Linsey
  • Content Count
    4
Community Reputation
0 Neutral
About Linsey
  • Rank
    Greenhorn
Personal Information
  • Occupation
    Garden Designer
  • Homepage
    www.linseysgardens.com
  • Location
    UK
Recent Profile Visitors
  1. Hi - yes, I do have it. I've tried uploading it, but it failed. Is there another way I can send it to you? Linsey
  2. Hi Tamsin I did re-set the origin to 0, 0, 0. Not sure if this is the same thing. I also did fit to objects and couldn't find anything far away. I'm guessing maybe there was something hiding underneath my extrudes/walls/etc? The only way I got it to work was to copy it to a blank file and not make the hidden classes visible when prompted.
  3. I have got a problem with rendering a model. There are diagonal lines all over the walls and extrudes when I select 'draw edges' in OpenGL and as I rotate the model little triangles appear all around the windows and various other parts of the model - extrudes, walls, etc. I have installed the latest service pack, re-started, etc. None of my other models are behaving like this and I really need to fix it. All suggestions gratefully received. There are a couple of files attached illustrating my problem. Cherry Tree Cottage - Model - 2.pdf Cherry Tree Cottage - Model.pdf
  4. I have got this problem with a model. There are diagonal lines all over the walls and extrudes when I select 'draw edges' in OpenGL and as I rotate the model little triangles appear all around the windows and various other parts of the model - extrudes, walls, etc. I have installed the latest service pack, re-started, etc. None of my other models are behaving like this and I really need to fix it. All suggestions gratefully received.
