654 -
Everything posted by Patrick Fritsch
VW needs to have a setting in VW Preferences so that when I import anything, let's say a "Material", I am able to have mapped that it's dependent sub-orjects like Texture and Fill will land in a preselected "Texture Folder" and "Fill Folder" as opposed to creating a new folder (in this case a zNested Folder). Because my files keep getting messy and I feel like the maid wasting a lot of time re-organizing. ....will be funny in 20 years from now for me to revisit this wish and still nothing done.
Redshift and AMD GPU support…status update please!
Patrick Fritsch replied to Patrick Fritsch's topic in Hardware
Maybe VW should just ditch their Family product Redshift for AMD Radeon ProRender....https://architosh.com/2021/11/amd-supports-hip-based-rendering-for-blender-3-0/ Using GPU & CPU to it's max! Many plug-ins available already here https://www.amd.com/en/technologies/radeon-prorender ....but not for VW unfortunately More AMD ProRender info here: https://www.amd.com/en/technologies/radeon-prorender I'm fine to use Redshift...but you gotta make it work with AMD on PC -
@Matt HagenGotta run get my Daughter...but pretty sure your problem is that there are stray items floating off in layer space, super far from the origin. That always causes problem. turn on all layers and classes, do "select all" from the edit menu and then zoom to selected items and you'll see how far out things are spread. Just unselect the required model geometry and delete, should do it for you.
Is it something like this problem with Redshift?
To expand on this request I am finding that the New Materials vs using Component Classes (as previous VW method) there are some limitations in "Materials" visual control in Viewports on a per item basis. Example, I often need to show multiple Exterior Cladding Schemes to clients, With the classes method I need to have several wall style for each cladding type and then override the viewport Class to do iterations. Now with Material, I still need to create several wall types using a specific cladding Material for each but my options now to control iterations in Viewports is to either; Use the new Data Visualization feature to override each specific Material, OR Link each Materials Fill and Texture to a Component Class...but this would just end up as previous VW method (and would be incredibly long to re-setup all the Materials already provided in the Library) What is odd to me is that with the new Materials method, I am saving on adding classes but I now have Many Materials to manage. If Material will have further implementation uses then it makes sense but not currently IMO. One thing that materials need is the ability to be used in Section Details in Viewport Annotations, as you can see in the attached screenshot we need to be able to select which Material Part we want to use (Fill, Texture or Hatch) AND we must be able to control the selected parts Scale/Rotation/offset(alignment). With such a system then we could use the same Materials at deferent scales in Layers AND Viewports.
Title bloc manager will not update Sheet Style
Patrick Fritsch replied to Patrick Fritsch's question in Troubleshooting
Wish submitted here -
When I want to switch the TBB Style in the OIP the Sheet Layer page size should be synced automatically. Since the Sheet size is already set in the TBB Symbol Style edit dialog box, it seams redundant to have to set this twice! Currently, Visually the sheet will not be resized until you edit the page setup in the "Sheet Layer" so I would just be shifting the setup work elsewhere and not automating. What I think needs to be done is flip it! Add a "fit to TBB Style sheet size" option in the "Sheet Layer" page setup options so that everything is controlled by the "TBB Sheet Style". I think this is a legacy quirk as "TBB Sheet Styles" are fairly recent. See further discussion in forum here:
@Nikolay ZhelyazkovExactly! This way when I want to switch the TBB Style in the OIP the Sheet Layer page size is synced. Since the Sheet size is already set in the TBB Symbol Style edit dialog box, it seams redundant to have to set this twice! -
@Nikolay ZhelyazkovNot quite, as Visually the sheet will not be resized until you edit the page setup in the "Sheet Layer" so I would just be shifting the setup work elsewhere and not automating. What I think need to be done is flip it! Add a "fit to page" option in the "Sheet Layer" page setup options so that everything is controlled by the "Sheet Style". I think this is a legacy quirk as "Sheet Styles" are fairly recent. -
VW 2022 Viewport artifact bug when Sheet DPI at 300
@Rob NykolaishenNo I am on Win 10 Pro, just updated my old signature...I guess we could blame my GPU as it's 12 years old now....so it could be system based maybe. New computer arrives next week so i'll know for sure then. Thank you -
@Pat Stanfordif the VP's are set to 300 DPI and their fine, might be just a Bug for PC?. My GPU is up to date but an old EVGA GeForce GTX 570, I have a bunch of new computer parts in the mail. I submitted link to this post as a Bug so maybe someone at VW will be able to check it out... Thanks for trying to help out Pat...again! -
There appears to be a replicable bug with Materials, if you take any Library Materials and change the Texture and Fill to be "by class" the Materails updates correctly. But if you go back and try to specify the Texture and Fill only the Texture can be changed back to it's initial state...Material's Fill remains sticky...I have attached a sample file and I have replicated on blank test file. come on V Dev's Materials sticky FILL.vwx
@Pat Stanford The 3 Isometric VP on Sheet A0.1 -
Ability to import stories and story layers.
Patrick Fritsch replied to Dieter @ DWorks's question in Wishlist - Feature and Content Requests
Found it -
@zoomergot a link where I can find it? Would like to give it a try. -
Many good requests, with a 2012 Vintage! Import Stories and Levels from one project to another seems reasonable….if l have already setup a split level on another project, I should not have to copy it manually to a new project just because my template file is setup differently! -
@Pat StanfordI just checked and they were at Low (Shaded render mode). Artifacts still present if I change to High or Very High. I have attached the file.VW BIM TEST walls slabs layers stories.zip -
Patrick Fritsch posted a question in Troubleshooting
I just ran into this on a test file, I simply changed the DPi of my Sheet from 72 to 300 and the viewport update renders artifacts. I repeated the process and same. But if I go down to 100 DPI it's ok, at 200 DPI the artifacts come back. Let me know if this is a known Bug. Thanks -
I am using a wall style for modeling my stepped footings, but when I draw the Foundation walls (both on separate layers) I cannot seam to be able to use the "Fit Walls to Objects" command so that the foundation walls will follow my stepped footings. Is it because a Wall cannot follow another wall with this command? I setup the top the same way (Relative to wall) and it works to follow slabs.... Considering the age of this post, if we are to never get proper DEDICATED foundation BIM tools, I think this functionality should be added to the "Fit Walls to objects" command. @mike m ozany insight here you sem to mention above that you are able to fit walls command to stepped footings walls? Thanks
Why is it that we can organize a Key Note legend into multiple columns (see attached) but not a standard text box. Would be very handy for organizing my general notes page. Wow this one comes back to haunt as I'm updating my template with VW 2022...
Energos - Effective or Nominal U-value calculation?
Patrick Fritsch replied to Patrick Fritsch's topic in Energos
Crickets for a long time! Coming back to this... I have 2 questions regarding the Energos module as there is limited information in the VW help files. Has the Energos module been abandoned as there has been no improvements since it’s 2016 release I believe? Is the Energos Module tested with ANSI/ASHRAE 140 "Evaluation of Building Energy Analysis Computer Programs". All Canadian and most American bldg. codes require energy simulation programs to be certified this way to be admissible for code compliance simulations. The PHPP is certified with ASHRAE 140 therefore can be used for energy modeling as per building code requirements. It would be nice if VW’s Energos was able to explain how accurate or not it is when giving us a pass/fail mark when selecting the Passivhaus Standard as a compliance check (eg: shading devices missing, etc). VW Energos team should do some collaboration with the International Passivehaus Institute to certify the calculation methods as the creator for the designPH SketchUp creators did https://shop.passivehouse.com/en/products/designph-2-116/ Finally here is a 3 part post on the comparison between Energos and SketchUps DesignPH tools by an Architect an Certified Passive House designer: https://www.markstephensarchitects.com/vectorworks-energos-review-passivhaus-passive-house-design-pt3/ -
Yup!, the future of VW Redshift rendering crap on Macs...despite VW proclaiming at the Summit that VW 2022 performs great on M1, I'm assuming they are talking strictly about 3D Modeling and/or CPU efficiencies. Mr. VW if your reading this, please invest in PC and AMD development at risk of upsetting a BIG user base! -
@trashcanyou can check out Redshift benchmarks here https://www.cgdirector.com/redshift-benchmark-results/ -
Nice the script is also updating the drawing stamp settings from the Title Bloc Style!
