Kreativ architects
    9
Reputation
0 Neutral
Personal Information
  • Occupation
    Chartered architect
  • Homepage
    www.kreativarchitects.co.uk
  • Location
    England, UK
Recent Profile Visitors
  1. Now that the release of OS 10.8 (Mountain Lion) is imminent has there been any advance on whether VWA 2012 SP4 is compatible or not?
  2. It has been over a Month now since I ordered and received an upgrade to 2012 from my reseller / dealer here in the UK. I have however not received any further information / registration details etc regarding the VSS paid for. Can somebody please update me regarding what the delay is and how soon it can be rectified.
  3. I have a VWA model that was originally created in 2009 but upgraded to 2011. The roofs were however created in 2011. However, the connecting roof faces doesn't appear to work. Does 'connect faces' work with roofs or do they have to be deconstructed to 'faces'? Is the fact that the original model is 2009 complicate things? I've carried out the instructions as per the book and YouTube video but there is no red highlight as for other similar actions. Any ideas?
  4. Russ, Looks useful, except for the fact it's a "windows" programme!
  5. Miguel, Thanks, it's the units I am concerned about. I don't want to have to convert from USA 'metric' to a European metric resulting from, say, the use of "kN" instead of "N", "g" instead of "Kg" or "m" instead of "mm" unexpectedly in the middle of formulae! It's the same theory but could be very different results! For example fuel consumption worked out as "kilometres per litre" and "litres per 100 kilometres" and "metres per litre" give different answers!
  6. It may not provide a full structural analysis but it does provide the max. bending moment, max. deflection and other required solutions for a range of 'standard' loading conditions for a range of simple structural beam sections. That is all that is required to size a beam in a simple structural situation. All I need to know is whether the underlying calculations used by the plugin comply with the methods and codes of practice set out by the various BSI / Eurocode standards. The information provided to me by the plugin is useless if the methods of calculation and formulae do not meet those standards. Once I am certain that the calculations used are appropriate I can then determine whether the results of the calculations are within the limits and factors of safety required using 'safe load tables' etc. I have been carrying out these calculations for small projects with a pencil and calculator for many years, one of the advantages of having studied architecture at Bath University here in the UK! I am fully aware that I'll still need to work out the loadings manually, but that is not very difficult for small simple projects. For more complex and larger projects a qualified chartered structural engineer is of course commissioned as part of the design team. Regards,
  7. Having not had a useful response to my earlier posting I am having another go. Some helpful advice would be much appreciated. It doesn't appear to be possible to determine whether the simple beam calculator works to the appropriate Eurocode (or BSI standards) for structural design. Perhaps it is part of the localisation features? The problem with the VW plugin is that I don't seem to be able to access the 'defaults' to check against the BS and Eurocode: that seems to be restricted to the 'mechanical' variety of VW. Can anyone enlighten me please? It will save hours of time / structural engineer's fees if the results / solutions of calculations are acceptable to the authorities here in the UK. It would also be useful to know whether the 'electrical' calculators are useable here too! Thanks,
  8. BCD, I note your comments about not replacing structural design with a plugin. However, at the domestic level with simple beams I would have no hesitation. Having studied at a school of architecture with a large part of the course devoted to engineering design (both structural and services) I have, for the last 30 years, dealt with the simple stuff myself as a chartered architect: beams, lintels, drainage layouts (single building and at estate level), road design etc. I think it important as an architect to be able to carry out all aspects of the design on small buildings and that includes all the latest eco / sustainable aspects too. Consequently I have a very good understanding of what the specialist designers (and contractors) are up to on larger projects and on site. The problem with the VW plugin is that I don't seem to be able to access the 'defaults' to check against the BS and Eurocode: that seems to be restricted to the 'mechanical' variety of VW. Hence my earlier posting. Regards, John Kellett
  9. It doesn't appear to be possible to determine whether the simple beam calculator works to the appropriate Eurocode (or BSI standards) for structural design. Perhaps it is part of the localisation features? Can anyone enlighten me please? It will save hours of time / structural engineer's fees if the results / solutions of calculations are acceptable to the authorities here in the UK. It would also be useful to know whether the 'electrical' calculators are useable here too! Regards,
