P Retondo
Content Count
1,806 -
Calendar
Everything posted by P Retondo
Matt, thanks for going to the trouble to create a graphic illustrating the specifics of the idea. To limit the operation of the override to "none" class is an interesting idea, although as DWorks points out, it's not the only way to go. But having the Viewport override settings supercede might void the usefulness of the whole idea, since Viewports on Sheet Layers are the current method of choice for many (but certainly not all) users when it comes to output - which is where the graphics count most. For me, this inheritance feature would have to be a user-controlled option, not a default or automatic thing. I don't know that this is impossible. AutoCAD programmers were able to do it, but given the structure of NNA's code it might be difficult.
Vectorworks 12.5.2 Crashes 10 times a day with NVIDIA software!
P Retondo replied to petercard's topic in General Discussion
Matt, I had similar problems a while back with 12.5.2, and had thought I had a corrupt file. I ended up removing VW and reinstalling, and the problem immediately disappeared and everything has been stable since. The signature of my problem was that when VW stalled Task Manager indicated that one processor was occupied with a VW task. -
Matt, if I understand you correctly, that would create a conflict. Of course, there is no current option to have an object "inherit" a symbol's class attributes, so I'm assuming you mean that the object's attributes are set to "use class," and you want the meaning of that to be "use the symbol's class," not the other class NNA assigned to the object. If you ask an object's attributes to be overridden by both the symbol object's class and by the class override in a Viewport (N.B., these classes are different, otherwise we wouldn't be talking about the inheritance concept), there would be no way for the program to sort out which one has priority. Or, at the very least, there would be a conflict with the desire of those users who don't want the ACAD behavior to prevail, and have set up their systems to work with the way VW currently behaves. Think about this: a line in a symbol has class "A," and is set to dash style "by class." Class A has a solid linestyle (no dash). Under your inheritance proposal, if the symbol is assigned class "B" with a short dotted line, the line would become dotted. But suppose that in your viewport you have defined a class override whereby class A is set to a long dotted line. Which dash style will the line receive? It has to be determined to be one or the other. If it automatically receives the short dash, that frustrates the desire of users to have the viewport preference apply. On the other hand, if you mean to suggest that there be a new attribute option, for a symbol member object to "inherit" its attributes from the class of the symbol container, then that might be a workable alternative to give the user a choice. It would add a button in a different location, I hasten to add, and it wouldn't give us the nuanced control to assign some attributes, but not others, the inheritance behavior. Having another setting for every attribute for every object would be too much.
Bill's right about how ACAD blocks work, and there's just no exact equivalent in VectorWorks. There are workarounds, but I think it's worth mulling over a wishlist item to NNA about coming up with something that will give more meaning and power to the class assignment given to container objects. With ACAD blocks, the attributes of some (not necessarily all) objects within a block can be overridden by assigning the block instance to a "layer" (= VW class) in the same way VW objects take on class attributes only if they have been created with the "by class" options selected. It strikes me that if there were a checkbox option on a symbol, whereby the user could choose to override member object attributes according to the class assignment of the symbol container object, that would do the job without creating a conflict with the normal way that classes can be modified in a Viewport. This would only operate on those objects and those attributes with "by class" selected. You could call this idea "optional inheritance."
Bill, you can override the class attributes of your objects in a Viewport, so you don't need to create two symbols. If you want to display the same symbol in two different ways in one drawing, you'll need 2 viewports to do that. Look at the OIP with a viewport selected. Go to the "classes" button and when the list comes up, you can edit the class attributes, and those edits will apply in that viewport only. So you can change your linestyle to dotted for that viewport, for example. Window and Door PIO's as used straight from the window and door tools can be classed and will pick up class settings and viewport overrides in the manner you are asking for. Those aren't really symbols, per se, they're a different kind of object. So if you are looking for the easiest way to have a window or door be dotted in one plan and solid in another, assign them to a Demo class like the wall, and use viewport overrides to have that class display differently in different drawings.
Peter, what is "windows XP compatibility mode?" Okay, researched that myself. I have been running without checking that option for almost a year, without experiencing problems. From what I understand, if you are in compatibility mode you may be unable to run 64 bit programs, and since some of those are part of the system, you might run into some problems. In fact, I wouldn't be surprised if this is the reason you can't run with 4 GB RAM. It's worth a try anyway, and I have an ulterior motive in getting you to try in that I'm uncertain whether to upgrade my RAM! I don't know why you are opting to use compatibility mode, but on my system the 32 bit emulator works just fine without resorting to compatibility mode. BTW, with 64 bit you could install 128 GB RAM! (assuming everything works and your buss could handle it!) -
Vectorworks 2008 seems slow. Is this memory related?
P Retondo replied to cdavis's topic in General Discussion
Pete & Ray, someone on another thread was complaining about VW crashes or stalls, and, perhaps it's just coincidence, but he had the NVIDIA 7600 video card. If you have an extra 20 minutes, you might try swapping that for an older card to see if it is part of the problem. -
Well, the logic of this is that your contained objects might have different classes and attributes, so you don't want the container object to override the differences.
Mike, do you think that this is mainly for folks who still do their printable output on Design Layers instead of Sheet Layers? I use Sheet Layers now for all output. The only use I think I have for Viewports on a design layer would be when I want to have more than one version of a detail on my Sheet Layer in a case where the detail is composed of 2d objects drawn over a Viewport.
billtheia, you don't necessarily have to convert your symbols to groups. The same process will work in both converted and unconverted symbols. Enter the symbol or group to edit the objects. Change all the objects so that they take attributes by class. BE AWARE that it is the class of these objects, not the class of the group or symbol, that will affect how they look. So if you want to have a class that controls them, set one up and ASSIGN IT TO THE OBJECTS. Assigning that class to the symbol instance will not do anything. Assigning that class to a group will also do nothing, unless you are prompted by VW about whether you want the class assigned to the group's objects and respond affirmatively. So, I would suggest that you use some special class other than "None" to control how these objects look. The biggest use of this level of control is to customize class attributes in Viewports.
Another problem with the NVIDIA GEForce 7600 video card! Peter, just for kicks, you might swap out your video card and see if that doesn't solve the problem. A couple of other users have reported problems on machines with that card. I've been running 12.5 on an x64 machine for about a year with no problem (different video card, though). x64 seems to emulate 32 bit processing just fine. I'd be curious to know what problem you had with 4 gigs of RAM, since I'm thinking about upgrading my 2 gigs. -
Blink, I would use NURBS for this project, and start by defining three or more circular NURBS curves, then use the lofting tool to create a solid, then use boolean process to carve out the middle, etc. Sample object created in two minutes or less by this process: If you want the bottom curve to be a faceted polygon, you can define a NURBS curve for that, and everything will be faired into a single shape when you loft. Or, you can subtract an extrude with faceted hollow inner face that clips the object in a manner similar to your image.
J, wow, that was a bracing exercise! No matter how hard we try, it seems there is always something (almost) obvious that escapes us.
This sounds like a memory leak to me. Pete, that was a good set of tests and observations. What is strange is that others who have been using this program with similar systems haven't reported the problem. So we need to give Katie all the information and cooperation we can to help isolate the cause. Don't lose hope! I reported a 2008 slowness issue regarding Viewports, and NNA engineers got right on it and solved the problem. -
Bruce, the best thing to do is post problems on this forum. Someone usually has the latest info about bugs, etc.
J, make sure you have selected "Constrain Tangent" in the constraints palette. To get it to work in the opposite direction, hold down the key.
Re: the screen flickering comments, I've experienced something like this as indicated above, but not to the degree some are reporting. So it seems to me that this is a complex situation that might have as much to do with the particular system as with the program itself. I would encourage everyone to post more complete system details. Mine: VW 12.5.2 and 2008; WinXP pro x64; Intel CoreDuo 3.2 Ghz; 2 GB RAM; NVIDIA quadro FX 3450/4000 w/ driver 6.14.11.6218 revit, in my mind your credibility is suspect because of the tone of your posts. I looked at the RA link, and Revit wasn't mentioned. Normally I'd just ignore comments like this, but in past posts you have shown some signs of being more serious. I've never used Revit, so I can't comment on the substance, but I have a hard time sorting out your complaint. How about giving us some specifics, such as how long you used Revit and in what context, how long you've worked with VW, and what your detailed comparison is? That would be useful. Crude language, **** or not, is uninformative.
By "blinking monitor" do you mean that the VW window header and the little icons in the upper right seem to blink multiple times when doing certain operations? That is what I am seeing, and I'm waiting to get a good fix on it before submitting a report. Because this only seems to happen with complex projects with large filesize, my theory is that there is some kind of memory management going on in the background, and that the program is loading and unloading modules & resources in order to keep total RAM down. Or it could be as simple as some function call repeatedly asking for a window redraw. In either case, this needs to be re-engineered. As users, of course, we're more-or-less in the dark about the causes. The best we can do is give very detailed information to NNA. I think Katie is a good person to describe the problem to.
STEP import/export
P Retondo replied to andy c's question in Wishlist - Feature and Content Requests
Petri, thanks! So does that mean that the VW implementation of IFC format answers this wish list item, or is IFC so limited it can't serve mechanical design needs? -
Doesn't really contradict what Katie says. But I've never really been sure what the meaning of a "lineweight," etc., would be for a container object. BTW, it's not the active class attributes that would count, it's the class to which the object is assigned (could be one and the same unless the symbol was created to be assigned to a particular class when placed). You probably knew that. This does work the way you want it to, if the objects within the symbol are created as you normally do ("use class" for everything), and then you convert the symbol to a group and change the classes of the contained objects.
STEP import/export
Andy, my impression is that STEP is not the current favored file format. It was always intended to do much more than IGES, which was mainly for geometric characteristics where STEP was intended to be a BIM-type standard. I'm not sure that enough people are on board with STEP to make it a real standard. Maybe someone who knows more than I do about STEP vs. IFC could comment. -
Stupid Question: Where is the 3d Section Cut tool in 12.5.2(71051)
P Retondo replied to jwlyon1's topic in General Discussion
jw, not sure what you mean. I had to add the Cut 2D Section and Cut 3D Section commands by editing the workspace. -
Three, the symbol is a container object. The container object's attributes are not shared by the objects it contains. Same with groups.
You can try converting your plane to a NURBS surface, then create a NURBS "box" by converting an extrusion at your boundary to NURBS surfaces. Then use the Connect/Combine tool to extend the plane to the boundary surfaces. This is a bit fussy, and sometimes doesn't succeed. The DTM method can take more time, but is more certain to give good results.
