Sbd
    506
Posts posted by Sbd
  1. Perhaps I utilized it the wrong way, but I am trying to compute surface area of a curtainwall for each of the components accurately. I created a wall Area schedule (default template) and did two types of walls - a regular wall, and a curtain wall. A regular wall accurately shows surface area of a material (connected or not...which is great for my purposes). Curtainwalls for some reason are notoriously elusive when it comes to computing surface area, and in this case showing area for glass for instance. I am using the =MATERIALSURFACEAREA('Glass Double Glazing Low-E Argon-filled MT') function, have assigned the material to all the components in the curtainwall, but alas, no cigar. Any help?
    Also, something to note, material surface area computes only on one side of the wall as shown for the masonry! If you have alot of walls, getting the settings right can be tricky! Please note - the material surface area only computes wall surface area on the left pen line, not the right! so if you need to define orientation, that is the way to find out.
    Thanks in advance!
  2. Has anyone successfully extruded along multiple 3d poly lines/ nurbs lines? I am trying to use a single profile (i.e. 2x8) and extrude it along 51 3d polylines that are spaced 16" o.c. in the same direction. Is there a way to do this in bulk rather than one by one?
    Question 2 - Can this be used with the Marionette? and if it is, can someone direct me as to how this can be done?
  3. I was curious, when editing a subtracted and added geometric object where the push pull features are used - I ran into something interesting. When editing a feature, and selecting a face, it leads me to move the feature as previously shown in the preview videos, however, when exiting, it goes into every other feature added after the one that is edited in the geometric model. Is this as designed? or is there a way to skip editing all other features (the ones created after the current edited one) after exiting the edit feature mode? If there are tens or dozens of additions added to the geometry, clicking that exit feature button however many times would be quite tedious, no?
    but otherwise, the feature is pretty awesome!
  4. Does anyone know how to synchronize incrementing values of tags if they are used separately between different design layer viewports and / or different worksheet annotation viewports? Whenever an incrementing tags is placed in only one location, you cannot tag it again in another viewport without changing its incrementing value. Is there a way the numbers can be synchronized thoughout the entire document?
  5. @zoomer
    This is why I prefer Windows. Apple's closed ecosystem gives developers a hard time developing cross platform applications and instead specifically cater to them because of the user base they have. That's why you guys have such a hard time with every OS release.
    Hopefully once Wine / PlayonLinux gets more developed and mainstream with Linux, perhaps VW can be even ported there by using compatible opensourced windows OEM windows direct link libraries and .Net libraries to run it. A guy can dream right? 😉
  6. @zoomer
    Working with 400 mb files remotely will be a challenge IMHO for especially large projects. Also, if you have a lot of custom record information for Building code requirements, zoning requirements, specifications, details, and FFE / Fixture callouts, using the Object info pallet will be difficult / tedious at best, especially if the project references other VW files. Even with a 15" laptop, my productivity was cut substantially because I didn't have a second monitor. It is nice if youre checking something in a cafe somewhere in Tahiti, but I doubt its a good replacement for a workhorse, even if it is possible to do over webgl, maybe I'm wrong?
  7. @Boh
    If it makes it any consolation, I'm Russian. I too have a Russian accent. Don't think we said anything insulting, on the contrary. It's good to be not so serious sometimes. Yes, she has a Russian accent. But I'm sure she's brilliant nonetheless.
    PS. For the record, This is the teaser video I've watched the most thus far. These particular features seem like one of the primary reasons to upgrade.
    • Like 3
  8. I sooooo hope they get area calculations for the surfaces right ! This would be sooooo great! (Que Tony the Tiger) That and....
    1. Will the display criteria be controlled only by the view port like before? or can it be done live like its shown on the video?
    2. Structure grid and detail viewport symbols look very useful. Do they also work like section tools?
    And lastly
    3. The Material resource, will it take over the class control of materials in door and window plugin objects????
    Also...+1 for Russian Accents 😉 Love it! lol
    Edit:
    For those who didn't notice :
    • Like 1
  9. @jeff prince , I agree, the site model needs a little work. I have learned by using the site model tool ends up being problematic when using hardscapes and actual cutouts and site modifiers that I've resorted to using Nurbs surfaces, and mapping 2 dimensional geometry on the produced 3 dimensional surface. Sure, it's not parametric, but its a solution that isn't impossible to solve. I've also had many a problems before, some severe, some, not so much. (I.e. the way vectorworks calculates surface areas for walls, windows etc..., energos, the way VW tabulates records and it's inability to divide 0 into 0 without getting an error, among many others) Tech support wasn't able to help me much either. It's ok. I still found a solution.
    Regarding the contour problem, let me check it out, maybe i can creatively come up with something.
    Regarding export to C4d and exporting alpha channels shouldn't be such a big deal. I know in 3d max and / or in sketchup / vray - you can use a single image as an alpha and as an overlay if I'm not mistaken. VW isn't meant for that type of work. Now that Lumion, Twinmotion and Unreal Engine are on the market, real time renderers and it's entourage / foliage models should be able to replace such models. All I'm saying is that, yes, work-arounds are annoying, but it is not impossible to implement. My personal preference, I just import low poly sketchup foliage, and use that instead. Much easier to transfer to other 3d programs. If polys are too high, use a poly reducer to get the results you need.
    I'm just happy I can produce a decent BIM model in VW, create a set of documents, label everything, use records for everything, and still be done on time. I can't say the same for any other program. Opting out of the service select might be a financial savings for one year, but you will end up paying for it when VW solves the problems you're talking about, or creates new tools that circumvents some of those problems. The tag tool for me was one such example 2 releases ago, I don't know how i worked without it before that point. In either case, what you pay in service select for upgrading VW upon release for 2 years is probably less than what you would pay to upgrade after missing the 2 years (depending on when you have service select). Financially, it works out for the better I think.
    Additionally, I don't think they (service select customer service) will solve alot of problems you have. They're not intended for that purpose i believe, but they certainly are useful to get some ideas on how to solve something. They're also not the size of autodesk. You're still getting updates (more than autodesk produces), and its 2 times if not 3 times less expensive for a single seat. You're getting almost everything you want out of the software. If you want to stay in the same family, maybe Archicad is better for your needs? Have you tried it?
    • Like 2
  10. Perhaps the new material tool will be able to fix that since it is more of a material problem rather than a wall problem. Second, had they addressed that problem separately, I am sure there would be other gripes. All I am saying is that every release won't get you everything you wanted, but I know I've gotten at least one or two very useful tools or functionalities with every release.
  11. 21 minutes ago, Mark Aceto said:
    VW users: we want a maintenance update focused on performance and stability--no new features!
    VW: for the first time in 20 years, every user finally has true multicore performance the entire time the app is being used
    VW users: we're not upgrading because there are no new tools!
    VW: there are ton of new things we haven't announced yet in these 4 Trigger Tuesdays
    This is why we need better communication vis a vis a Public Roadmap. Also, just end Teaser Tuesdays. They used to be 8 min DIY BTS deep dives followed by Q&A's. Now they're just the same 3 min promo videos that drop on release day when we can dive into the new release ourselves to explore (which is extremely fun to do under those circumstances vs rage-posting in the the forum for a month straight).
    LOL. But does it blend????
    • Laugh 1
  12. I've been hoping to get this into the works for a while. Great for details and great for axonometric representations that are to scale. Scale is very important in architectural presentations and construction documents, and currently no isometric view can scale the presentation properly. Does anyone feel the same way?
    • Like 1
