257 -
Everything posted by MaltbyDesign
Easy way to show walls with black fill for 2D sheets?
MaltbyDesign replied to MaltbyDesign's topic in Architecture
Thanks very much, Jeff! -
Sadly, I can't find a tutorial by this name. Are you able to share a link? -
Thanks for that, Jeff. I'll go have a look at that. This seems to be a really logical way to control visualization for phasing. -
That looks interesting but what I don't understand is how you apply the existing, new and demo characteristics to the wall. I see in the Properties Data tab you have the three phases in a drop down. How do I do this with my own wall types? Is there a tutorial on this that you could direct me to? I'm using VW2022. -
No. And I can't see where to change my signature. This came up before and I checked my profile settings but don't see it anywhere. Used to see it under my name but something appears to have changed with how the forum is set up. -
Thanks for this. Where can I find out how to implement Data Visualization? That sound like what I need; a way to easily differentiate between existing, new and demo. -
When I model walls, I like to create wall types made up of components which can be seen on plan but for some presentations it's nice to show walls as solid black. I thought there was an easy way to do this but I can't seem to find it. Any tips or directions to a tutorial that explains how this can be done? Thanks in advance.
Where are the Imperial Paper Sizes in Page Setup?
I can! So that took me on a hunt to change units on the computer itself which is exactly what was causing the problem. Thanks for your help, Pat. -
I set up for 'Any Printer' so I don't think printer drivers come into it. However, the printers I do use are set up for imperial sizes. Not sure why I can select from both imperial and metric sizes on my iMac but my MacBook Pro is only showing metric paper sizes. -
I have units set to imperial and when I go into File>Page Setup>Printer Setup only Metric paper sizes are given as an option in the selection tab. Okay, so go into Manage Custom Sizes and hit + to add a new sheet size but only metric shows as a size option. I don't have this problem on my iMac in my home studio, just on this new work laptop. I can't figure out any other location where I can change units other than File>Document Settings>Units. What am I missing?
Cabinets not rendering properly when 'shaded'
@Benson Shaw thanks for the suggestions. I don't think it's any of those but I'll double check. -
Cabinets appear to have portions remaining in wireframe when 'shaded' in a 3D view. Restarting VW seemed to address this. When I save a view the rendering appears as it should but when I want create a viewport of this saved view to add to a sheet, the resulting rendering is partially rendered with the doors appearing as wire frame. That is not rendering like the rest of the cabinet. Restarting VW didn't solve this. The first image show a screenshot of the saved view which renders properly while the second shows the viewport on the sheet, on which door faces aren't rendering. Any ideas how to fix this? Is this a software problem or user error? Monterary v12.2.1 MacBook Pro (14-inch, 2021) M1 Pro 32GB memory
Viewport Bounding Box is Larger than the Viewed Area
MaltbyDesign replied to MTRobin's topic in General Discussion
Thanks very much, Pat. I'll see if I can't eliminate those. It's a drawing that I inherited so am sorting out a few issues. -
Thanks Pat. The viewports on that sheet are fine. The problem is when I try to create a new viewport from a design layer. I'm using VW2022 SP3. My signature hasn't been updated in a while. -
Thanks! I'll DM the file to you. -
Select All and then Zoom>Fit to Objects was one of the first things I tried. I can't see any reason for the giant bounding box. -
Sorry to revive this topic, but I'm suddenly having this problem as well. I turned on all classes and layers to be sure there was nothing floating off in space to dictate such a huge bounding box. I created viewports the other day without having this happen but now I can't see why this is happening. -
Why does the fascia option only work on eaves and not gables?
@techdefThanks for the clarification. I'll give that a try. I was trying to get the 'fascia' wall to follow the roof but that wasn't working. -
@techdefwould you mind sharing a screenshot of your Insertion Options in the edit wall style dialogue box? I've got the wall as fascia part but can't get the wall to follow the top and bottom of the sloped roof. Thanks in advance. -
Thanks for the alternate approaches. I just wish that the built in tools worked as expected without having to find workarounds. -
I often use the Create Roof tool to quickly create shed roofs, done by converting 3 of the 4 sides to gable ends and the low side of the roof remaining an eave. Inserting a fascia will only add a fascia board to roof edges that remain an eave. Any edges of the roof that have been converted to a gable end will not receive a fascia board. This seem like the most basic of flaws in the software, particularly when trying to quickly model a design idea. Am I missing something? I don't think this should be a difficult task.
@Ben Beaumont I just wish that the whole setup was more intuitive than it is. Considering how much discussion and confusion there is around storeys, layers and levels suggests that the user experience could be made less complicated than it is.
@zoomer when I was playing around with TM, the first time I imported a model it was nowhere to be seen. Discovered that it was because I create my site model with actual elevations for the grades and import my building model which I build with the main floor at elevation zero. TM imported my model at the elevation of my site model (+760'-0"). So I ended up creating a separated model file with the site model set to zero before exporting it and that seemed to work. What I don't like is how the model edges look like cliffs when imported. Not sure what, if anything, can be done about that.
Roof Standing Seam Metal MT not scaling properly
@Tom W. Thanks very much. I was looking at that but didn't see the "Set by Image" button. I was also to edit the surface hatch as well. Thanks again. -
I'm using the standing semimetal roof material MT on my model and it appears at half the scale showing seams at 6" apart rather than 12" On walls, it looks like I can scale the spacing up in the OIC - Render tab. But where I've applied this material to a roof, I can't see any way to adjust the scale. Why doesn't the material insert at the correct scale to begin with and is there a way to adjust to the correct scale on the roof? I should note that on one of the wall, adjusting the scale won't work for some reason, despite being identical to the others that dis scale. Thanks for any thoughts on how two fix this.
