583 -
Posts posted by Elite Exhibits
Rotate 3D View script...
Is there a script to Rotate 3D View, and be able to set the direction and angle ?
vs
Resetting the dialog box each time
DoMenuTextByName('Rotate 3D View...',0);
Rotate 3D View Dialog Box_1.pdf
Peter
On 11/6/2023 at 7:53 AM, shorter said:
Being able to assign shortcuts to saved views... now that would be useful.
This script should work ...
VRestore('111');
It brings up the Saved View 111
Peter
- 1
@gangotti A long standing problem - It rears an ugly head now and then - see attached
1. Not the Attributes (as shown) (ie: No Fill)
2. Not the Text Style as Indicated in the OIP (ie: Un-Styled)
3. Not the Class (at least the text should be Red based on the Class setting)
Look for something odd or missing - here the Spacing is blank in the OIP
Try changing that...
Seen this with Text - Callouts - Dimensions
Too often the solution is to wipe over the text / copy / past into an existing visible example or a new one.
¿ The Source of the aggravation ? ...from our perspective it may be a file originally created in a different version of VW.
Peter
@Christiaan - Just commented on the aggravations Rotated Plan is, with our Workflow, in your Working Plane Views mode post
We don't NOT rotate the plan, yet VW assumes that we have and it makes for added effort to use a Work Around when Standard Views do not act like Standard View
A LOCK would be great - We would want it to be in the Rotated Plan Off position
Peter
- 1
4 hours ago, Christiaan said:
You rotate the plan so that your...
In a simple separate test file, (3 Extrudes) tested this and it appears very convoluted - VW changes the Rotate plan back to Zero ?
Question
Is the Plan Rotation set to 0 first, (In the Mode / Tool Bar)- and the geometry drawn / rotated in the drawing ? or is the Geometry drawn X-Y first and then then entire drawing rotated ?
Need to Google search the VW Help to get a hit for Working Plane Views mode only one UNDER THE VIEW BAR with text in that Blue Green Text Zone (Where the Main Print giveth and the Inset print taketh away ...) No real explanation
Rotated Plan view is a major thorn in our Workflow - A. we do not use it - B. VW appears to automatically think we want it. The result is geometry that cannot be edited in Top/Plan view (as VW has decided it is now rotated) or Geometry (Symbols especially) that are placed and rotated show up in Standard views (Front, Right etcetera...) at an angle, not the view expected. Top/Plan view often indicates Rotated Top/Plan View.
Assistance is appreciated
Peter
Wall Questions - Unify Walls Created with Create Objects from Shape ... + Textures on Walls
v2021
Draw a Polyline (L shape with curved Corner - see attached)
Use: Create Objects from Shapes
Created Wall(s) are NOT a single unit - Several Walls are created
Question #1 - Tool to combine into a single Wall - "The Wall Join tool joins straight or curved wall segments" does not join the walls as assumed - into a single wall -
¿ What options are needed to join a straight and curved wall vs intersecting Walls ?
Intent is to apply a texture on a singular Wall - vs aligning Texture onto several walls
Question #2 - Walls with Textures applied - lose the Texture when the length is changed
¿ Is this the norm ? makes the added editing process tedious.
assistance is appreciated
Peter
Very odd - able to see the preview - not open it with V2016 - v2020 - v2023
Peter
or it is older ? (the 2013 reference above ...)
Peter
Assume it is v2024 - does NOT open in v2023
Peter
FYI
We have an app for the Mac - PDF Vector to DWG - works as expected
Believe that they also have a SVG to DWG converter
https://cadimport.mystrikingly.com
Peter
@Jeff Prince & @Pat Stanford comments above are key - although I have a collection of workarounds when I have VP that do NOT look correct and I need to deliver the design before VW have an explanation (If they ever do...)
Suggestion:
When I import / inherit items from other drawings - (Even when created in VectorWorks) I take the specific problematic object and place it into a blank drawing - as None and Dimension are the only Classes in a Blank drawing, any classes used in that solo item (your Tree as an example...) will be appear in the Organization Palette / Classes.
I often find some Legacy CAD induced Classes like "0" - "PDF" or plural versions of what I thought the classes should be.
In that drawing, where you have this single problematic item, Classes could be deleted / combined / renamed then the item brought back to the main design.
Another non destructive (albeit potentially convoluted...) is to Save the drawing, turn all the classes on in the VP, Update - see what is visible (theres that tree ?!? ) - then Revert to Saved for a return to the previous VP Class settings.
Peter
Greetings
Question is, any one use the Freehand Reshape mode ? (with success ?)
I have read the Help - Watch videos (
Looks good - Unable to have it function, as such, in the real world
Reshape 2D items only
Rectangle - Polygon - Polyline
Open and / or Closed
Layer Plane and Screen plane
We find that the tool in either mode only draws an added object
No addition to the selected component
Aware that there are other edit mode to use, just curious or is this one of those inexplicable aggravating anomalies
Any Advice is Appreciated
Peter
Question here is now ... ¿ How does the WIDTH box show up in the Floating Data Bar for a Rectangle ? (as Tom W illustrates above)
VW 2023 SP7 does NOT have this feature as the default - see attached
Any assistance is Appreciated
Peter
WIDTH on the Floating Data Bar Tom W FORUM_1.pdf WIDTH NOT on the Floating Data Bar v2023 SP7_1.pdf
- 1
@Tom W. thanks, except ...
Try as I might, the WIDTH box is not part of the Data Bar for me - what settings am I missing ?
Peter
4 hours ago, Tom W. said:
What is your current workflow? I would just hit tab, right arrow then enter +4' in the floating data bar + hit return twice.
@Tom W. - Interested in what you mention as I am unable to have it function as described
...an example as in the first illustration by Bill Treen above ... (May be a preference setting)
Expound, Please and Thank You
Peter
Example of Rotation where none is desired / none is needed
Screen Shot
Drag and Drop into drawing
Edit Crop
Paste existing Circle onto bitmap
¿ This Rotation of the Bitmap is for what Workflow ?
Assume that the circle dictated the angle of rotation from looking at the handles
Yet, in the OIP, the circle has NO rotation (?)
Peter
I have drawn as @Pat Stanford suggests a 3D polygon (two clicks gats you a "line") - as a reference put out a 3D Locus or a sacrificial bit of 3D Geometry to snap to
see attached
Peter
... the Question is still : Is there a way to stop / reset / correct VW from rotating the woking plane or assuming that an item - drawn or imported - is on a rotated plane.
Any advise is appreciated
Peter
Preference / Way to turn off the Dimension Witness Line Override
in Troubleshooting
Posted
Not the Witness Line - the Override
Editing existing dimensions VW appears to Auto add Override Witness lines
in different locations - Spending to much time re setting this feature in the drop down back to none.
Suggestions ?
Peter
