Gaspar Potocnik
140 -
Everything posted by Gaspar Potocnik
Yes that is true, but I only want the horrible lines to disappear, not the container...
Any chance getting any answer?
MA Net only works under Windows, you have to download the ESP Vision Driver from the MA Lighting website, there is also a readme file which has the steps to make it work. https://www.malighting.com/downloads/products/grandma2/
Turn off focus indicators
Gaspar Potocnik replied to mreadshaw's topic in Vision and Previsualization
Strange thing is it only happens in wiewports on Sheet Layers, which didn't happen before. For me this is new to 2019. -
Completely agree, look like as soon as Lighting Instruments are in the mix viewports get insanely slow to load...
Vision & VW Design Layer Viewports
Gaspar Potocnik replied to LJ TMS's topic in Vision and Previsualization
I'm using the 3D labels which now has the full label legend functionality, that way you only do thing once. You loose the 2D symbol part, let's hope that gets implemented in the near future. -
NAS-Servers (Back-Up) with Vectorworks and/or Project-Sharing
Gaspar Potocnik replied to Mi&D's topic in General Discussion
@JimW any advice on this? Looking at the getting a NAS aswell. Thanks -
Synology NAS DS1517+ and Vectorworks
Gaspar Potocnik replied to Yvonne Parry's topic in General Discussion
@Yvonne Parry did you get the sinology? I at the exact same point as you at this moment, looking for some advice. Also wanting to be able to use project sharing. Cheers -
Selecting multiple fixtures and being able to invert Pan and/or Tilt is a must. The moment you are going back and forth between real life and the viz suite you need both to be exactly the same and most of the times re-exporting parts of the plot just isn't an option, plus this should be achieved in seconds not minutes...
Video Capture Cards in Vision
Gaspar Potocnik replied to bbudzon's topic in Vision and Previsualization
Any news on this topic with Vision 2019? Any other capture cards supported? Thanks -
Duplicate Along Path 2.0
Gaspar Potocnik replied to Kevin McAllister's question in Wishlist - Feature and Content Requests
Maybe this could also be a part of it: -
Jim is right about the external display for a laptop, drives me mad! I would go for the bigger screen although for my workflow it’s nice having 2 monitors. I also have a cMP, changed the GPU for a Vega and bumped up the ram and CPU, it has similar benchmark results as my i7 8700 hackintosh...
Really happy this finally got a 2.0 bump, certainly getting there! I did find some odd things, anyone else found these same issues? - When using a 3D label created in previous versions I am not able to change position of any of the fields assigned previously, actually I don't even see the field in the 3d Layout, only the container. I guess this is because of the feature improvement? - Is there anyway of not seeing the lines from the insertion point to each label? If not, should I generate a Wishlist post? - The assign 3D location in the ASSIGN LEGEN PROPERTIES menu is not working for me. The 3D flipping - In the 3D layout containers don't move with the actual text field. - It look like the positioning of each field is not absolute and interacts with the position of the rest of the fields, so if you move one ,01m it will move depending on everything else in the 3D layout, am I right? Cheers
Must say I am impressed, both with features that have left the wishlist (finally!) and the upgrade the app got in terms of rendering and performance. It's great to finally have control over image and video rendering, and being able to save preferences, THANK YOU! Some questions do arise with all the new stuff: - Do 3D elements HAVE to have a texture from now on? I'm using some existing files (and some new ones) and any 3D object that is imported comes in grey, no mater the color it has in VW. - Can we get a hold of the VWX file of the Sponza demo? It would be nice to understand how the textures are mapped. Cheers
Adding an external GPU to Macpro
Gaspar Potocnik replied to J. Wallace's topic in General Discussion
If you have a cMP you can add the newest gpu natively, I equiped mine with a Vega 64 it gave it a new life! On the other hand I’m waiting for a usb c pcie from sonnet to arrive and test my egpu and see how it goes, I’ll post as soon as I have it. -
I found out these two bug in separate ways so depends. The saved views happens with any merge, so if a set piece is changed or moved I delete the original 3d and merge in the new one, forget about saved views... So yes, this is part of the workflow. Regarding the fixtures, this was a completely random workflow, I wouldn't usually import new fixtures but you never know honestly, specially when doing festivals when floor packages change pretty often... Also I usually have both apps open until I finish my vision file, once its done I'll restart the computer and start programing with a clean start of system resources.
I'm having the same issues. Didn't have issues in the past with dropbox. I am working with Mac, latest software and os, and doing the project sharing with AFS, anything I should change? Thanks
This has been happening to me swell, after each merge I lose saved cameras... This swell, but after restart of vision they disappear. I guess it's a bug?
I really want to see what the answer for this will be 🤔 Same thing for Vision, which will the call be?
Anywhere we can find release notes? or list of fixed and new features? Thanks
Jim is this only SLI or does it also support Crossfire?
macOS High Sierra and Vectorworks 2018
Gaspar Potocnik replied to Diego - Resuelvector's topic in General Discussion
I've been running high Sierra on both a 2016 MacBook Pro and 2010 Mac Pro with no major hiccups, only known issue bugs but not related to the OS. -
I've been trying to find an answer for this reading through the forum but couldn't find a concrete answer. Does Vectorworks and/or Vision get any benefit from a system with multiple GPUs? Does any even support it? If so, is there any rule? I would guess same brand and Model would be preferred...
Teaser Tuesdays - Mac Touch Bar Support
Gaspar Potocnik replied to PVA - Admin's topic in News You Need
Not sure if this should go in this post or the wishlist so feel free to move it. Could we have the tool mode on the touchbar? Honestly, I'm only using the standard views since I don't have numpad everyday and tools already have shortcuts, so maybe this would be more useful for some users.
