has anyone had any trouble with their lighting accessories not moving correctly when moving the instruments they are attached to? i.e. when moving a Source 4 36deg with an iris, i will move Source4 with the "Ctrl M" Move Command - the instrument moves in the correct way but the iris seemingly jumps to a different location - i manually move it back into the center of the Source4 but will repeat the issue when i move the instrument again - in the Accessory's Object Properties it is correctly assigned as a static accessory and the position and unit corresponds to the unit it is associated with - any ideas?
