MattLXdesign
22 -
Reputation
3 NeutralPersonal Information
Location
Sydney, Australia
Recent Profile Visitors
This is probably a very niche issue but I have recently noticed that while I have Multiple View Planes active, in the window with Shaded render mode I cannot change the Shaded Options. Specifically Textures, Colours, Anti-Aliasing, Shadows, Draw Edges. If I toggle any of those, when I hit OK everything reverts. If I turn off Multiple View Planes, I can change the Shaded options to my hearts content. Is anyone else finding this? Surely I'm not the one who likes drawing in 2D and 3D at the same time.... I'm using VW2024 on Windows 11
Lighting Accessory Alignment and Changing Device type 2022
MattLXdesign replied to Patrick Schulze's topic in Entertainment
Hi hrawls, With the accessories, there's a new section in the Object Info box for Accessories. You'll need to select the offending accessory from a drop down box there. Then in the section above is the drop down to select <none> for the label legend. The problem I'm having is copy pasting fixtures with accessories between plans for a tour I'm drawing. The object info is all filled out for the full fixture with accessory in the new plan, but only the symbol for the accessory appears on the plan???? Has anybody else has this? -
what determines a DLVP's position in the design layer
MattLXdesign replied to rexwexford's topic in General Discussion
To add to observed issues with DLVP's lining up - I regularly reference external files while drawing lighting designs. Both venue and set plans are external so I always have the most up to date version in my plan. Previously I just had to make sure the internal origin's lined up, set the user origin to the internal origin and everything works. Now with VW2021 this is no longer the case which has me pulling my hair out. Which I don't have much of. Happy to lose it if it means my DLVP's line up again. Correction - It seems my user origins are drifting when updating the file to 2021. Resetting the user origin the internal origin has fixed the problem and I get to keep some hair. -
Color gel assignment not carried to vision.
MattLXdesign replied to JakeSliv's topic in Vision and Previsualization
After some dinner and a beer I have made a discovery which I'm sharing here for anyone else finding the lack of colour information for generic fixtures transferring from Vectrworks to Vision ultimately frustrating. If you edit the fixture, either by pressing the edit button in the OIP or double click the fixture you can edit the colour wheel of that instrument. Unfortunately you can't just type the colour by gel no. but if you have 'Active Document' selected in the colour picker you will see the colour name show up when you hover the mouse over the appropriate colour. This will transfer from Vectorworks to Vision every time. I'm sure that between now and when the theatres open again I can write a script to automate that. -
I'll play around with exporting only the updated fixtures. I really only use vectorworks for producing plans for the crew to rig. Right now seems a good time to play around with visualizers, which have never really clicked with me. So I know I'm a harsh critic. Hopefully exporting updated fixtures only will prove far more workable. But I can predict that having to reassign the colour to every fixture when I send from Vectorworks to Vision will be enough to prevent me from using Vision after a couple of plans. I thought it worth leaving a comment. Everything else about is has been very easy and intuitive. -
I would like to add a plus one to Jake's request here. It seems crazy to have to manually add the colour to every generic fixture in the rig. And then to have to do it again when you make an update on your plan would be enough to convince me not to use Vision. Which is a shame because I'd really like too -
What would bring them into the same ballpark? In my example above I'm only working with ~5m throw. Just tried in a larger venue with a 19deg and ~20m throw. No problems. Work exactly as I would hope. So there must be a minimum throw distance for the "Use Vertical Beam" to work. Still sounds like a bug to me..........
That's odd because I just measured the beam angle from a fixture set to "Use Vertical Beam" which is a 50deg Source 4 and the beam measures as 119.49deg from a section view. From a top plan view the beam measures as 67.42deg with "Use Vertical Beam" toggled on AND off
I am having exactly the same problem. Using the same VW version as mjm. 2019 SP2 Build 463397
Instrument summary, typical label legend dissapeared VW19 SP1
MattLXdesign replied to Sebastiaan's question in Troubleshooting
Found a work around. Place two Typical Label Legends in the Instrument Summary. One of them will stick -
One more thing - I hadn't realised the problem only begins after refreshing the symbol summary, although that absolutely matches my experience. So I created a new instrument summary which restored the typical label legend for me. Except the scale was incorrect. Defaults to 48 rather than 25. Why does the instrument summary tool not default to the same as the active design layer? I could rant about that for hours and will to myself later. Anyway after correcting the scale the Typical Symbol has once again disappeared and this time will not reappear when creating a new instrument summary. Why am I paying so much for yearly upgrades when they do not work?? -
Also happening to me. This is extremely frustrating!!!
