592 -
Everything posted by SCParker
Autoplotvw.com also has a lineset tool.
Anyone know if there's a way to set the height of truss as it's getting added? Rather than inserting and then changing the height?
Has anyone else have this? When I move a connected run of truss, VW is redrawing each truss one at a time to move them. Each time the screen has to redraw/refresh. So, moving 10 sticks takes ten refreshes, etc. I've reported it as a bug. MovingTrussOneStickAtATime.mp4
This has been fixed... 👍
For the hex you may have to edit the shape itself in the resource manager. Right click it and edit 2D. Then add the fill.
Multicable labels, and multicable circuiting tool.
SCParker replied to Ryan Lilly's topic in Entertainment
@rseybert I know that in another post you prefer not to use add-on tools. Autoplot's cable tools does these two items, and more. -
I get this as well. Haven't tracked down enough info to post a report yet.
You could also make a "Dimmer" symbol and make it a lighting symbol. Then you could do the same as Kevin describes but without the houselights themselves. Each dimmer placed gets the same treatment in your paperwork as a lighting unit does.
Project share. One user has two machines with same username...
SCParker posted a question in Troubleshooting
If one user has two computers, Home/Office, and they both have same user name on the home folder, how can I get VW Project Share to list the local VWXW files as two different files? And, how do I get the Project Share Users pane to list the two computers as two users? This is important for when, not if, the user forgets to release items from home and has opened the file at work. Both files are open and now in conflict with themselves. Thanks, Scott -
You can also attach records to it so you can count them 🙂
Oh, but... In a scenario where you have a beam that has a limit of 1000#s per every 15' and you want a 1ton point. You could want to bridle and split the load between two points on the same beam. The workaround is to cheat and put beams going across so the Braceworks does the calcs. Then remove the extra bits.
For me, VWXP and secondarily, VWXW files. Our office of 18 are using Project Share across the board. Our technicians on the road need to have VW Viewer to snap measurements, preview plans, etc. Without the ability to open a project share file via viewer adds a layer of delay and additional workflow for those of us who have already moved on to other projects. Additionally, which one of us has the final responsibility to do that "Save a copy as" back to VWX? Worse, what if I save the VWX and then someone else does an update after I'm done? Etc.... Thanks, Scott
I am just starting to delve into this and was looking for the same answer.
Look in your service select account. Under downloads. Or, it might be Next to your license number in service select.
I had the same in one drawing a while back. It turned out to be an issue with a lighting unit's Braceworks ID. When you reset, it resets everything. I sent the file to tech support and they are the ones who found the issue.
Is there a way of reattaching several hoists back to a truss at once? If a truss gets nudged without the hoists, they all disconnect. Thanks, Scott
Reattaching a bunch of lights to a truss at one time
SCParker replied to SCParker's topic in Braceworks
Duh, never-mind. It helps if the trim of all the items are the same. -
Is there a way to quickly reattach a bunch of lights to the run of truss? The lights grab the truss when moving one at a time. But trying to do a group doesn't stick. I get the little blue box but neither choice works. Funny that it be removed from the hanging position AND set hanging point. But they're not being selected when I click on "select System Objects" in the OIP for the hanging position. Any ideas? Am I missing some sort of refresh and attached to closest possible point? Thanks, Scott
Whenever I run into these kinds of issues, I copy and paste the offending parts into a blank drawing and try again. Not that this will help, it's just another step in the search of a solution.
Needed: Adding the name of Hanging Position to Truss contained within.
SCParker replied to SCParker's topic in Vectorscript
@JBenghiat Hi Josh, Sorry, I need just a touch more instruction on how to make your worksheet script work. I confess to having very little experience with running scripts other than those already flushed out and automated by you and others. Best, Scott -
I've not done this on a curved truss, but when I do a LED video wall, I add a distributed load equal to the weight of the wall. Most of the walls I've been using hang from a pipe underhung off the truss with webbing every two feet so, and then to the header bars. Thus the distributed load vs. several single point loads. Disclaimer, I'm not an engineer, nor play one on TV. When I get close to the point limits, I punt to the house riggers and/or an engineer to double check. hth, Scott
@Nik Mondo you're half an hour from me. We should get together sometime. Best, Scott
This is one that you'll fair better by inserting corner blocks for most of your work and then change out for grapples after your calculation needs are done. Straight truss currently do not have a way of having this attached off to the side. Or, placing the side truss under/over the main truss line to make that connection point.
until
