I just brought a 2009 file into VW2010. I had already placed the plant symbols (with their associated tags) in the 2009 version of the file.
While In VW2010, I noticed that some of the plant symbols were on the wrong class ('L-Text' instead of 'L-Planting') so I changed them to the 'L-Planting' class.
This switch appears to have made the Plant tag lose its graphic attributes. The plant tag uses its own class called 'L-PlantTags' which I set up in the plant tag class in the default prefs in the 'edit definition' of plant symbol preferences palette)
The 2010 Object Info palette shows that the plant tag is still using 'L-PlantTags', and the graphic attributes for the class 'L-Plant tags' shows a solid line weight of 2 and no fill, which is what I want it to be. The Object Info is also showing that the Tag Bubble is set at 'Circle', also as I want. All the settings appear to be correct, but I do not see a plant bubble at all now that I have switched the plant's class. I still see the tag leader, shoulder as well as the text that the bubble would surround.
Any suggestions?
