Stereo
33 -
Never
Calendar
Everything posted by Stereo
Solved! It helped to just reset the printig system.
I forgot: I am using exactly the same configuration as Matthew
Hi I am experiencing the same problem. When I am using a postscript font ? such as univers condensed ? it won't print out. When writing a pdf via acrobat, the font shows as bitmap font. Here's a little work around: before print, hit the 'preview' button. Mac OS X 10.4 creates a pdf, sends it to preview.app, then, once you hit ok, prints it out correctly.
Im using VW 10.5.b1 on a G5Dual. That's nice. But using customized paper sizer, the drawing does not rotate right on the plotter, I often get an A4-printout on a paper like an A1. I tried all combinations, so I think this is just an annoying bug that appeared since VW10. PS: Anything else works great and superfast ? I'm very glad with that software and your work!
With the Designjet 120 you're having an excellent printer that does not need any X-Rip or other driver. Just use the driver HP provides, this one should be fast: ftp://ftp.hp.com/pub/softlib/software2/COL3312/pl-11451-2/hp120officemx.hqx
Since the software-rip for HP DJ500 was never really functional on Mac OS, here is a 100kB piece of software that works: http://www.buymelunch.com/printing/ It uses PCL-language, so you don't need PS.
Hello Colin With the designjet 500PS you can solve the issue by printing vie Postscript instead of printing with the regular driver
The HP software understands .pdf as well, it has a .pdf rip included. so you can even directly drag a .pdf onto the window of ps rip and it starts ripping... But hp rip is horribly slow and produces errors in larger files. The best solution for me was to buy a PC (ugly, beige) and windows 2k server, install appletalk and let it rip. It's fast and reliable.
Maybe you just have to unselect "fit to page" in the print dialog box.
Here's a short how to: Cables: Ethernet connection and a parallel cable.Software: On the PC: Make shure you ha a Windows 2k version or NT4 on which you can install the Appletalk protocoll, and file & print services for Macintosh. Maybe it even works without Appletalk, just TCP IP - so you can use a simple Win XP or 2k Pro. Install the HP-PS-Rip-software. Then restart. Then share the new printer. And: 256 Mb built-in are really enough, 128 Mb is to few. On the mac, make shure you have the right PPD's under system folder/extensions/printer descriptions. On the mac, you should create a new Desktop Printer using the LaserWriter Utility. It's also nice that you now can use Apple-Laserwriter software instead of Adobe PS-Driver. It works great with OS X also. It's alos that the HP-PS-Rip-Software on the PC is much further developped than the Mac version. You can simultaneously print and rip. And it's incredibly fast. Even very complex drawings start printing just 20 seconds after they got out of the Mac. So buying a cheap old PC even with let's say 300 MHz saves you a lot of time and error-output.
Printing on a Designjet 500PS using Macintosh is not satisfying: the software rip is very slow, with the standard memory configuration you'll get jagged output and you'll waste a lot of time changing your drawing a little (leaving away some lines sometimes helps) or simply: the plotter does stop plotting after a few inches. I contected HP support, they could not help. They had to admit that their product is not usable with Mac OS for the everyday-business. After weeks, the solution was that HP gave me an E42-Pentium 4 PC with Win2k installed, it serves now as a print server and everything is working very well. I have an Output quality which I have never seen before on my plotter.
quote: Originally posted by Gregor Samsa: I am an old time mac user, never worried about this kind of things, now with OSX... Does not matter under OS X. File type and creator still are stored invisibly.
perspective (keep vertical lines straight)
Stereo replied to poultryfarm's topic in General Discussion
The lines become straight when the actual viewpoint and eye are on the same height. If you want to look at an object that is high up like a roof if you stand in front of a house - you just stretch the marquee until you see that object - and do not change the viewpoint. -
Here is the link, so I'm taking back my request: http://download.info.apple.com/Apple_Support_Area/Apple_Software_Updates/English-North_American/Macintosh/Display-Peripheral/Video/GeForceGraphics2.1.1.smi.bin
quote: Originally posted by mlapthorn: Euphoria, I'm racing along at full speed. Would you please post the updater at your idrive - since 2.1.1 is no longer available...
quote: Originally posted by rjtiedeman: I just installed the new GeForce2 MX drivers 2.1.1 Strange, I could only find an Update 1.1.1 under http://kbase.info.apple.com/cgi-bin/WebObjects/kbase.woa/68/wa/viewDocument?extKCID=75115 Where did you get it from? With my Geforce 2 MX, 1.1.1 does not solve the problem. So please leave the link of the updater to download. I'm thanking you in advance (otherwise tell me the number of Steve Frushour's truck)
Shortcuts to be assignable to function keys
Stereo posted a question in Wishlist - Feature and Content Requests
On the mac, you can't assign Shortcuts to the function key's (at the top of the keyboard, F1?F15). It be great if the function keys could perform more important actions than loading an application o.s.s.. Under OS8, I used NowMenues to do so, under OS9 I manipulated the keyboard-layout with resedit, but what can be done under OS X? has anybody an idea? -
If you have a Mac, you can just use PDFwriter or Acrobat Distiller from Adobe, or Print2PDF - they work like a virtual printer. The file generated is a obviously a .pdf-file. As far as I know, Adobe's Products are available at least for NT4, W98. Since I turned away from Microsoft, I can only inform you about these old OS's.
I think it was me who introduced the idea about Allplan against VW. I wrote down this because this actually is the biggest fear I have about VW / Nemetschek. I had to evaluate Allplan for another company. This thought should be considered in the following sense: I don't want to work with any other software. VW is great. Unless it doesn't print, show selection handles, warps memory usage etc...
I experienced the same some time ago. Just uninstall VW and then reinstall it, so it should work again. If it doesn't help, do the same procedure on the other stations involved.
... can I rent this truck? I'm having enough of the woewoes with VW9, VW8, NVidia, Printers ...? What brand of truck was it, a VolksWagen 8.5.2? So let's go beach and have a beer.
I have the imression, that Nemetschek bought Diehlgraphsoft in order to get them away from the market - maybe the want to sell their horrible Allplan.
This reply is for bringing back this issue to the top of this list. Besides of all these woes this list is about, I still believe in VW as THE best tool for my work. So the frustration I share with the hundreds os people in this forum is personal. Do we have to wait for a solution, or should we forget it and turn to 8.5.2 with older videocards or even to autocad?
Vectorworks uses the extension .mcd but you better let these files send again as .dwg R14 or .dxf R14 since - as far as I know - 3DS does not read .mcd-files.
