P Retondo
Content Count
1,801 -
Calendar
Everything posted by P Retondo
Wall recess: wall hatch showing when window/door inserted
P Retondo replied to Christiaan's topic in Architecture
Gosh, guys. -
Christiaan, have you tried setting the recess cut line to a height within the recess (should be in the OIP)? Normally, you have to adjust that height to get the recess to show as a cut in the wall. -
Door Tool - Exterior Door Swing Out?
P Retondo replied to Bruce Kieffer's topic in General Discussion
Bruce, I'm not sure I understand your question, so this may not be the answer you're looking for - all doors swings can be put into the 4 potential configurations using the "Flip" button in the OIP. -
Will, your post is a little confusing. You say you already have hybrid (i.e., 2d/3d)auto symbols, but then you want to add 2d to them? To convert a hybrid to 2d only, just save a duplicate of the symbol and delete the 3d content.
Mike, awesome! Just to be clear, MH, Mike means when you have double-clicked on the symbol and it shows up rotated in its edit space, you use a command to activate the Top/Plan view, and the symbol will rotate to it's normal orientation. Mike, it looks from the behavior of the screen as though VW is actually accomplishing this through the "rotate view" algorithm. The beauty is that you can still see other objects in normal edit space to work on the symbol in context.
MH, this is a feature. It allows you to edit the symbol in context when you've toggled show other objects in edit mode. To get around it, you can also duplicate the symbol, set rotation to zero, and double-click.
Can the selection tool work like in AutoCAD
P Retondo replied to Dunconius's topic in General Discussion
With the selection tool enabled, push "J" and click to get coincident objects, which are displayed in a window. For overlapping or closely bunched objects - vw tells you there are coincident objects with a little "*" cue. -
Jonathan's got the answer. Make sure every point you want to move is in the multiple-reshape marquee. I often use the "tab" to bring up the floating data bar (you may have different settings for data bar visibility), tab again to go to the "L" field, enter the distance you want, press "Enter", then hold shift to constrain to the direction you want to move.
No problems resembling that here.
Good point, DWorks! I don't see why the code couldn't be written to do this.
Go for the 3.2 GHz, mate. 8GB RAM might be more than VW can use at present, plus you can always add RAM later. Are you really using vw2011? Major improvements in viewport update speed since then.
I don't think so, but I'll do a test and let you know. Okay, exported from a sheet layer using the setting you indicated for viewports, no problem - no crash, .dwg file looked okay. My target was AutoCAD 2000i, if that is a difference. [img:left]http://www.retondoarch.com/ConstDocs/VW%20files/Export%20dwg.pdf[/img]
Reference the external file layers in separate viewports in separate DL layers. Then you can create Sheet Layer viewports that selectively show any combination of layers from the external files, and manipulate class visibility and graphic overrides layer per layer. Duplicate viewports in DLs in order to show the same external layer differently in different Sheet Layer viewports. Not too difficult or time consuming to do. Once you set up one reference viewport in a Design Layer, duplicate the layer and change the layers visible in the new viewport, etc. Name layers in such a way as to track the content.
If you're working in 3d, in order of importance, processor speed (multi-core good for Renderworks), video card (speed and cache size), min 2GB RAM, 4 better.
Peter, odd behavior, for sure. What I do is go to the resource browser, or simply go to Top/Plan view (Ctrl+5) and edit the 2d by double-clicking, or go to Plan view (5) and edit the 3d by double-clicking.
Vincent and Jim, hate to spoil your bad mood, but I do import and export .dwg several times a week, and I've never experienced the problem you are having. Maybe there is something about your setup or preferences?
Grant, why do we want cadfaster?
Dashed lines scale weirdly in viewports
P Retondo replied to P Retondo's topic in General Discussion
After talking to tech support and trying out their suggested solution, it looks like this problem of a corrupted linestyle reference is due to faulty conversion from v2012 to v2013. After reconstructing all references, the problem has gone away. -
New line types not showing when referenced
P Retondo replied to I will I's topic in General Discussion
If your files with references were updated from an earlier version, try reconstructing the references. -
Dubman, never had this problem. That's not much help to you, but at least it tells you the problem can be conquered once you figure out what's going on.
Miles, smooth sailing here, same version of VW and OS. Once in a while I get a crash when I inadvertently push wrong or multiple keys.
Does anyone else have this problem? Design layer viewports show dashed lines incorrectly, compared to the linestyles in the referenced file. Some are too short, some are too long, some are just right. I don't see what could be causing this. "Scale with line thickness" has no effect on the problem. Importing the linestyle into the target file has no effect.
I use Vincent's class assignment approach. I also have a class called "Overlay" which allows me to dot in clerestories ("Convert copy to lines" performed on the window to get the objects) when we don't want to show a cut in the wall.
Mike, if you mean that you're using "thumbnails" to display resources, and the triangle that hides/displays items under each category bounces back to an undesired setting everytime you boot VW, that's a long-term behavior. I wish it would get fixed.
Don't recommend 2013 SP2 if you use WGRing
P Retondo replied to Christiaan's topic in General Discussion
I just noticed some weirdness with WGR in 2013 SP1, in a set of files migrated from 2012. Updating an existing reference resulted in a whole series of naming conflicts. The conflicts were between resources in the target document ("Plan") and the same names that existed in the referenced document ("Kitchen") as "groups." Why there are hidden names of groups I don't know. I aborted the update, which did not cause a crash, and cured the problem by: 1) deleted the reference to "Kitchen" in "Plan"; 2) deleted the circular reference in "Kitchen" that showed the floor plan layer from "Plan"; 3) recreated the reference to "Kitchen" in "Plan," no problem experienced; 4) recreated reference to "Plan" in "Kitchen." So far, no problem with all that, and no naming conflicts.
