506 -
Everything posted by Sbd
Viewport rendering / auto resizing of worksheets renders VW2022 unusable
Sbd posted a question in Troubleshooting
As the post suggests - this bug has a huge implication on construction documents that use worksheets in design layer viewports. Worksheets resize automatically when referenced in a design layer viewport, cropping them makes them disappear. Beware of transitioning to VW2022!!! This is by far the worst update in the last 4 years that i've experienced unfortunately, and its implications have been disastrously far reaching. A bug has already been submitted, but i am disappointed that it wasn't addressed in the latest service pack. I will try recreating a new file to see if there is something wrong with the file itself because it was originally upgraded from 2021. But this is pretty bad! Update 1 - Upon placing in sheet layer viewport - worksheet keeps disapearing. Is this a worksheet issue? or a rendering issue? -
There are many occasions when a worksheet needs to be resized to fit the viewport, but it cannot when it is fully expanded. Instead of creating a separate design layer and reference worksheets within the viewport, I wanted ask for a new feature - the ability to crop worksheets like images. This would be extremely helpful in resizing and reproducing similar information with copies of the worksheet in cropped formats. Their reference remains the same, but the ability to display selective information would be extremely useful.
Viewport Rendering part of worksheet does not show contents
Hi All, I'm rendering a worksheet referenced in a viewport located on a sheetlayer. When printing pdf, it updates the contents and successfully shows the contents of the viewport when exported, however, in realtime, it does not show the worksheet. Also, VW has a tendency to resize the worksheet as well. It requires a copy and paste - to retain the same size in the design layer viewport. Viewport Referencing design layer. Sheet Layer -
image by datavis ('') - does not properly work, or maybe i'm doing something wrong? Currently display by datavis is enabled, and imagebydatavis callout out referencing datavis name (2nd image). Also, if i change the datavis name to another data visualization - nothing changes.
- 1 reply
- 1
VW 2022 - Opengl viewport / sheetlayer background geometry ghosting
Sbd replied to Sbd's question in Troubleshooting
They mentioned on the mac it had disappeared. I'm guessing this is an OpenGl bug - where opengl is still predominant on the windows platform (i presume). It's better than in 2021, so at least that is a good thing. Additionally, 2022 is much speedier in terms of rendering linework than 2021 which is a huge advantage. So i give them the benefit of the doubt, just wanted to give the tech's at the forum the heads up! -
From what I understand, Opengl was eliminated on MacOs, however, viewport / sheetlayer geometry ghosting beyond viewport still persistent in VW2022 -
Thank you for your response ! I agree, a wall type will work very well for almost any situation. The only reason I asked about slabs and roofs was for organizational purposes when creating worksheets to list available wall, roof and slab types in separate worksheets. Is there a node that I would be able to replace the wall type node with a slab type/roof type node instead? This tool is definitely going into my menu marionette commands!!! thank you again
The last two columns are calculating incorrectly Column Z = P / O Column AA = T / S Table cell calculations for P = =IF((('!CDA-EnergyTabular'.'Solid/Glass')='solid'), '!CDA-EnergyTabular'.'U_prop'*AREA, '') O = =IF((('!CDA-EnergyTabular'.'Solid/Glass')='solid'), '!CDA-EnergyTabular'.'U_req'*AREA, '') T = ='!CDA-EnergyTabular'.'U_prop'*AREA S = ='!CDA-EnergyTabular'.'U_req'*AREA Is there something going on here that I'm not aware of?
I don't use them that often either, but after making the geometry, i generally get rid of the marrionette from the viewport, and save it as a group symbol in the resource browser should i need it again. If i need to change the barrel roof once more, i would again drag the marionnette into the viewport, verify the barrel roof name and referenced wall type and redo the geometry. I believe there is an option in there that can retain the nurbs surface while regenerating the barrel vault roof. When i do anything that is out of the ordinary, i also have massing models on another layer in case i need to take the surface geometry from it once more. I also keep design variations on other layers as well, for various options. In terms of nurbs surfaces there are several ways you can go about it. Either you create a complex shape from two nurbs curbs via the loft surface tool, or (this is generally easier for me to do) create a series of operations on various extrusions. I.E. The original barrel vault roof could be an extrusion, then a series of cuts via the split tool, and lastly, when i get the blocked version result of what i am looking for, I extract the top most surface that I would like to use for the barrel vault. Depending on the settings you use, you can turn the shape directly into a nurbs surface, and then just simply add the surfaces to each other if need be (if they are not combined). Then copy the nurbs surface to the layer you need, name it accordingly and then use the tool for that surface. Hope it helps!! Here's an example: Primitive version Built out option
- 6 replies
- 1
- roof
- custom roof
(and 1 more)
Tagged with:
Try this. You might need to create a custom wall type for the barrel roof you wanted, however, this tool is pretty awesome. It will do exactly what you want, with materials, shape and even creates an autohybrid object.
- 6 replies
- 1
- roof
- custom roof
(and 1 more)
Tagged with:
is there a way to summarize subcomponents of walls rather than showing them one by one? I've tried numerous ways to do it via summarize by value in every cell column etc... but it doesn't work, any pointers?
updating viewports from viewport pallet causes black screen
The middle monitor (currently shown as black) is the vw screen after updating viewports from the viewport pallet. Also, the view port is also unresponsive during the update (which i think is contrary to the new update is). Please note, the file i am working on is a converted 2021 file, if that matters. I also updated multiple viewports at once. Is there a limitation for the number of simultanious updates in order for VW to operate while rendering? Thank you in advance!! -
Will they be integrated in a service pack release? Or the next version of vw?
Only one way I know of, use hardscape tool with the associated elevation benchmarks per face for the barrel vault. It would be an assigned slab however, not roof...which means you might need a separate record for u values.
- 6 replies
- roof
- custom roof
(and 1 more)
Tagged with:
Are graphic legends included in this release?
Hi everyone, recently did an upgrade to my workstation. Ryzen 3950x @ 4.3 ghz (overclocked), 128 gb ram @ 3600 mhz (timing 16), Nvidia rtx 3070 Overall the performance boost for program performance is great, however, when tagging objects in elevation on complex bim models - it still slows down a great deal. Not much a performance boost, and it unfortunately is quite irritating waiting 10 seconds to tag a single object. Tagging all objects ends up tagging every object with the same record @ different orientations and elements beyond the facade, etc... My question - has anyone figured out a way to speed up the process of tagging objects in elevations/sections without massive speed bumbs? As it seems, hardware did very little to improve this performance. Perhaps my settings are off? or workflow is different? **Update - This is mostly occurring on curtainwalls and wall tags on elevations. Windows and doors are attached fairly quickly. Perhaps the amount of similar type objects slows it down? Thanks in advance!
This answer took me 6 months to figure out. Use the hardscape tool and modify the elevations of the edges to the required slope. Use the 3d aligned slab mode and use modifiers for the elevations (via the stake tool). Make sure to uncheck the option - interpolate surface, otherwise the geometry will go crazy.
Wow! Thank you! Here is a sample GA assembly system catalogue detail Also attached is a sample excel spreadsheet to input the information in the appropriate fields of the components. There are two ways of going about it, using a concat command to summarize description of all components for the description, Wall style name, Wall Type Mark, etc..., or to have manually configured ones. Which ever is easier to build. Fire Resistant Assemblies.xls
Best way to coordinate structure with structural engineer
Sbd replied to Christiaan's topic in Architecture
I was going to do a comparison between a column or beam schedule and edit it via worksheet. (The beam schedule would only be useful for girders as beams would fall outside grid lines) But its a project that has been put on the backburner for now. Its in idea form for now -
Are there any nodes, marionettes or other types of features inside of VW in order to parametrically create wall types from an excel spreadsheet? I.E. you have a series of fields for material thicknesses, descriptions, UL ratings, Marks, etc... that can parametric ally created the wall with all of those elements filled in? Keeping a UL wall type / floor type / Door / Window library I think is becoming very important, and since there are many proprietary as well as generic wall types to choose from based on STC Ratings, UL Ratings, Height limitations, etc... I think it is necessary to create a tools that can easily solve the problem of these libraries parametrically. I know it's longwinded, but, again if it makes sense - > excel - > marionette or script -> Wall style / FloorStyles / Window Style / Door Style
I am trying to create a library of materials from textures and hatches via marionette. Are there any methods of implementing this parametrically using the marionette tool?
I know people are starting to experiment with different databases, remote management, etc... particularly with this pandemic. Any way we can support library references via webdav ? (I.E. if we self-host a nextcloud or owncloud instance?)
Good afternoon, I have a fairly large model and have been trying to share information with consultant engineers. Upon exporting IFC V4, all wall types in the file, particularly the record #IfcWallStandardCase#.#Pset_WallCommon#.#Reference# is deleted from all the walls, and hence all the ID tags. I have repeated this twice on the file, and the bug is consistent.
