Gaspar Potocnik
140 -
Everything posted by Gaspar Potocnik
I have always used some real picture, but I made my self this exact same question a couple of days ago... Not to meh knowledge, maybe some kind of script?
You probably have a large number of polys and that is why it's tacking that long. My workflow is to generate separate .esc or mvr files grouping things by department or whatever is easier to edit in Vision afterwards. This way if you have any updates to any part of your show you only re-export what has changed and not everything. My workflow will probably change with the implementation of mvr, but for now I stick to it. Regarding which file type to use, I'm currently using a combination of both, depending on what I am exporting and how I want to use it, again whatever is easier to manipulate in vision afterwards.
Just started a wishlist post, have a look and vote so it is changed as we use it.
Spotlight Numbering Tool Improvements
Gaspar Potocnik posted a question in Wishlist - Feature and Content Requests
In reference to this post it would be nice to get some upgrades in the new numbering tool: - Ability to reorder the fields. I personally think it should affected by the lighting device parameters you see in the preference menu, if not at least being able to reorder within the tool. Also this way you can see everything that is checked at a glance. - Highlight and check mark seem rather confusing: To check mark any field a double click has to happen (and after the first click the field usually scroll down, so if you had the last field selected you will have to scroll down again and give it the second click) only one click would be wonderful -
Video Capture Cards in Vision
Gaspar Potocnik replied to bbudzon's topic in Vision and Previsualization
@Charlie Winter I've only tried Mac OS, works on both 10.13 and 10.14 for sure, haven't tried previous versions or Windows... -
Light Instrument Data Appearing in Different Places
Gaspar Potocnik replied to Steve Clarkson's topic in Entertainment
I'm not quite sure I understand your problem. I do see from your file you have 2 symbols, one which look like a stock symbol and one you have edited. The stock symbol inserts properly as a lighting device, and has the proper records attached to it. For some reason you have inserted it as a symbol in the drawing instead of a lighting device, not sure why/how... I've inserted it as a lighting device without any problem. The custom symbol in which you have added your logo and lens is made out of a lighting device, that is the reason it is not appearing in any report. You should edit the stock symbol by right clicking on it in the resource browser and editing de 2d par with your logo and afterwards de 3d for the lens. Have a look at the following video which might help. -
I am afraid there is no way of changing fixture mode within vision...
Yes. Select your fixtures, in the properties windows expand the Rotation tab and enter a value in the coordinate you want. It looks like some must have a different Y value, you can select all and change the value for all of them and then adjust...
In Vision change the rotation of anything you need, as simple as that. Once it is saved it will show up the proper way each time you load the /v3s file.
Is there any way of only showing unit mark in dimension text and not everywhere else? Other than using the trailer field in the dimension properties... Trying to have less keystrokes in but keep the unit mark.
Data Tags - Hanging Position Z value
Gaspar Potocnik replied to Gaspar Potocnik's topic in General Discussion
@Kevin McAllister works like a charm! Thanks! -
I'm trying to make a Z value data tag for hanging position, I don't see it listed so I have tried "Z Location" and "RelDimZ" without any success. Is there any workaround or if it is not listed there is no way of having it?
Connect vision to grandMA3
Gaspar Potocnik replied to zeroInf's topic in Vision and Previsualization
What resolution are you using in vision? Have a look at the online manual and you will be able to learn what each parameter affects...- 10 replies
- 1
If you are using a Mac to run Vision your only chance to get MA to connect is by Artnet or sACN, for that to happen these configurations are need: sACN - Console and visualizer have to be on the same subnet range. - Console has to be in session and sACN output has to be activated (Network Configurations tab) - Console has to be connected to your switch threw port number 1 Artnet - Visualizer IP has to be in the 2.x.x.x or 10.x.x.x range - Console has to be in session and Artnet output has to be activated (Network Configurations tab) - Console has to be connected to your switch threw port number 2 to be able to output Artnet, if you also want to connect an OnPC then another cable to port 1 has to be connected. If you are using a PC you also have the option of downloading the ESP Vision driver from MA Lighting's web page. After installing configure the driver to the IP address your NIC is using and Session your MA is running. You also have to be in session and connected to port 1 of the desk.- 10 replies
Since v1.0 is out, are any of the fixture modes in vision already GDTF? Any idea how current libraries/symbols of VW going to work with GDTF?
GDTF importer to create Vision Symbols
Gaspar Potocnik replied to allannathan's question in Wishlist - Feature and Content Requests
Maybe it should be for Vectorworks aswell since this should be attached to the symbol used in the lighting plot... -
MA dot2 has 1 free universe, and you can use it via Artnet or sACN
I've had the same issue with some LED bars swell, I believe it was with TecShow StickTriTec and Blaster Pixelbar 12.
Vision 2019 SP3 MVR Improvements
Any chance vision can be multi unit as Vectorworks? Or since mvr is mm it can become mm? -
Vision Running slow
Gaspar Potocnik replied to thelightingguy's topic in Vision and Previsualization
This happens con any Mac I try it, 2016 MacBook Pro 15" Touch Bar, 2010 Mac Pro with Vega 64, custom Hackintosh. JIRA was submitted 11/16/18 though I had some emails with tech support about it even before. -
Vision Running slow
I've tried this out again, with a old .v3s file (previous to sp3) and a new .mvr file generated with SP3 and the problem persists, with sACN on a Mac, sometimes you get latency (or mouse move to render) and sometimes you don't. Artnet works fine. I guess this bug wasn't fixed... @Brandon can you try using artnet to see if you get the same results? -
If this is the case, and vision won't convert units, then it should be stated somewhere, either in the dropdown, special pop up or something. Coming from VW were you can use any unit anywhere and the app will convert it, it makes no sense to be given an option to change units but only millimeter will work. -
Vision Running slow
Are you running Artnet or sACN? Mac or windows? -
I’ve been trying to find info on remote operators but didn’t find any, where/how do you configure this?
