Sbd
    501
Everything posted by Sbd
  1. Matt, I was going this route until I had to copy the txt file export. It looks like a csv export of some sort. Direct export to txt? how would i go about doing that? I also noticed the xml file is coded, so therefore it would be best to leave that end alone, right? Once you empty out the spreadsheets, you can create the catalogs from inside vectorworks - no need to modify one by one. But I agree, copy and paste a few dozen times for various door and window manufacturers and you have yourself a great resource without filling in the blanks just modify the rough opening and clear opening elements and possibly frame sizes / descriptions of the window and its catalog cut sheet. Something we in NY specify often are Ceco doors, or other steel doors for egress / mechanical room access, etc. Surprising theres no catalog for them yet. But if I manage to get it to work, will share! Other door companies like simpson, etc... or window companies like pella. Looking forward to new releases! One huge cumbersome element however - Descriptive elements for doors / windows are parametric - and cannot be edited or modified from a worksheet! Back in 2015, it was, until a more proprietary integration system was put into Vectorworks. That I believe is the biggest downside with automating schedules and updating libraries. Just my two cents. Otherwise, this new update is a great breath of fresh air. Its faster too! Especially the additional viewports and the tabbed windows. Either way, I'll come back when I've explored a bit more regarding hacking into the catalog files Thanks everyone!
  2. Good afternoon, I'm in love with the option to use catalogs. Is there any way to make new catalogs for doors and windows? This is great because custom symbol creation now has the possibility of becoming so much easier
  3. Hi everyone, I do have a question regarding schedules, particularly those that are symbol styles (i.e. doors styles, windows styles, etc.) 1. Is there a full list all the record format connection references in a complete guide for all objects? i.e. window.height, door.height, etc... I can create a worksheet with all records that are provided from the create worksheet menu, however, it's cumbersome doing this process for all styles in vectorworks. 2. Is there a way to modify these records from a worksheet remotely? I've noticed that even if I unlock the parameters set (instead of them being controlled completely in them) in the styles, I can't modify them for ALL of the elements in a drawing, particularly if there is more than one symbol. I have to modify them one by one in the door/window dialogue box and in doing so its a very inconvenient procedure. Any help please? Thank you in advance!
  4. Just curious, does anyone have a mass import script for revit files handy? or perhaps something similar for marionette that would import and create symbols from revit libraries? Could be useful since alot of product manufacturers issue revit files only. Any takers? Willing to share some libraries after i'm finished.
  5. Is there currently a way a schedule can callout objects by their style in the database? I.E. Windows and Doors? etc...? or rather limit a function of windows or doors by their style type or name?
  6. Well i've narrowed it down, when i create the viewport from a clip cube, know the depth length and width of the viewport, it seems to render it fairly quickly. However, as soon as i turn on the markers layers for the windows, then it takes ages. By the way...by ages, I mean it freezes, and doesn't finish rendering...:/ Any reason why? UPDATE: So for some reason when i assign a different class to a marker, it doesn't render, but when i keep the marker in the window class, it renders. Could this be a bug? I assigned an Anno layer only for markers... I have a total of 200 windows, maybe 1/3 are showing on this layer....Also, does the length of characters in the markers depend on rendering time? I know they're opengl, so i figured it shouldn't matter, no?
  7. Thanks on the tip Alan, My file is pretty tidy in terms of textures, hatches, etc... I try to use line work, hatches and textures only once. I try not to use patterns because they require opengl, and i prefer to render in hidden line format. I do have a lot of classes open, but I will be using them in the near future. Can empty classes really slow down a file by that much? Either way, I'll purge, will tell how it works out. Thanks !
  8. Good afternoon everyone, I've worked with vectorworks for quite a while in a few different firms, however, only the past year and a half did I really get into the parametric end and BIM end of vectorworks. I do love the features and time saving elements in vectorworks that vectorworks allows you to customize on your own or are inherently in the BIM elements. Having said that, when working with larger projects - i have come up to a few issues when working with larger and larger projects. Since I need to often share information with engineers and clients, they prefer the information in CAD. This means that all of my plans and elevations need to be exportable (not rendered in OpenGL). Whenever a project grows larger and larger in size (multiphased) the harder it is to work with the file itself. Why should a line rendering take 5-10 minutes???? But then again, it could also be the workflow. Generally what i do is store the entire project in one file rather than several. It doesn't take as long to update references stored in a separate file and is generally more responsive that way. But, i recently reached a 600 mb threshold, and i'm having a major problem rendering all of the elevations. Could this be a problem with the amount of information stored? All my walls are brick, and some elements have stone work...which could make the renderings intricate, however, this is unintentional. Using regular hatches should make it easier to render. Does anyone have any tips? or feedback? Maybe similar experiences? Thanks alot everyone!
  9. I wish it was that easy. But after i have 18 layers, and 19 references sheet layers and almost completed sheets, its very hard to redo the callouts....i was hoping there would be an easier way to fix this? Also, does this mean there's a bug? or the file itself is just corrupt? and if so, how do i go about avoiding this problem in the future? Thank you in advance!
  10. Pat, Sorry for the bother again, there seems to be a bug - after heavily using the callout tool, it starts to behave very oddly. I am attaching a sample file where the callout tool has been corrupted. Problems include: In design layer view port - 1. An additional leader element is added to the callout tool (usually on the right or left side - there is an unnessary line) 2. Note is slightly offset when adding and additional leader that gets in the way of the text. In Sheet layer viewport 1. Callout is displaced drastically from leaders 2. Shoulder length function or text margin doesn't solve the issue. In annotation Layer viewport 1. When placing a new callout - leader only is called from the left side of the callout, and cannot be switched normally - unless the mirror function is used. 2. Cannot delete leaders in annotation mode. All problems therein have been bubbled. You can test it yourself, could you confirm it behaves similarly? and if so, is there a way to fix it? In new files, this problem doesn't seem to persist, but who knows? I just recently started using the callout tool. Anno_Leader_Trouble_Shooting.vwx
  11. Thank you Pat, How do i go about doing this?
  12. Good afternoon everyone, first would like to start off by saying happy new years ! I've been playing around a little bit with the callout tool, however i discovered a bug. I've been trying to create a symbol detail library to reference for standard wall details - and i've recently discovered the callout tool (earlier posts) I really like the feature it has where it can generate a legend for a series of callouts - and then just that legend can be modified for that particular element. But i don't think this tool has been fully developed. The callout tool isn't designed to be inserted into symbols, something ive been trying to do. It loses its properties and generates a separate note for every callout every time it's dropped, something that i don't want to keep fixing all the time. Could anyone please confirm this is the case? Does anyone else think this is a bug?
  13. Pat, Thank you for the suggestion. I figured it wasn't possible. I've been using this method thus far, just thought there might be a quicker way to do this.
  14. I think i found a bug - Can anyone else verify this ? I have the latest service pack - for the callout tool - Adding a leader works, but deleting one doesn't. Can someone please verify?
  15. Thank you for you that Pat, Is it possible to continue information in a database in an adjacent column though? I.E. Lets say i have a database connection with 2 column references, and i have a total 4 column worksheet. Would i be able to say continue the database information on the 3rd and 4th column after i reach 10 rows of records?
  16. UPDATE: Apparantly the call out tool is a really great resource for keynote legends. Pardon my ignorance, i just recently discovered this feature. A great thing about this feature is that it has an option for additional columns - which is great! However, i do have a question : Is there any way to add additional columns to either : 1. Worksheets - if it exceeds a certain width / length or 2. General notes tool. There is no option for this in the general notes tool - a huge limitation!
  17. Good afternoon everyone, I've been working on a set where i have alot of callouts for plans, elevations and sections that seem to be repetitive but not parametric, and i've been wondering... Is there a way to combine notes database with a callout tool or perhaps a bubble revision tool? I've been thinking of a simpler way of marking up notes by using annotation bubble revision markers and linking them to notes that are shown separately on the sheet in list form. There are multiple reasons why this is a useful feature 1. CSI can be embedded into notes parametrically - unifying elements in the project to specifications without any deviation to notation 2. Simply the callout process in plans - and eliminate clutter by referencing notes beside the plans. 3. No errors in documentation 4. Information is centralized - and modification to notes or finishes can be made remotely. 5. Notation tool does not need to be updated independently from the bubble revision callouts - they're intended to work simultaneously. Method - My current method is simple - i created a 2 custom record fields one for number, the other for description of the object - and reference those records in a table for that layer only. I however - end up having to make one table for each layer (floor plans, rcp, tenant protection plans, fire safety plans, etc...) which is the only nuisance. I end up having 10 - 20 worksheets just for that set. Is there a way to combine this method with the notation tool? and is there a way to eliminate duplicates? perhaps a method that would allow us to use one worksheet dynamically? Either way, I know this feature doesn't exist, but i figure , if anyone has any ideas how to combine these tools, i'm all ears? perhaps Nemetchek will hear us? Thanks everyone!
  18. Good afternoon everyone, This is more of a wish list item more than anything. Dealing with different engineers that work in autocad, i find it a bit frustrating to export elevations with hatches in BIM mode to be converted into linework. More importantly, when selecting option for hatches to be converted to a separate layer, any exported elevation (not plans) hatches in vectorworks aren't converted to a different layer, instead they remain in the original layer of the wall type class. As a result the dwg files become bloated and hard to modify. Any way to change this? I know a workaround, however, its a bit cumbersome - which essentially converts any surface into a poly - that can use hatch information. This exports just fine into required hatches, just a nuissance to do for every job. Perhaps there is another way? Thanks in advance !!
  19. also, convert you pts files into .laz, itll decrease their size by over 90%, just FYI I have a 60 GB pts file that i need to shrink, and by converting to laz, i made it about 3 gb
  20. I have a bit of experience with this. As a tip, I wouldn't recommend converting them to individual 3d loci - as it will increase the file size tremendously. What I would do however are several things. When you import the entire .pts file or .laz or .las I would put it on a separate design layer and do not touch it. Then i would use the clip club to get the proper section cut you need, however deep you need it. So lets say your pts file will have a high elevation of 7', and a low elevation at 3'-0" - use the clip cube to clip that precise amount. When you finish doing that, right click the top face of the clip cube, and select convert to viewport. This is important - Use a design layer viewport instead of a sheet layer viewort as you can snap the points. Also, point cloud information only works in openGL - not in architectural plan mode, so bear in mind when you do that. (use the number 5 key on the number key pad to go into plan view mode for opengl). Otherwise you will not see the section information inside the viewport. The great thing about this technique is that when you assign the design layer viewports for multiple levels, you can change the depth in the section viewport properties, so if you need 1", itll use 1", if you need a foot depth, it can do that as well. Same goes for sectional information. This definitely takes a bit of practice, however, definitely useful. This technique is for Dynamic informational use - when drawing your plans. If, however you want to make slices, the point cloud tool has the option to delete all other information when you create your slice. I would recommend looking into the tools tutorials. But you definitely don't need cloud compare or any other software to get the sectional point cloud information. hope this helps!
  21. Pat, Sorry to bug you again, is there a way to show the dimensions of all sides of a space? not just the length or the width? In the New York jurisdiction the plan examiners are very meticulous to zoning floor areas, and as a result ask us not just to show the dimensions but show the areas and calculations of every space adding up to the whole. This requires Architects in New York to subdivide all areas into rectangles, squares, trapezoids and/or triangles. When you have a trapezoid in Vectorworks however, the length of width function only shows the dimension of the larger length, not the smaller one, and not even an average between the two - which is something used in calculating the area of a trapezoid. so my question is : 1 - any way we can call out/show all the dimensions of a space? 2 - using average(length) or average(width) still wouldn't work to call out the average between the two unequal sides. any workaround?
  22. i was referring to the worksheet. shouldn't Str2num work the same way in converting a database string entry into a number format? I believe it worked for me earlier. I will double check at home, since i have done a few experiments with this already, but a while back. By the way, =Round string worked perfectly!, Thank you Pat!
  23. Michael, Quick question, is there a string that allows a database header to round a number to the nearest inch? In other words, lets say i have a space thats 6'5.324" x 4'7.643" - when displaying the length and width and areas - is it possible to round these numbers to the nearest inch? like 6'5" x 4'8" ...etc? Also, str2num doesn't work in vw 2017 anymore...am i missing something?
  24. its easy using the 3d polygon tool. first create the bottom edge, then the top edge. Once you have both profiles, use the polygon tool to create the surfaces. once you are done, use shell the create thickness of the walls
  25. Is it possible to create a roof object that is tied to story elements? Or at least having a height setting for the bottom and top portion of the elements? That way rise over run / angle would be calculated automatically. Just a thought. How does everyone else feel?
