506 -
Posts posted by Sbd
On 2/25/2021 at 5:40 PM, Ben Beaumont said:
We have constructed localised libraries of 100's, (pushing 1000's) of Materials. @Julian Carr has written a script to create Materials from Textures which helped enormously. There is also a Worksheet that can push other material values into Material Styles. This is a boon for building libraries with repetitive information. We have updated our Wall and Slab styles such that the external and internal components (only) use Materials. Typically the external face is textured with an associated surface hatch (eg; painted weatherboard) so the component has a discernable thickness. The weatherboard Material library has any given profile in multiple popular colours. There are around 5 common weatherboard profiles and 100+ popular exterior colours. I don't think we can reasonably use Classes to manage the attributes of 500+ weatherboard options alone.
We have constructed an 'Applied Finishes' Materials library with about 150 popular and fashionable paint colours from a leading paint supplier. The Wall styles have a 0.1mm internal Component for the 'Applied finish'. The slab styles (for ceilings) have the same. The Wall Styles in our libraries have 'Natural White' associated with them, the ceilings have 'Ceiling White' associated with them.The Attributes of the other Wall and Slab components are still 'by Class'. We have a short list of (legacy?) Component Classes to control these attributes.
It is a pleasure to use the Wall and Slab Styles straight from the library and to be able to simply swap out the Material with a preferred option (also straight from the library).
I hear the comments about the absence of Class override type control for Materials, but for me the flatter workflow of simply applying a Material to an object is a far lesser evil than trying to do it with Classes. Considering the ease with which a model can be 'painted' in some other platforms, Materials are a welcome development.Are these scripts available? I have been searching for something like that for the longest.
1. Script to create Materials from Textures
2. Script to write info into the material settings
2
I agree . Great potential.
I'll start another post later, but combing this with a web gui remotely will sky rocket it's potential.
May I ask, what do you use it for in particular ?Sorry about that, too early in the morning, didn't see you mention you used it for windows.Do window sizes auto update upon selection of the record?
And can you lookup database tables to cross reference records in a worksheet? ( it's a topic I will start a new post on soon )
UPDATE 3
When you start stacking up with the ODBC datasources, you still need to delete the ones that do not work.
Go into administrative tools and ODBC Data sources and remove any data sources you do not need.
Also, if you want to set up new datasources flexibly without VECTORWORKS, this is the way to do it! In vectorworks you cannot modify existing ODBC databases. Here you can.
1
- Popular Post
- Popular Post
UPDATE 2
ODBC Works with MYSQL!!!!
There is a pretty convoluted way of getting it to work, however it all deals with the drivers.
PROCEDURE:
1. INSTALL UPDATED DRIVERS FOR MYSQL ODBC CONNECTION. This is important for successful connection. See link below.
https://dev.mysql.com/downloads/connector/odbc/
Both x86 and x64 drivers should work in the connection as I was able to set up an database connection using an ANSI ODBC Driver as well as the UNI ODBC Driver for MYSQL. (albeit with A LOT of trail and error)
2. Set up MYSQL server via localhost or docker. In my case I am running MYSQL over docker with PHPMYADMIN as the database connector. Additionally, I am using NOCODB as an airtable alternative in order to modify records remotely (i.e. via website). Additionally I am using Portainer to manage all of my containers.
As of this note: I am currently not using a remote WAN capability for mysql server, however it is possible to do with a reverse proxy. With enough votes, i can set up a tutorial on how to do that if there are enough people interested.
See screenshots below
Since I have used custom portforwarding - my container port is 3306, but the facing WAN port in this case is 4040. (This is going into the real of IT, but i recommend having a bit of knowledge on that front in order to do this. Otherwise use a locally hosted version of MYSQL server.
3. After you have recorded the information for connection, next thing to do is to connect to the database using a GUI or a hosted system. In my case I am using noco db
https://hub.docker.com/r/nocodb/nocodb
Setting up nocodb is pretty easy. But in this case, using PHPmyAdmin would actually be better because you have control over database names, and table names. I recommend using a compose file with mysql, phpmyadmin as a resource in order to access everthing. Ill provide the docker file/compose code soon.
4.
5.
7.
8.
9.
10.
11
13.
Press the Test button for additional confirmation. If connection is successful, it should work.
14. Press OK to create the connection. Here is the tricky part - after creating EXIT OUT database connections. It needs to repopulate the DATABASE SOURCES above the connection string.
14. Go back into connections
15.
The database should appear in this list.
16. REenter your credentials for the SQL server
UPON CONNECTION - YOU should see the database rows
Go back into record format connection to link the database to the internal records
DB should populate
Connect the record fields the the database record fields
It should auto populate your selection after you update vectorworks connections
For faster synchronisation
1. Create a shortcut key for vectorworks connection update
2. see below
and
Hope this helps!!
6
great news everyone, ODBC works for mssql . however I am missing something. I am still getting an error after setting up a connection after successful test via ODBC.
I used MS SQL server 2019. Am i to use an earlier version?
I was able to set up a table inside the container and was able to connect via test connection when setting up ODBC parameters.
after setting up the connection - i get this error
Note - I have confirmed the sql tables work via noco database, so the problem lies with either the driver, sql version number, or something else. (see screenshot below)
connection currently works, i just don't know why it rejects the connection after successful test.
I'll do some experiments, stay tuned!
But here is the summary of what I've discovered so far (on a local level)
When using an sqlite file, I modify the sqlite file in an open source sqlite file editor - something like
I add tables to it specifically to what I need (I.E. product database with insulation characteristics, or pricing tables, or zoning / building code reference database and I link the database to record information in VW in read only mode.
When i assign that record to an object - it does not update immediately, i have to use the update vectorworks database in order for it to choose. The table above was an experiment of sqlite database reference - and in large databases, a search query or search by record would be fundamental to using ODBC.
The part that is annoying is that I can change a record in the sqlite file upon entering the information, but I cannot update the object upon selecting the record, which is a bit frustrating.
I'll try using ODBC with mysql hosted on a local docker vm and update my progress soon.
Also, Would adding a search function for large databases be possible?
18 minutes ago, Nikolay Zhelyazkov said:
- I am happy to have helped! If we go for Bulgarian it is "Благодаря" 🙂
- Have you tried setting the text wrap of the objects in the tag layout? I think that this might be what you are looking for. If this is not the case, can you give me some more details on what exactly do you mean?
In that case, Благодаря ! 🙂
Also regarding your question - see screenshot below. This is a comparison between a tag vs a annotation callout . A callout has toggles, but no database reference.
It would be nice to resize text like a callout in a limited size viewport in case it is needed.
(also, I have a hunch that a future feature - legends will work very similarly to a tag, only summarizing in bulk all of the elements referenced...might eliminate this need entirely if the text in the legends can be resized similarly...
I also have a hunch that you are also directly related to that feature!....but alas, it is only a hunch! 😁 )
4
3 hours ago, Tom W. said:
@Samuel Derenboim see:
Can be used to tag materialmanufacturer, materialreferenceID, etc as well. Unless it's a Compound Material in which case you can only return the Description, Mark + Keynote fields as far as I can tell
Thank you for letting me know! Posted a formula for regular geometry as well.
Will be very useful in the future for detail call outs (creating a custom set). Originally intended on using symbols with custom records for annotation and callouts.
I also noticed a custom record option in materials - it would be interesting to see how that works as well! I will keep experimenting
Also, will we ever see text resize toggles for tags? 😁
It seems that solution might work for walls. I also use it for regulation geometry
The formula for this would be :
#WS_MATPROPERTYBYNAME(MATERIALNAME, 'materialmark')#
#WS_MATPROPERTYBYNAME(MATERIALNAME, 'materialdescription')#Спасибо! @Nikolay Zhelyazkov
1
Each detail would be a separate symbol. (to me sheet does not mean sheet layers). If by sheet you mean what is in the design layer viewport - then yes.
Detail number for the detail works, but if it can be detail + drawing name (i.e. . But I will rename each symbol to be the detail name later if we cant do baseflashing for wall deck. etc... (like it is in the detail itself, that would be even better). But if you can't, it's not a big deal.
Yes, I think you summarized my intent correctly.
Modified Bitumin would be the parent folder if it only had symbols inside. Modified bitumin is part of an Asphaltic line of details, so it would be best to inherit the folders inside the base folder. I.e. Lets say Asphalt Details => Modified Bitumin => DWG symbols.
Thank you again!!!!!
That is exactly the procedure. Thank you so much! Let me know if it uploaded the file fully. If not, I can send a link.
Pardon my non specificity.
So this is the way i did it previously - import dwg batch - > in advance preferenced i was able to set all lines to black and white. What it doesnt do is import the dwg files into their respective folders.
Then another method came up - using import symbol (batch command)
It in turn created all subfolders in the directory!
what it doesn't have the option to do is convert lines to black and white as shown below
But most importantly, it eliminates the name of the detail, and detail no. of the mfg.
Now if i import the detail as a layer and not as a symbol - it provides all of the information that was in the record (see below)
My concern and original question is
1. How do i preserve the record information upon import as a 'symbol'
2. convert all lines to black and white
3. distribute all symbols in their respective sub-folders when importing from a directory with subfolders
Polylines, rectangles etc.. preferably shouldn't be exploded to retain hatches or fill. i only asked because if the symbol would be converted to group, the information would be retained. But that was a sort of convoluted way of going about it.
i figured i did something wrong. lol i think i was able to do it now
1
21 minutes ago, Pat Stanford said:
Basically No.
The internal VW scripting model only runs in a single file. This applies to Marionette, Vectorscript, and Python. That means that you can not start a script and have it open a different VW File and manipulate that file.
Long ago I wrote an AppleScript that took a folder of VW files and opened each one and then ran a Vectorscript to export each file to a DWG file.
Something similar could probably be done for your import thing, but since you are on Windows, you don't have the AppleScript option.
If this is a one time conversion project I might be able to help. If this is an ongoing need, then I don't have any other great ideas.
Thank you for your response regarding this matter! unfortunately yes this is ongoing. Ok, ill drop that idea, however i noticed that with import symbol (batch) - vectorworks can import dwg files by folder quite seamlessly, however there are still a few things i want it to do while it is importing which is -
batch import = > explode all symbols = > convert all lines to black = > proceed with import
I'm Having a bit of an issue with importing dwg files as symbols as it does not do a few things i prefer like :
1. import folder structure the dwg subfolder directory
2. import / convert to group any elements that have record information (normally does not import record information as nested symbol)
3. name all symbols by record name (inside of symbol) rather than file name of dwg file.
I thought about going about it a little differently -
batch convert to vwx in place, and then reimport every vwx file as a symbol.
Another workaround can be convert bulk dwg files in place - but with every action save extents of imported layer as symbol
I feel like this can be done with the marionette tool - however i do not see any nodes for :
1. creating symbols
2. opening vwx files
3. converting design layer to symbol
Is this possible?
ah, thank you Tom!
Will we ever be able to pull material data information into a data tag?
I noticed in order to pull it in a worksheet - command is something like :
=MATPROPERTYBYNAME(B3, 'MaterialDescription')
=MATPROPERTYBYNAME(B3, 'MaterialReferenceID')
=MATPROPERTYBYNAME(B3, 'MaterialManufacturer')
etc...
Will we be ever able to do the same thing with data tags?
Beautiful!
Is this for wireframe? or shaded background renders only?
4 hours ago, Pat Stanford said:
I agree with Christiaan. The people at VW are trying to do the best job they can with the resources they have. I am certain that the sales/marketing/management at VW are aware of all the options and impacts that this change will have. They have watched the industry move in the subscription direction for years. They are not suddenly going to a new model that no-one has ever tried before. And based on their research and experience they are doing what they think will best benefit VW.
If it benefits VW then it must also benefit (or at least not harm) the majority of users. Will it be the right thing for all existing users. Absolutely not. Will it be the right fit for many on this thread? Based not he responses, probably not. But the users of this forum are a tiny fraction of the total number of users.
And please give the VW people some credit. I am sure this was worked on for a very long time. None of us like it when someone with no understanding of the requirements or site conditions criticizes our designs that were done to the best of our ability. VW personnel feel the same about this.
My $0.02. Written for my personally, not in my role as a moderator or in any way representing VW.
I agree, the people that develop the software I am sure that they are in 100%.
Your help alone in these forums helps a tremendous amount. The fact that the programers/developers in VW also participate in the conversation is a huge deal.
Having said that, how will the subscription system help ?
Is it intended to increase the development team? or provide better updates? Will your salaries increase due to this condition?
If so, couldn't that simply be solved by increasing the price for entry for permanent licenses - and why will that option no longer work?
At the end of the day, is it the development team that determines whether or not features get released? or whether it is the appropriate time to release them? or is it management? I just am under the guise that management is divorced from development despite how well intentioned and passionate the team is...unless I am mistaken, then Ill certainly eat my words.
1
9 hours ago, shorter said:
there was another that reversed that result…Can you share a source?
Also regarding my assessment wasn't regarding a hunch, but rather demand. Go to Archinect or any other website that provides job listings.
On Archinect, search for vectorworks as a keyword. Only 26 jobs available throughout all of United states ( not sure if it covers UK).
Do they same for Autocad. 673 results. Revit renders 764 results. Archicad renders 45.
Total search results: 1508
Autocad - 44.4 %
Revit - 50.6%
Archicad - 3 %
Vectorworks - 1.7 %
These are real-time numbers that currently list jobs available today.
As a reseller of VW, I understand your position, but at least be fair.
3
Linking Custom Database to Parametric objects
in General Discussion
Posted
Has anyone had any experience using the data manager and parametric objects like windows and doors?
The reason for the question is to link external databases that have information on doors and windows to parametric objects without having to create styles individually. Going to manufacturer to manufacturer and custom make parametric objects is unfortunately very tedious, and wanted to speed up the process. Like for example Marvin and Pella windows - vectorworks created a great catalog however some information and sizing is outdated (particularly product names) which makes me feel a bit wary of using them, therefore i end up creating my own when i have the time. However there are also some other companies like anderson, and even European windows like zola etc... that would still need some kind of integration on the users behalf. VW obviously doesn't have the resources to produce something like that, and I don't expect them to since the features they're working on i believe should be the priority.
With my recent discovery that ODBC can be referenced remotely, I have a renewed desire to link database libraries to parametric objects. How would one go about doing this?
Has anyone experienced this? Any thoughts?
