Gaspar Potocnik
140 -
Everything posted by Gaspar Potocnik
Has anybody been able to get a bump on to a stl file? Just trying to get something like a voronoi displacement on on face of a model I have. Cheers
Status Bar!
Objects moving when importing MVR file
Gaspar Potocnik replied to mhersland's topic in Vision and Previsualization
I had this happen once (I think it was in January), with ladders actually, was in the middle of a tight deadline and didn't report it... -
Vision 2021 and metal
Gaspar Potocnik replied to Gaspar Potocnik's topic in Vision and Previsualization
I guess this is a NO go? -
Just watched the keynotes. It is mentioned that VW will use metal for the Mac version in 2021, what about Vision?would be nice....
- 1 reply
- 1
Hog PC & Vision whats it going to cost me?
Gaspar Potocnik replied to J. Miller's topic in Vision and Previsualization
I'm not 100% sure since I. haven't used a Hog in ages, but I believe you can only use sACN or ArtNET if you are using Vision on a Mac. A HogNET driver is available for windows I believe. -
Thanks @markdd!
So I finally get some time to fiddle around with this but I found myself not being able to get the "Lighting Device" record to show up when filtering. When I apply my criteria I can see it: But when I want to select the universe field to "color it up" I'm not seeing it, am I missing something? I've done the same workflow for truss and motors and that was no problem...
Why not changing the color of your symbols? If you want to keep de grey/black for renderings you only change your pen color so in wireframe it renders with color, if not you change both.
Thansks @axhake hadn't seen that. Since there is a Purge command, shouldn't the color purge be there aswell?
So I've been trying to get rid of the Colors that appear in the Fill and Pen List under Active document, is there any way of achieving this? Can't see the item under the Purge command... I tried deleting everything from the file, run the Purge command twice but nothing gets rid of the Colors from the list.
Problem solved, issue with the file and VW, after a reboot and using a new file this was fixed, old file still doesn't show images in worksheets... Thanks @Pat Stanford
Haven't tried this for a couple of years and note being able to make it work. Trying to make a basic list of symbols. My first column is =('Lighting Device'.'Inst Type') Second column =IMAGE Third column =COUNT I get absolutely nothing, no image, no count in the database header. Cell Format is set to Thumbnail-Top Plan View. I've tried: - different scales - Different view and render types in the cell format - Inserting Cireteria into de IMAGE column (Only difference here is I get a count in the database header and a TRUE or FALSE value but no image. - Generate a report - Create a new worksheet from scractch - New file and worksheet Any ideas? Bug?
Edit Multiple Subclasses
Gaspar Potocnik replied to Justinwest1231's question in Wishlist - Feature and Content Requests
I would add the ability to edit the father class hierarchy in the navigation pallet. -
If you are using a MA and Windows for Vision use the MA driver, you will have no parameter limit since it uses MA Net as grandMA 3D does.
I haven't used any HDMI - NDI converter, there is no need, just plain NDI from one computer to the other and works great. To generate the NDI stream I used Newteck NDI Scan Converter.
[3D Label Legend] Leader Lines
Gaspar Potocnik replied to Charlie Winter's question in Wishlist - Feature and Content Requests
Any news on this? Or any workaround to get them to disappear? -
@orso b. schmid I haven't had any time to play around with 2020 until know. I did convert all the files and made a new folder, I'm trying to figure it out but haven't had any success. Here is how I see thing in 2019 (and how I've seen for the past years) in the resource manager: When trying to use a plug in as the title block (I can see me workgroup folder and navigate to title block for instance) I see this: But in 2020 I don't get the second workgroup folder even though it is configured the same as before. Resource Manager: Title Block manager: Any ideas?
I'm glad to help and get things the way I want! Just too many abbreviations, what is a TO and VE and where should I generate any of them? Are they served with or without ice? 🤔
I've used DMX transform for quite some time, only to move thing up and down, besides dealing with inches to figure out heights works great.. Today I wanted to rake a truss con "variable speed hoist" and found out the now (I believe this was not the case of old and beloved Vision 2.3) everything rotates around the local origin, this is also stated in the manual. Is there any workaround to get thing to rotate on the object axis? If not, I cannot figure out one good reason to rotate anything around the local origin in the entertainment world... Please someone explain what the benefit would be.... EDIT: I did find a workaround, if you place the whole object you want to move centered to the local origin in VW, it will rotate on its center. The only problem with that is that you have to move everything again in Vision in inches.... I really do hope I'm missing something here...
New Patch system and Vision 2020 Export
Gaspar Potocnik replied to Gaspar Potocnik's topic in Entertainment
I can see the DMX address field in the OIP but not in the spotlight numbering ergo I cannot patch with that tool. It's good both apps are following a standard, it would just be nice to have this stated somewhere in the manual (at least I did not see it) since it will change workflows for people. -
Beforehand I think this is great and something we've asked for some time, so Thanks! On the other hand, I haven't found any information that specially shows how it works so here are some questions: - I am guessing that the "Channel" field has to be the Unit number, can this be changed? - I've tried to use the numbering tool to get the DMX address populated but haven't found it, is the patch window the only way to get it done? If so, this is something to reconsider... - I've seen the Vision data mapping has vanished and for what I've tried it uses the same fields as the patch window, is this correct? Is this editable?
This has been a great guide for the past years, thanks @orso b. schmid For some reason tin 2020 I can't see anything in the WG library folder within VW, any ideas what has changed?
Feature Request: NDI Support
Gaspar Potocnik replied to Daniel B. Chapman's topic in Vision and Previsualization
Works like a charm!
