I've been digging around a little bit on the Microsoft website and so far here is some information I've found which I do beleive pertains to my problem, but it sounds like there is not much I can do about it.
From the Microsoft Knowledge base:
SUMMARY
When you attempt to shut down your computer, start Windows, or start a program in Windows, you may encounter error messages that are similar to:
A fatal exception XY has occurred at xxxx:xxxxxxxx
Fatal exception errors are codes that are returned by a program in the following cases:
Access to an illegal instruction has been encountered
Invalid data or code has been accessed
The privilege level of an operation is invalid
When any of these cases occurs, the processor returns an exception to the operating system, which in turn is handled as a fatal exception error. In many cases the exception is non-recoverable and the system must either be restarted or shut down, depending upon the severity of the error.
In the sample error message that is listed above, XY represents the actual processor exception from 00 to 0F. (Note that the "h" that is listed after the 0E, 0F, and so on, in the explanations below is frequently omitted from the error message.) The xxxx:xxxxxxxx value represents the enhanced instruction pointer to the code segment; the 32-bit address is the actual address where the exception occurred.
Windows does not cause these errors, but has the exception-handling routine for that particular processor exception, which displays the error message
14 (0Eh): Page Fault
The Page Fault interrupt allows the operating system to implement virtual memory on a demand-paged basis. An interrupt 14 usually is issued when an access to a page directory entry or page table with the present bit set to 0 (Not present) occurs. The operating system makes the page present (usually retrieves the page from virtual memory) and re-issues the faulting instruction, which then can access the segment. A page fault also occurs when a paging protection rule is violated (when the retrieve fails, or data retrieved is invalid, or the code that issued the fault broke the protection rule for the processor). In these cases the operating system takes over for the appropriate action.
Any one out there have any ideas? I would sure appreciate it if any one could give me some pointers as I have already emailed Nemetschek Tech support and haven't received a reply as of yet.
