3,173 -
Posts posted by Andy Broomell
1 hour ago, Seth Thomas said:
For visibility, I think this depends on your Creation Options settings, but yeah, that makes sense for attributes.
I think you can only choose to make classes Visible/Grey/Invisible across all existing Viewports/Saved Views, which is fine most of the time.
But say for example that you have a class for 3D figures that's on in some of your rendering viewports, but not in your plan or elevation viewports. If I wanted to then create an additional class, say for lights to illuminate those 3D figures, I'd duplicate the figure class so the lights are only visible in the viewports which already contain the figures.
2 hours ago, Seth Thomas said:
When I do, I find the easiest way is to simply create a new class and carefully name it to appear where I want it in the classes list. Duplicating works too, but I find little advantage to that over starting new because I would have to right-click once to duplicate, and once again to go in and rename it. Creating new brings me straight to the naming portion without additional clicks.
I tend to Duplicate only when I want the new class to have matching Visibilities across all of my viewports as an existing class. (Or if I want it to have the same class attributes/textures). Otherwise, creating from scratch is fine.
- 1
I know I've posted in this topic a number of times, but this is honestly the most frustrating bug I've ever encountered. Absolute hindrance to productivity.
This happens an average of 5-10 times a day (granted I do a LOT of rendering in one day). Each time sets me back probably about 5 minutes, once you add the time it takes to realize the bug is occurring, save the file, close Vectorworks, restart, hit render again (which takes longer now because nothing is cached), and get your mind back into point it was before you hit this roadblock. So let's say I lose 30 minutes a day.
There are three people rendering in the studio where I'm currently working. We all experience this issue (on unrelated files, started from different templates, with different workspaces, etc). Between the three of us that's about an hour and a half a day. Or 7.5 hours lost for the week. We're in the 19th week of the year. So far in 2018 we've probably lost 142 hours of billable time. That is many thousands of dollars lost because Vectorworks can't fix this bug.
Sorry to rant, but we're already in SP3 and no signs of change ☹️
(Can I send an invoice to Vectorworks for the lost time?) 😁
- 2
This would be incredibly useful.
Surprised to see the ability used to exist; I've never been able to change the opacity of the viewport in recent memory.
- 1
And make sure to also rotate any of the other three shaders (Reflectivity, Transparency, Bump) that happen to be using an Image.
Just spitballing an idea with no testing whatsoever... What about exporting a DWG, opening this in Illustrator, then either saving an image from Illustrator or just opening the Illustrator file in Photoshop which will rasterize in the process? Not sure if that allows for not anti-aliasing somewhere in the process...
Submitted a bug earlier today, but figured I'd post here to see if anyone else can replicate the same issue.
Add a Foliage object to a design layer. Go to Nav Palette and right click / duplicate. This causes my Vectorworks to crash every single time, even in brand new files.
@Pat Stanford - it seems as though running the command with all of your objects already inside a group causes Vectorworks to stall indefinitely. Is there any way around this, sans ungrouping beforehand?
10 hours ago, Alan Woodwell said:
Hi so added the people models and colour to show variants. Right click on the bottom one and change control geometry this will change the seating perimeter.
Play with the variables to get a low seating audience.
The top ones are just there to test out seating options. You can change the seat symbol type.
Play with the seating grid also.
Maybe just another way to do the seating.
Thanks Alan - I'll have to take a closer look at this, but it looks quite promising for when seating (or whatever) can be defined by a polygonal boundary. This is maybe 20% of the time though, as the seating layouts in many of our files are bespoke to a set or to a platform layout such that they have to be placed manually. In those cases I'll continue to use Pat's script, but it's great to have both of these approaches in my toolset. Thanks!
34 minutes ago, Pat Stanford said:
Try this one. I changed the way to edit the number of groups at the last minute and missed two places where I needed to change a variable name.
That seems to have done it! Fantastic!
Thanks again a billion for working on this, Pat! (btw, I was hoping to attend the user group yesterday, but ended up being stuck in Hollywood too late in the afternoon 😔).
Playing around with the script now... It seems to work excellently with "3" groups. However, when I try it with more than that, let's say "7", I end up with 7 groups, but only 3 of them contain objects. The other 4 apparently exist, since the OIP says '7 Groups' when I Select All, but I can't see or individually select the other 4. And the three groups don't contain equal numbers of objects. (When I run it with "3" the distribution is great.)
As I play around more, there seems to always be 3 actual groups in the end, and one group tends to contain quite a few more objects than the rest.
Coincidentally I tend to just use 3 different figures in my audiences, so this script will be immediately useful. 😃
Let me know if there's further testing I can do. Thanks again!!
The Sweep command only looks in a left-and-right fashion - it considers only the horizontal distance between the locus and the profile shape.
So you'll want to rotate both things 90°, create the sweep, then rotate back 90°.
Can you select them all in the Saved View tab of the Navigation Palette (or Organization Palette), right click, choose Edit, then simply uncheck "Restore Unified View"?
I'm pretty sure this checkbox actually saves whether Unified View was on or off, and its settings(?), despite erroneously sounding like it "restores" Unified View. It should really be labeled "Restore Unified View Status."
So if you uncheck that box for all the Saved Views, you should be able to just turn on Unified View once and it should stay on without being affected by the Saved Views.
10 hours ago, markdd said:
I have no idea whether this approach is useful to you. But, if you add a stripe either as a symbol to each box or as an object within a box symbol and attach a record to it (Stripes 1-14), then tell visualisation to change the fill colour of the item that contains the appropriate stripe record. If the texture is coloured according to the object's attribute then it should work. I've done a couple here and all works fine.
Interesting. But no, that's not quite helpful.
The goal isn't to have multiple viewports with different combinations of colors. Rather, the goal is to have instances of a single symbol definition be able to be multiple different colors. For example, the stripe in "Box 1" could be red, blue, green, yellow, etc. all with the one symbol definition.
So the problem with the data visualization thing is that it still changes all the instances of a particular symbol.
So ultimately I don't think there's any way to achieve this currently, aside from doing it manually.
For any VW engineer who may stumble across this thread, if there were a "BySymbol" option, here's how it'd work in this example:
- Have 14 symbol definitions, one for each box size.
- Have 8 classes, each set up to be a different color.
- For each stripe within each box symbol, set its fill color (or its texture) to "BySymbol".
- Place 2000 symbol instances of the various box sizes in the drawing.
- Assign each instance randomly to one of the 8 color classes. Make sure the symbol instance's Fill or Texture is set to "By Class"
- The stripe inherits the color from the symbol instance's class, despite being inside the symbol.
- You end up with 112 permutations with only 14 different symbols. Fantastic!
Of course this would be useful in a million other ways, but this is just one specific example of how useful it'd be.
- 2
You'd think the basic capability of stretching any object from the center would exist in Vectorworks, but alas it does not.
In the meantime for Text objects specifically, one workaround is to look at the Width in the OIP and type in a larger number. This will make it expand from the center, assuming your text alignment is set to center.
14 hours ago, markdd said:
Why not use layer colours until Vectorworks implement “by classing” in symbols.
There is also data data visualisation in sheet layer viewports.
In this case it's a texture that needs to change; the 2D attributes don't matter. Is this something Layer Colors or Data Visualization can do? (And it's not the entire symbol, just one of the objects within the Symbol.)
For example, imagine it's 2000 boxes in 14 different sizes. Each box has a colored striped painted on it, in one of the 8 colors.
So I just embarked on a project that has 2000 of a particular type of object. This object comes in 14 different sizes; each size is a different Symbol. Each of those sizes comes in any of 8 different colors. In the rendering we want some of every possible option... The permutations of doing this manually is a bit overwhelming.
If I could just have 14 different symbol definitions, and assign the 2000 instances to 8 different classes to control the color, it would save me hours of time.
As it stands I'll technically need 112 different symbols (though I'll probably fake it and leave some combinations out of the rendering).
Having a "BySymbol" option for attributes would be a HUGE step forward.
- 2
I just encountered the other issue again - where the scene renders but doesn't reflect changes. I changed the texture of an object inside of a Symbol (that symbol is inserted into walls, if that matters?) and when I render it's showing the old texture. Restarting fixed the issue.
I haven't seen this^ type of render bug for quite a while, but just to confirm, the bug where changes aren't reflected in renders AND the bug where renders immediately turn black are both present in SP3, the latter occurring extremely often.
- 1
Unfortunately the simple process has been replaced with a more complicated one (albeit with more flexibility/functionality). If you look at markdd's post in the topic I posted above, that's the only way to use Create Report in 2018 and get the same results.
Of course you can then save this worksheet into your template, or into a library file for easy access.
57 minutes ago, crosetti said:
I asked before & received the answer for 2017, but I can't seem to get it right for 2018. Thanks!
Is this what you're looking for?
My guess is the 3D polygon you have selected is the large 'floor' shape, which you should probably just delete. Perhaps it's interfering with your ability to select the other objects?
You might find Edit<Invert Selection to be useful, as it will unselect the current object and select everything that isn't currently selected. Another tip is to use Edit<Select All to see how many discrete objects there are total. And double-tap "Esc" to deselect everything.
A mesh is essentially a container of 3D polygons, but unlike a regular group, it actually joins the polygons into a single object, plus the vertices of the 3D polygons stick together when modified.
Post more screenshots if there are still issues, or feel free to attach the file itself and I can take a closer look.
So it looks like what you have to start with is a Group, as seen at the top of the Object Info Palette. Always look here to see what "type" of object you have.
With this group selected, go to Modify<Ungroup, which will break up the group into its component parts. What are you left with after you ungroup? If there are more groups, keep on ungrouping till you get down to the level you want.
Can you post a screenshot of what it looks like?
My guess is that all of the sandbags came in as a single Mesh object. You'll want to separate it into individual Meshes. First, select the Mesh and go to Modify<Convert<Convert to Group. Then ungroup the resulting group, leaving you with a whole bunch of 3D Polygons. Then select each individual sandbag and go to Modify<Convert<Convert to Mesh. (Note the keyboard shortcut if you have to do this numerous times).
You'll also want to double check that the imported objects are oriented correctly on the X,Y,Z axes (sometimes things come in laying on their side). Also check their scale (fix using Modify<Scale Objects if needed), and that the bottom of each object is on the ground plane rather than floating in the air.
You may also choose to may each object into a Symbol if you'll have multiple instances in your project file.
Let us know if this works or if you have additional questions.
2 Point Perspecitive
Posted
You don't actually need to use the walkthrough tool at all. Within the RW camera tool you just need to make sure that the camera height and look to height are the same. That's currently the only way to get two-point perspective, though it'd be nice to also have the option to tilt the camera up or down slightly and still have the option to keep verticals parallel.
BTW, on the topic of the walkthrough tool - note that you can place a RW camera, then with it activated, use the walkthrough tool to move your view around and have the camera "follow". And conversely, you can use the walkthrough tool to find a view you like, then place a RW camera and click the "Match Current View" button.
(Or if you have a SpaceMouse, that works like the Walkthrough tool regarding above functionality.)
