Sbd
    503
Posts posted by Sbd
  1. They mentioned on the mac it had disappeared. I'm guessing this is an OpenGl bug - where opengl is still predominant on the windows platform (i presume). It's better than in 2021, so at least that is a good thing. Additionally, 2022 is much speedier in terms of rendering linework than 2021 which is a huge advantage. So i give them the benefit of the doubt, just wanted to give the tech's at the forum the heads up!
    • Like 1
    The last two columns are calculating incorrectly
    Column Z = P / O
    Column AA = T / S
    Table cell calculations for
    P = =IF((('!CDA-EnergyTabular'.'Solid/Glass')='solid'), '!CDA-EnergyTabular'.'U_prop'*AREA, '')
    O = =IF((('!CDA-EnergyTabular'.'Solid/Glass')='solid'), '!CDA-EnergyTabular'.'U_req'*AREA, '')
    T = ='!CDA-EnergyTabular'.'U_prop'*AREA
    S = ='!CDA-EnergyTabular'.'U_req'*AREA
    Is there something going on here that I'm not aware of?
  3. I don't use them that often either, but after making the geometry, i generally get rid of the marrionette from the viewport, and save it as a group symbol in the resource browser should i need it again. If i need to change the barrel roof once more, i would again drag the marionnette into the viewport, verify the barrel roof name and referenced wall type and redo the geometry. I believe there is an option in there that can retain the nurbs surface while regenerating the barrel vault roof.
    When i do anything that is out of the ordinary, i also have massing models on another layer in case i need to take the surface geometry from it once more. I also keep design variations on other layers as well, for various options.
    In terms of nurbs surfaces there are several ways you can go about it. Either you create a complex shape from two nurbs curbs via the loft surface tool, or (this is generally easier for me to do) create a series of operations on various extrusions. I.E. The original barrel vault roof could be an extrusion, then a series of cuts via the split tool, and lastly, when i get the blocked version result of what i am looking for, I extract the top most surface that I would like to use for the barrel vault. Depending on the settings you use, you can turn the shape directly into a nurbs surface, and then just simply add the surfaces to each other if need be (if they are not combined). Then copy the nurbs surface to the layer you need, name it accordingly and then use the tool for that surface.
    Hope it helps!!
    Here's an example:
    Primitive version
    Built out option
    • Like 1
  4. Try this. You might need to create a custom wall type for the barrel roof you wanted, however, this tool is pretty awesome. It will do exactly what you want, with materials, shape and even creates an autohybrid object.
    • Like 1
  5. The middle monitor (currently shown as black) is the vw screen after updating viewports from the viewport pallet. Also, the view port is also unresponsive during the update (which i think is contrary to the new update is). Please note, the file i am working on is a converted 2021 file, if that matters. I also updated multiple viewports at once. Is there a limitation for the number of simultanious updates in order for VW to operate while rendering?
    Thank you in advance!!
  6. Only one way I know of, use hardscape tool with the associated elevation benchmarks per face for the barrel vault. It would be an assigned slab however, not roof...which means you might need a separate record for u values.
  7. Hi everyone, recently did an upgrade to my workstation.
    Ryzen 3950x @ 4.3 ghz (overclocked), 128 gb ram @ 3600 mhz (timing 16), Nvidia rtx 3070
    Overall the performance boost for program performance is great, however, when tagging objects in elevation on complex bim models - it still slows down a great deal. Not much a performance boost, and it unfortunately is quite irritating waiting 10 seconds to tag a single object. Tagging all objects ends up tagging every object with the same record @ different orientations and elements beyond the facade, etc...
    My question - has anyone figured out a way to speed up the process of tagging objects in elevations/sections without massive speed bumbs? As it seems, hardware did very little to improve this performance. Perhaps my settings are off? or workflow is different?
    **Update - This is mostly occurring on curtainwalls and wall tags on elevations. Windows and doors are attached fairly quickly. Perhaps the amount of similar type objects slows it down?
    Thanks in advance!
    • Like 1
  8. This answer took me 6 months to figure out. Use the hardscape tool and modify the elevations of the edges to the required slope. Use the 3d aligned slab mode and use modifiers for the elevations (via the stake tool). Make sure to uncheck the option - interpolate surface, otherwise the geometry will go crazy.
    • Like 2
  9. This answer took me 6 months to figure out. Use the hardscape tool and modify the elevations of the edges to the required slope. Use the 3d aligned slab mode and use modifiers for the elevations (via the stake tool). Make sure to uncheck the option - interpolate surface, otherwise the geometry will go crazy.
  10. Wow! Thank you!
    Here is a sample GA assembly system catalogue detail
    Also attached is a sample excel spreadsheet to input the information in the appropriate fields of the components.
    There are two ways of going about it, using a concat command to summarize description of all components for the description, Wall style name, Wall Type Mark, etc..., or to have manually configured ones. Which ever is easier to build.
    Fire Resistant Assemblies.xls
  11. Are there any nodes, marionettes or other types of features inside of VW in order to parametrically create wall types from an excel spreadsheet? I.E. you have a series of fields for material thicknesses, descriptions, UL ratings, Marks, etc... that can parametric ally created the wall with all of those elements filled in? Keeping a UL wall type / floor type / Door / Window library I think is becoming very important, and since there are many proprietary as well as generic wall types to choose from based on STC Ratings, UL Ratings, Height limitations, etc... I think it is necessary to create a tools that can easily solve the problem of these libraries parametrically.
    I know it's longwinded, but, again if it makes sense - > excel - > marionette or script -> Wall style / FloorStyles / Window Style / Door Style
  12. Good afternoon,
    I have a fairly large model and have been trying to share information with consultant engineers. Upon exporting IFC V4, all wall types in the file, particularly the record #IfcWallStandardCase#.#Pset_WallCommon#.#Reference# is deleted from all the walls, and hence all the ID tags. I have repeated this twice on the file, and the bug is consistent.
  13. @zoomer Does it mix the textures somehow using an overlay? And what about general material properties? would this be an advantage to having a single base material for lets say reinforced concrete vs precast concrete?  All I am trying to figure out is how is a composite texture advantageous to a single one.
    9 minutes ago, zoomer said:
    3.
    A Base Material is a unique Material, like a standard Wood.
    A Composite Material is basically a combination of different Base Materials,
    e.g. reinforced Concrete = pure Concrete + Steel Bar portions.
    5.
    So many PIOs so far don't support Materials at this version 1 stage.
  14. Hi Everyone, this maybe a loaded question, but I thought I should put it out there.
    1. Is there a way to create a mass amount of materials via command using a texture / hatch library rather than creating one by one from scratch?
    2. Is it possible to create a new material from a context menu item like you would a hatch after scaling or modifying it via the attribute mapping tool?
    3. What is the difference between composite and / or simple materials ?
    4. is there a way to attach a material so a wall component the same way you can modify its properties without having to change the wall style? (note - This is for using the same wall type, but different wall finish colors. Say Gypsum board - different colored walls, for stucco, metal panels, stone, wood paneling...so on and so forth)
    5. Regarding Windows / Doors - same question above. Would something like that every be integrated?
    **Note - Ive read some of the other posts regarding materials on the forum. I know that it has been noted that the deviation of windows and doors not having materials was for the purposes of calling out quantities of extruded objects, geometry and wall components. This is great, but when you have to render the project, that is when it becomes tedious and cumbersome to set up the 3d model, whether it is exported via collada, obj, 3ds, etc...to sketchup, lumion, enscape, 3ds max, or blender.
    6. What is the purpose of adding additional / separate record information via the material properties. Is this for callouts via tag tool? If so, would it work on wall component plan / section details? or would it just work on 2d / 3d geometry ?
    Hopefully maybe some people can chime in with their experience of the new material tools features or uses here as well!
    Thanks in advance!
  15. Perhaps I utilized it the wrong way, but I am trying to compute surface area of a curtainwall for each of the components accurately. I created a wall Area schedule (default template) and did two types of walls - a regular wall, and a curtain wall. A regular wall accurately shows surface area of a material (connected or not...which is great for my purposes). Curtainwalls for some reason are notoriously elusive when it comes to computing surface area, and in this case showing area for glass for instance. I am using the =MATERIALSURFACEAREA('Glass Double Glazing Low-E Argon-filled MT') function, have assigned the material to all the components in the curtainwall, but alas, no cigar. Any help?
    Also, something to note, material surface area computes only on one side of the wall as shown for the masonry! If you have alot of walls, getting the settings right can be tricky! Please note - the material surface area only computes wall surface area on the left pen line, not the right! so if you need to define orientation, that is the way to find out.
    Thanks in advance!
  16. Has anyone successfully extruded along multiple 3d poly lines/ nurbs lines? I am trying to use a single profile (i.e. 2x8) and extrude it along 51 3d polylines that are spaced 16" o.c. in the same direction. Is there a way to do this in bulk rather than one by one?
    Question 2 - Can this be used with the Marionette? and if it is, can someone direct me as to how this can be done?
