Biscontin
68 -
Everything posted by Biscontin
Stacked-dimensions Offset not working wit Note
Biscontin replied to Biscontin's question in Troubleshooting
This is still an issue with VW 2022, see video. The added NOTE on dual-stack dimensions is not aligned! Any suggestion (aside from adding a TXT manually below the dimension)! Screen Recording 2024-01-30 at 10.46.09.mov -
Hello there 🙂 Is there a way to show automatically the full tab/window of coordinates (L, A, X, Y) when moving a point from a G datum point WITHOUT hitting Tab-key several times? See video... Thanks. Screen Recording 2024-01-30 at 10.39.57.mov
I am having a big issue with imported Pdfs. I am dragging-dropping 1 page pdf (400k, very light, few lines, no texts). Every time a do zoom or I try to pan the page and even doing a simple line... it freezes (spinning wheel) for 5-6 sec. Impossible to work on it. I tried to turn off Snap To Geometry, nothing changed. I am running VW on a Mac Studio with 64Gb ram memory... The odd thing is that at the beginning (when VW was installed for the first time on the fresh Mac Studio), this did not happened, everything was fast and smooth. Perhaps is there a VW cache memory or something that is clogging VW? Thanks.
Hi, is it possible to customize the opacity (or the color) of the GRAY visibility applied to layers/classes?
I had a viewport, all was great! Now I have moved the "original" drawings and the viewport is not blank... how do I move the viewport over the new drawing location?
I have a jpg "cropped" within a rectangle... is it possible to rotate just the jpg and keep the "cropping rectangle" fixed?
Hi, is there a way to use CLIP command and select an existing "marquee" instead of creating a new one? I need to clip along a "curve" line. Thanks.
Hi and thanks for your reply. I am trying your alternative method. The issue is this: I cannot position it on the sheet layer... I don't see the viewport. It is either the viewport or the sheet layer. I don't know how to view both.
Hi, I am trying to display a viewport into a layer with a different scale compare to the layer where it is display. I am trying to print then a PDF showing both viewport (scale 1:50) and layer scale 1:100). I created the viewport, cropped it too... but I am not able to show the other layer, I can only see the viewport. Attached is what I am trying to achieve. Please help 🙂
I am trying to print a PDF of a page that shows both 2D lines and a 3D details... similar to the example attached. Basically a window/mask that shows a 3D isometric view of an 3D element draw within the same file... Is it possible? Thanks 🙂 Screen Shot 2021-05-12 at 18.18.14.pdf
@E|FA Right... in 2D I guess it is not possible.
@tom W. this is good, it works... thanks! I did as you said and I see the VW error on the witness lines. Could you just guide me how to "stacked a wireframe viewport on top of a hidden line one"? Thanks thanks.
Hi, Do you mean here? See screen-shot. I tried to all options, nothing worked. It always extend the dimensions perpendicular to the 2 points. Screen Shot 2021-05-10 at 14.34.21.pdf
Hello, In a 2D drawing, is it possible to set the "Unconstrained Linear Dimension" at a specific angle/degree? It looks like the default is + / - 45°. Check my video and see what I am trying to do. The final "123" dimension is a copy/paste of what I am trying to get. Thanks. Screen Recording 2021-05-10 at 10.44.37.mov
YES! This is great and it is what I needed, thanks @Benson Shaw
CLIP tool does not cut-off the line, it always create a close rectangle. I tried 😞
Split tools not good, for now TRIM alone is working almost as I needed. I hoped there was a TRIM ALL command that trims all selected objects.
Helpful, but still I have to select the parts that have been trimmed... if I have a complex trim with many trimmed lines it would be hard to select them. Is there a way to remove also the trimmed parts? Thanks!
Please check video attached. I am trying to cut/trim multiple rectangles that extend over a line ... but I need to do it in one click, not rectangle by rectangle as I am doing in the video. Is it possible? Seams easy to do... but... Thanks. Screen Recording 2021-05-07 at 12.28.51.mov
Unfortunately does not work... see video. I quit/restarted VW, nothing... not working. Screen Recording 2020-07-17 at 14.53.17.mov
"But there is a VW setting that will allow you to change to lossy JPEG format, to save file size. But that will be the standard for all images." yes, please tell me where to change this... thanks!
Is it possible to paste an image (let say I open a Jpeg in Mac Preview, select an area of the image, Ctrl+C to save it in the clipboard) in JPEG and not in PNG? When I Ctrl+V the clipboard VW paste in always in PNG format...
Too bad 😞 -
See video. Basically, when I copy and paste some text from other sources (a pdf or internet browsers etc) into a VW text string, the font style does not match the VW font style... which is ok. I wish there was an option for a paste-and-match-style... The problem is when I use Eyedropper to paste a VW text style, the COLOR of the text does not change, it keeps the original pdf or browser color. WHY? The only solution is to change the color of the text to a random color and re-change it into black. Is there a solution? Thanks. Screen Recording 2020-06-05 at 15.09.22.mov
