Elite Exhibits
    583
Posts posted by Elite Exhibits
  1. My 2¢ on VW Videos ...
    @rDesign URL video link is a good example (see above)
    What I find with some VW training is a level of sugar coating that might still leave some uses in a quandary.
         Example in this case: The demo file in the video is set up and complete...
                     (¿ with the assumption is that you look for and use items from the VW Libraries  ?).
    As someone with a work flow that utilizes FAVORITE files for most all designs and edits, understanding how to start from scratch and load the Resource Manager would be an important key
    Peter
    • Like 2
  2. @Tracey Andrews as Tom mentioned - you need to tell the RM what to look for as well as where to look - Typically the RM looks in one place at a time - unless ...
    If you tell the RM to show Symbols, for example. Click in the right column highlighting  the top most drawing. Make sure the left side carets pointed down on each header. (Open, Favorites etcetera (as shown above)
    Now use the down arrow on the keyboard and the RM will show the next drawing and the Symbols (in this example) it contains - easy way to buzz thru you Favorite Drawings.
    And, as Pat Mentioned, you may ask the RM to search. Where you search is also critical in what the RM finds for you- set that first, then type a word - start simple / generic as Pat indicates
    Searching everywhere is the option if you do not have a specific file in mind. (Or don't know where it is...) Search everywhere is not really everywhere - it is everywhere on the left if the RM is connected to it (assume for now, if you see it, you are searching there.
    The caveat with searching everywhere might be the RM finding multiple identical items and you not knowing where you have searched
    Right click on an item after the search everywhere and select the Location option
    The RM will take you there. Not what you want ? History back arrow.
    ¿ Lost ? - The history arrows might help
    Peter
    • Like 4
  3. To clarify, using a trackpad on a Mac book Pro you can set it so simple zoom and pan, in VectorWorks, works without having to change tools / hold a key / roll a wheel. The Track Pad can also be set so that right click / contextual menus takes no additional keyboard keys or alternate mouse clicks. You accomplish this direct from the trackpad.  Control / function beyond the 3 switches and a roller wheel on a mouse vs fingers already on one Track Pad.
    If you are NOT utilizing the Track Pad on your MacBook, an easy start is to turn OFF all gestures in the Preferences, then turn on one feature at a time and see what the function is in VectorWorks. Look also under Accessibility as there are additional features (gestures) there. If you play guitar or piano you know one may hold down a single finger while another finger does something else. Try a similar approach here. Example: Right hand starts to draw a rectangle, lift a finger, left had zooms and pans, right hand finishes the rectangle.
    Test the Track Pad gestures along with the modifier keys as they add a few hidden features in VectorWorks.
    Based on how you set up your Preferences if the crop perspective is off - you get the ability with the flyover tool & Track Pad to maneuver in the 3-D world - if the crop perspective on - you get actual zoom… as in the drawing gets bigger rather than the 3-D world getting closer.
    The Track Pad accomplishes the same mid tool functions a multi button mouse does. Except there is no external mouse to carry, account for, plug in and locate on some adjacent real estate while utilizing a laptop on the road (...or in coach class New York to LA).
    Please see the attached - Track Pad only manipulation (¿ unable to download ?)
    Peter
    • Like 2
  4. On 3/9/2024 at 5:14 PM, Jonathan Pickup said:
    I always take a mouse with me, I just can’t draw or use Vectorworks effectively with the trackpad.
    It is remarkable what can be done with only the track pad   - try the addition of the left hand and existing Zoom / modifier keys.
    Peter
  5. 50 minutes ago, Jake Wilson said:
    I have never defined the working plane as far as I know.
    VW has a major faux pas in this Rotated Plane Mode  - Defining an object rotated as it was originally created - especially with Imported Information.
    Just Yesterday  - I attempted to modify a Hybrid Symbol from a "Left / Right" version to a "Top/Bottom" version -
    ie: rotate it 90 degrees -
              No Layer Plane objects were harmed in this process - Hybrid was 3D and Screen Plane ONLY.
    In the Resource Manager
    Duplicate Hybrid Symbol
    Rename
    Edit 2D - Rotate 90
    Exit
    Edit 3D = Rotate 90
    Exit
    Viola ... Not so fast  !
    Some Text is upside down / Some text is backwards / Some is upside down and backwards
        Mirror and rotate do work on this text (assume that it is now in a parallel universe)
    Quick check of the Rotated Plane setting - (ARGH !) - VW has automatically set it to 270 degrees (?) and you could not select a standard views even Top/Plan was Rotated Top /Plan
    Solution: Copy Hybrid Symbol into a blank drawing
         take apart twin copies
              1 @ 2D and 1 @ 3D
                   rotate as needed
                       reassemble as a Hybrid Symbol (with same name)
                               Import and over write the Symbol back in the original design
    (ARGH !)
         If there is a better way ...
    Peter
    Rotated Plan 270 degrees_1.pdf
  6. @lkr241 Think of Associated Dimensions ONLY working in 2D  - ONLY on a Design Layer -  ONLY with Screen Plane (Top / Plan Component in up dated lingo ...) and you will have a happier VW experience - We turn them OFF and use them only for specific projects. (Yes SOME Wall Dimensions are able to be Associated Dimensions. Since ALL Wall Dimensions do NOT  Associate, one may need to fix dimensions, ANYWAY, as you have noted - See Attached
    VW HELP = "...links dimensions to 2D objects, as well as walls and wall components. "
    Dimensions in the Design Layer are able to show up  in a Viewport. This is determined by your Class set up - Viewport Crop etcetera.  Dimensions as annotations in a viewport appear to be an easy solution, especially if dimensions are distinct Viewport to Viewport.
    Associated Dimensions and Layer Plane 2D geometry may be a solution for this automatic mode you desire. It may end up being a bit of a work-around... ie: multiple sets of geometry if you are working (assumed ...) in the real 3D World)
          Typically, VectorWorks idea of automatic mode  is a double edge sword (ARGH!)
    Keep in mind that Sheet Layers are Screen Plane ONLY - Viewports (annotations) are Screen Plane ONLY
    https://www.youtube.com/watch?v=W2SJ-ftuNvY
    Peter
  7. @MikaelSteff - @Tom W. Just suggesting ...
    We gave up on getting this Default 3D... to work as expected - As mentioned above  - On again / off again  aggravating frustration.
    Not saying it is the solution to the problem, just a warning that you may be doing things right and VW is not
    Peter
    Post a file to let others take a look ...
  8. 3 hours ago, Tom W. said:
    Also check your 'Default 3D View Render Mode' setting in the '3D' tab, VW Preferences.
    @Tom W. This is good to mention, except we have had on to many again / off again issues with these Default 3D View Render Mode settings and have "given up" on understanding their behavior. Possibly, this is what is doing the "suddenly turn see through " for  @MikaelSteff
    We have shifted to Keyboard Commands For Wireframe / Open GL  (Shaded)
    Peter
  9. @zoomer have you ever had useable results with Photo to File in the VW Cloud ?
    Recently ran three tests and was very disappointed
    Want to have the process simple / low tech.
    Photographed an object
    Used a regular iPhone
    Photos taken indoors
    1st run failed (insufficient overlap)
    2nd (More overlapping photos this time) resulted in a file that was incomplete
    3rd (Better / New photos / More photos / even more overlap) (background stripped away on the iPhone) this also resulted in a file that was incomplete -
         see attached with Results: File imported is on the Left and One example photo is on the right
    The traditional manual mode ,to create 3D geometry from photos, is combination of photographs, details and manipulation. First with the iPhone  (PHOTOs App) - some work in GraphicConverter (or PHOTOSHOP) as needed  & then VW - Simple / Easy / Predictable (a 2D PDF is also a good asset)
    ¿ Anyone succeed at this ? - Would love to see some real world examples of objects (ie: Not landscape or buildings) that used the VW Cloud Photos to 3D File
    Peter
    OBJ Import Before and After_1.pdf
  10. ...and when searching VW HELP - do it from a browser also.
         Type what you think you want to find here  site:app-help.vectorworks.net/2023/
    or for VW 2021 - site:app-help.vectorworks.net/2021/
           or for that mater change the last number to match your VW year
    Follow @zoomer advice on different keywords above - Even if you type in exacty what the Menu item or Tool is.
    HELP is loaded with great information - It is just not easily accessed some times.
    Example Attached:
              Page 1 - Search inside VW HELP - Drop Down appears to have a match to what was typed
              Page 2 - First hit out of 1259 (?) - Not what was requested
              Page 3 - Search with Google outside of VW HELP - Second hit looks good
              Page 4 - Google search found it - and the requested phrase was in VW HELP it just did not find it as such.
    ¿ What is the "box indicator" ?
    Peter
    Box Indicator.pdf.pdf
    • Like 2
  11. @Micaela Edwards Assume that the image you posted is Rendered ?
    See attached
    At first glance the curves rendered as segments / facets appears to be a setting in the Options for the selected Render mode.
    Extrude a Circle and it typically looks good rendered
         Put a hole in the same circle then extrude - Facets may appear in the rendered view
    Peter
     Segmented Rendering.pdf
    • Like 1
