CreativeJuncture
    5
Everything posted by CreativeJuncture
  1. Thanks for confirming that. I should be making the move to 2011 shortly, just waiting for some stars to align properly.
  2. Thanks for you help, once again. The formula you've listed above helps me understand the worksheet syntax a bit better. However, I can't seem to get it to work for me. I guess I should mention I'm currently using 2008, in case this is a function that doesn't work in my version. I tried simplifying it, ie remove the text, so that the hopeful result would be "2600 3000" just to see if I could get that working right but was not successful. I used =CONCAT(WIDTH(C='Carpet'),' ',HEIGHT(C='Carpet')) since the item I'm trying to get these values for is currently the only item on this class I know I'm almost there, but apparently some small hangup is holding me back.
  3. It seems like VWX would have this capability but maybe not since many hours of searching here and reading VWX Help have been unfruitful. Basically, I want a to display text in a single worksheet cell that also contains a number of values derived from formulas. I want it to display something like: Dimensions ( 2600mm x 3000mm) The numbers in Red are values that I would like to be derived using the WIDTH and HEIGHT formulas of a single object (can be a symbol, or just an object on a specific class). is it possible to have simple text and formulas in the same cell or am I dreaming?
  4. I'm working with the original poster, lineweight, on this project & really appreciate your help. Based on the examples you've provided I've almost got a system set up how we need it. My remaining question is on RetailFixtures-2 file how did you get the Fixtures Report worksheet to only list each fixture (of which there all multiples) only once. I compare the Database Worksheet, that lists each one separately, vs. the Fixtures Worksheet and can't tell where the difference is in the worksheet setup. The setup for each looks the same, but the result is clearly different. How'd you get it to list each fixture/symbol type only once on the Fixture Report worksheet? Thanks
