Content Count
1,797 -
Calendar
Everything posted by Andy Broomell
Just started playing around with VW2017 and I LOVE the new auto-hide abilities of palettes. Being able to auto-hide floating palettes is a functionality I've been sorely missing since I switched to a Mac. I also unexpectedly discovered the new "Auto-Hide Docked Palettes" feature, which allows the palettes docked to the left and right to auto-hide off the screen. This is amazing, since it allows you to use the full width of your screen as drawing space, then easily access tools and things when needed just by hovering. However, this feature keeps on turning itself off. One such case is simply running a "Save As" command. Once it saves, the docked palettes are no longer auto-hidden and the setting must be re-enabled. I assume this is a bug.
Improvements to Renderworks Grass Shader
Andy Broomell replied to rDesign's question in Wishlist - Feature and Content Requests
Length variation would be awesome! -
What is the difference between copy-paste and duplicate?
Andy Broomell replied to LSWHEELDON's topic in General Discussion
I think the closest thing would be the Move By Points tool, set up like this: -
Offsetting duplications is GOOD but you have to know how the function thinks. The (ill-documented) trick is that the offset vector of the Duplicate command depends on whatever distance and direction you last duplicated an object via clicking and dragging (that is, Alt-Drag on a Mac or Ctrl+Drag on Windows). For example, to draw a side view of some stairs, draw the rise and run of one step. Then hold Alt [or Ctrl] and drag-duplicate this first step to be the second step. Now the "Duplicate" vector is set, and you can simply hit Cmd+D [or Ctrl+D] to create more steps with the Duplicate command. -
In addition to setting the transparency of an entire class, you can select individual objects and change their opacity in the Attributes Palette (which you mentioned earlier): (The opacity portion is highlighted in yellow.) If you see the little curved arrow, that means the particular attribute is "listening" to the class to which the object is assigned. Clicking where it says "100%" will give you a pop-up where you can lower the opacity or determine whether or not it's listening to the Class's attributes.
Arc Length Dimension Tool
Andy Broomell replied to Kevin McAllister's question in Wishlist - Feature and Content Requests
I have to draw helper arcs all the time too. It would be fantastic if the Arc Dimension tool more consistently recognized arc-like segments as Kevin suggests. It would also be great if the tool worked on Section Viewports. I assume it doesn't currently work because sectioned objects aren't composed of true curves, but rather a bunch of short, straight segments? (which I infer because Section Viewports have a "3D Conversion Resolution"). -
Another instance where I would love this functionality is being able to use the Rotate Tool to rotate and duplicate and object, then use the "repeat last action" command to create addition duplicates of the object at the same rotation. See image below. (I know Duplicate Array can achieve similar results but it's not a visual or interactive tool like the Rotate Tool is.)
Honestly the first time I had to use a computer that was running Fundamentals I was quite surprised that the Navigation Palette was not available. To me, using the Navigation Palette is about as fundamental to Vectorworks as the OIP. I would strongly support the case that the Navigation Palette should be included in all versions of Vectorworks.
One thing you can do ONLY in the Navigation Palette is update a Saved View (by right clicking and choosing Redefine). Without it you have to make a new Saved View with the exact same name to overwrite the old one.
Snap to angle not working anymore :(
Andy Broomell replied to ACrisford's topic in General Discussion
I've found my angle snaps deactivated a few times after Vectorworks crashes. Not sure why that would happen but it has... -
I'm not seeing that on my machine either, but as a workaround you can always use the Eyedropper tool to pick up the attributes from the first rectangle and quickly apply it to the duplicates.
Increase character limit for Dimension "Note"
Andy Broomell replied to Andy Broomell's question in Wishlist - Feature and Content Requests
By the way, I know you can just use a text object instead, but that would mean having to undo the typing you started in the Dimension object (assuming you didn't foresee it that the text is too long), switch to the text tool, retype text, align it in the right spot, then make sure it's the same class, color, font, etc. that the dimensions use. -
Thanks guys!
Is it happening this year? The website just has a place to enter your email to be reminded about the next call for entries, but no actual place to apply. If August 31st is the deadline again, that's in two weeks. http://www.vectorworks.net/scholarship/en/apply
Grouping objects inside Symbols
Andy Broomell posted a question in Wishlist - Feature and Content Requests
I'm not sure if this is a bug or a feature request, but I'm putting it here anyways. Vectorworks doesn't currently allow the following to exist: A Symbol... which contains a Group... which contains both Hybrid and non-Hybrid objects. (Such as a Hybrid Symbol and a rectangle... or a Hybrid Symbol and an Extrude). You can group Hybrid and Non-Hybrid objects together when not inside of a Symbol. But if you try to do it inside of a Symbol then the next time you enter the Symbol the Group container will have vanished and the original objects will be there on their own. Any explanation? -
Today I witnessed a colleague's title block disappear when trying to edit it, as described above. It didn't appear to be a class issue (all were on), and it didn't appear to have anything to do with the Symbol's name or location in the Resource Browser (which would've been my first guess). The weird thing is the entire Sheet Border object disappears, not just the Title Block portion. Not sure what's happening...
You might try Tools < Utilities < Reset All Plug-Ins. I'm not sure whether it'll address any of the issues you're having but it's worth a shot?
Constrain Dimensions Resize
Andy Broomell replied to ericjhberg's question in Wishlist - Feature and Content Requests
A "constrain proportions" checkbox in the OIP would be VERY useful. Holding shift only works if you're changing the object's size with the blue handles rather than typing in a specific dimension in the OIP. There's also the "Scale Objects" command, but there's a few more steps with that, plus you can't choose the anchor point from which it scales. This should definitely exist for Rectangles, Images, and PDFs. Perhaps a few other object types... -
Eyedropper Tool - A Mind of its Own
Andy Broomell replied to VectorGeek's question in Troubleshooting
I have the same issue with the Eyedropper randomly switching modes... -
Wish List: Improve Object Snapping Options
Andy Broomell replied to yasin2ray's question in Wishlist - Feature and Content Requests
If you double click the "Snap to Object" button in the snapping palette, you should get a list of checkboxes where you can choose types of snaps points more specifically. -
Please make the auto hybrid non destructive
Andy Broomell replied to grant_PD's question in Wishlist - Feature and Content Requests
I've been wanting this for symbols for the longest time. Admittedly I haven't taken the time to file a wishlist request because I have many thoughts about it and haven't yet endeavored to type them out. But generally yes - a way to see both 2D and 3D at the same time would make editing hybrid symbols a thousand times easier. +1 for nondestructive AutoHybrids as well. -
Praise jesus. I recently switched to Mac and that is easily the single most frustrating, time-wasting thing I've encountered. I hope it's ready in time for 2017
