script, please write back. Raymond
  18. Hi @Paolo. I know from testing on several versions of VW that "Siding" is not a reserved word. Would you please post a problem file so that we may investigate further? It's possible that your Mouldings Plug-ins package is using the name "Siding" and that is preventing you from using it again. Also, have you restarted VW to see if the issue goes away? If it does vanish after a restart, does it reappear a little later? Thank you, Raymond
  19. Hi @Paolo , Your test script needs an EndFolder command to compile correctly and run. Also, Name2Index() will always return "0" for a name that does not exist. PROCEDURE test; VAR h : handle; BEGIN h := GetObject('Siding'); if (h = nil) then message('No object with this name! ''Siding'' exists'); NameObject('Siding'); BeginFolderN(16); EndFolder; END; Run(test); Another problem with your script is if the folder "Siding" exists, VW will not delete it and create it again, a new folder named "Folder" will be created, then after that VW will create "Folder-2", then "Folder-3", etc., each time your test script is rerun. I believe @Pat Stanford 's approach is the right way to go – test for the handle's existence, then test for the handle's type – but you have to do different things based on: 1) if "Siding" does not exist (create your folder) 2) "Siding" exists, and it IS a Folder Type (do nothing; or delete the existing folder and recreate it from scratch) 3) "Siding" exists, but it IS NOT a Folder Type (execute your escape plan) HTH, Raymond
  20. Hello Kars (@Kars Keizer), I'm not to sure this is related, but it is confusing. From the Script Reference Appendix I get: and 6 appears to be "Final Shaded". When I run your script I get "Hidden Line", as read from the VW View>Rendering menu. I tried different constants and 5 gave me "Final Shaded Polygon", again as read from the VW View>Rendering menu. On a whim, try different constants. It may or may not work as it may also be platform dependent. I am on a MAC and you are on a PC. It's worth a try. If you find the numbers are wrong, you may have found a bug in the documentation. Raymond
  21. Hello @WhoCanDo , The constraint settings can be accessed by preference numbers. Here's a routine I wrote a couple of years ago that will do what you're looking for. function GetSnaps :String; { Return a string with the current SNAP settings. } Var S :String; Begin S := ''; if GetPref(37) then S := 'A'; { Snap to Grid } if GetPref(1312) then S := concat(S, 'S'); { Snap to Angle } if GetPref(1314) then S := concat(S, 'D'); { Smart Points } if GetPref(1316) then S := concat(S, 'F'); { Smart Edge } if GetPref(38) then S := concat(S, 'Q'); { Snap to Object } if GetPref(1313) then S := concat(S, 'W'); { Snap to Intersection } if GetPref(1315) then S := concat(S, 'E'); { Snap to Distance } if GetPref(1317) then S := concat(S, 'R'); { Snap to Tangent } GetSnaps := S; End; { GetSnaps } Enjoy, Raymond
  22. Hi Lyle, There is now. This script gives you an option to draw the circles on the Ground Plane, or elevate them to the height of the 3D Locus by changing the value of constant "Circles3D". See comments in script. I also added a dialog to let you specify the circle's diameter before the script runs. Procedure Loci3DToCircle; { Replaces every Loci in a drawing with a Circle } { centered at the insertion point of the loci. Use with care after backing up } { the original drawing. Use at your own risk. Here there } { be dragons. No warranty expressed or implied. ;-) } { Adjust the Const Radius = 1' to a unit an size appropriate to the requirement } { All Circles created will use the default class, color, etc of the document. } { January 28, 2015} { July 15, 2011} { © 2011-2015, Coviana, Inc - Pat Stanford pat@coviana.com} { Licensed under the GNU Lesser General Public License} { 08 Aug 2020 - Raymond J Mullin } { This is a modification of Pat Stanford's script to convert 2D Loci to circles. } { This script will convert 3D Loci to Circles on the Ground Plane if constant Circles3D is FALSE, } { or it will elevate the circles to the Z height of the 3D Loci if constant Circles3D is TRUE. } { This script will also use a dialog for the user to set the Circle's Diameter. } Const Radius = 6"; Circles3D = TRUE; { Circles on Ground Plane if FALSE. Floating circles if TRUE. } Var Diam :Real; Procedure DoAction(H :Handle); Var X, Y, Z : Real; Begin GetLocus3D(H, X, Y, Z); ArcByCenter(X, Y, Diam/2, 0, 360); SetObjectVariableBoolean(LNewObj, 1160, FALSE); { circle on Gnd Plane } if Circles3D then Move3DObj(LNewObj, 0, 0, Z); { elevate circle } DelObject(H); { delete 3D Locus } End; { DoAction } BEGIN Diam := RealDialog('What Diameter?', Num2StrF(Radius*2)); if not DidCancel then ForEachObject(DoAction, T=LOCUS3D); END; Run(Loci3DToCircle); Have fun, Raymond
  23. Perhaps it is because the DrawingLabels update after your script finishes, in which case you have already reset the Automatic Drawing Coordination back before any DrawingLabel code runs. If this is the case, I don't know of a way to get around it in one script. Raymond
  24. Hi Julian, Here's one for lower case. PROCEDURE TEST; CONST CR = chr(13); VAR S :String; function LowerCase(S :String) :String; { Convert string S to lower case. } Var Ch :Char; I, StrLen, ChVal :Integer; T :String; Begin T := ''; StrLen := len(S); for I := 1 to StrLen do begin Ch := copy(S, I, 1); ChVal := ord(Ch); if (ChVal > 64) & (ChVal < 91) then T := concat(T, chr(ChVal+32)) else T := concat(T, Ch); end; { for } LowerCase := T; End; { LowerCase } BEGIN S := '0123456789 !@#$%^&*()_+ ABCDEFGHIJKLMNOPQRSTUVWXYZ abcdefghijklmnopqrstuvwxyz'; message(S, CR, LowerCase(S)); END; Run(TEST); Raymond
