P Retondo
  • Content Count
    1,792
Posts posted by P Retondo
  1. Must be a 2016 thing. In all previous versions, a dialog box comes up when creating a symbol with a check box asking if you want to change all layer plane objects to screen plane.
    For those who aren't aware, the original VW (MiniCAD) and in versions of VW up through a few years ago, there was no "screen plane" / "layer plane" dichotomy. In fact, every 2d object was what we now call a "screen plane" object, and anyone who has the experience indicated by some signatures on this thread has long experience with using screen plane objects, even if they didn't know that's what they were! This was historically a big difference between VW and AutoCAD, where all 2d objects were actually 3d - basically, what we call "layer plane" in VW.
    I use virtually nothing but screen plane objects, even though I do a ton of work in 3d. I find it incredibly useful - think of it as a layer of trace on your screen, where you can draw and think in 2d with respect to the view on the screen. I actually think it was a mistake to embark on this "layer plane" notion, instead of enhancing the 3d objects we already had. But this is the VW we have - it would help if certain operations did not inadvertently toggle the preference for screen vs. layer plane. Every time I edit a sheet layer viewport crop, my "screen plane only" option switches to "working plane only," and I have to switch it back (this is 2015). Hopefully this bug is fixed in 2016, I'm just starting to use the new version. For anyone who doesn't know, you can choose "screen plane only", "working plane only," or "screen plane or working plane" in VW preferences / plane mode tab.
    PS: if you want to make sure moving a 3d object in a 3d view does not change location with respect to the screen normal axis, just draw a screen plane rectangle between the points you want, set it to the side, and between the corners of the rectangle. Just one of many useful screen plane object tricks.
  2. Jonathan, try it, and you'll find that it can't be done if you are given the two arcs and a starting tangent point for the fillet arc. That's because you don't know where the second tangent point is. (Take a look at the two drawings for which I supplied links - one for a desired radius but no starting point requirement - the case you've illustrated - and the second for a desired starting point where radius has to be determined.) I'm pretty sure the only way to do the second as things currently stand is to calculate the fillet radius with a formula, but if there is another way I'd love to know it!
    The situation seems ripe for a tool to be developed. There are two cases: 1) the "snowman" case we've been talking about, and for which I've posted the formula, and 2) the "S" case where your fillet curve can be concave or convex depending on the starting point. 2) can also be calculated, but I haven't done the work yet for that.
    (BTW, I haven't been able to figure out how to attach an illustration directly to a post - how do you do that??)
  3. You can construct a fillet of given radius using basic geometry. Tangent arcs have the property that the two arc centers and point of tangency are co-linear. Thus, using the centers of the two arcs you wish to join, construct arcs that are the sum of the radius + fillet radius. Their intersection is the center of your fillet arc.
    0B2Nv6O2xIh9xT3F6XzhiQkoyenM?ths=true
    If you have a given point of tangency and not a given fillet radius, your problem is a bit more complex. Trig is required.
  4. This may not be the case for you, but I use a template where the drawing labels are in a "nonprint" class, which I change to "none" when the labels are needed. Sometimes if that class is turned off I forget the labels are there. Auto-numbering, however, does not forget they are there. Having said that, from the specifics provided it does seem like you are experiencing some kind of file corruption.
  5. The only way I've been able to do this is to create a texture from the image, framed with solid boundaries, then apply it to a NURBS surface and tweak the scale and offsets. It seems like there should be an easier way, but I don't know what it is. Applying an image to a "2D object on the 3D plane" (whatever that actually means) is possible, but that would have to be based on a 2D primitive, such as a rectangle, circle, etc. I would love to know a better way to accomplish what you are talking about.
    BTW, you can convert your cylinder to a group of NURBS surfaces with a simple command, then you can isolate which surface the texture applies to.
  6. Jim, after looking into it I can see that Python, though not directly compilable, is a programming language, not a macro language. This helps me adjust my approach to following the online demos - I need to stop thinking in C++.
    Speaking of which, I asked the question, "how do we know the type of an argument" based on my knowledge of C, where variables are declared with a type, such as "Int". Now I understand that variables in Python are not declared with a type - or at least that appears to be the case from a very cursory look at things. I guess I'll figure out along the way how that works. In C, if you reference the wrong variable type when calling a function, that results in a compiler error that is explicitly called out. Not sure what happens when you plug in a real number in a Python / Marionette function that needs an integer.
  7. rDesign, this is a bug that occurs whenever you edit a crop in a viewport. You have to toggle the preference back to "Screen plane only" whenever you edit a crop. Already reported as a bug, and there may be other operations that cause this.
    Alan, I've been doing 3d in VW for 25 years, and I NEVER use layer plane objects. Never saw the need for them, given that we can create 3d polys that are much more versatile, except for not being able to show 2d graphical qualities. I can't foresee ever needing that. Screen objects are much more useful, given that they are aligned to the screen regardless of your point of view, and as I've pointed out before, screen plane 2d objects are part of the original unique genius of VW when it was MiniCAD.
  8. Mike, awesome! Just to be clear, MH, Mike means when you have double-clicked on the symbol and it shows up rotated in its edit space, you use a command to activate the Top/Plan view, and the symbol will rotate to it's normal orientation. Mike, it looks from the behavior of the screen as though VW is actually accomplishing this through the "rotate view" algorithm. The beauty is that you can still see other objects in normal edit space to work on the symbol in context.
  9. Jonathan's got the answer. Make sure every point you want to move is in the multiple-reshape marquee. I often use the "tab" to bring up the floating data bar (you may have different settings for data bar visibility), tab again to go to the "L" field, enter the distance you want, press "Enter", then hold shift to constrain to the direction you want to move.
