Joliphant
    8
    Never
Reputation
0 Neutral
Personal Information
  • Occupation
    VP Construction
  • Homepage
    www.hamptonroads.com
  • Location
    Portsmouth, VA,USA
  1. NEVERMIND!! I fixed it simply by restarting my computer. Sometimes we don't see the forest for all the trees!
  2. I was able to get the printer to print by selecting "Rasterize Print Output". The result is totally unacceptable as the image comes out distorted.
  3. OK. I am on XP Pro. The HP 500 driver version is 6.03 which is the latest according to HP. The error message is "0x0b218d14 referenced memory at 0x7ffdefff. The memory could not be read." The Microsoft error mssg indicates "VW.exe Ver 12.0.0.49891 Mod Name comctl32.dll Mod Ver 5.82.2900.2180 Offset 0003c349" Exception info "Code: 0x0000005 Flags: 0x00000000 Record: 0x000000000000 Address: 0x000000005d0cc349.
  4. Every time I try to print from Ver 12 to my HP500 the program crashes. I have had no problems with ver 11.5. ???
  5. Thank you very much, Caleb! quote: Originally posted by Caleb Strockbine: It's probably easier to use 'd', 'm', 's'. If you type '24d15m39s', VectorWorks will know what you mean.
  6. quote: Originally posted by CipesDesign: On a Mac, with most fonts, degrees (?) is SHIFT-OPTION-8. Some fonts are different. Check with your font maker... Thank you for the response. However, I use a pc. I will check with the font to see if I can figure it out. Thanks.
  7. How do I get the degree symbol when typing bearings in degress, minutes, seconds?
