OK, I checked my dimension class and looked at fill set and it was set to solid white with pen being black and was creating the new dimensions as a black block as I stated (previously created dimensions were normal). I tried setting to none and it still brought up dimension into a black box. (Under a file with a new name)If I matched parameters with a previously created dimension that was not a black box, I was able to create several dimensions correctly or without the black block. The class settings were the same whether the black block showed up or not on the new file
