VW version is 2008 SP3,
OS is WinXP SP3
Comp: Intel Core2 Quad Q6600@2.4Ghz 3gb Ram, 2x Geforce 8800GT SLI
I usually export to Acad 2002.
I checked files in DWG trueview 2008 (yet i know that people that i send it to, have all these problems that i have in viewer. Command "recover" in Acad simply does not solve the problem.
Drawings are elevations (it is not a general rule though). They are 2D. Same problems happens when we recieve for example furniture layout with some 3d furniture models/splines/nurbs.
As i've written above - it has something to do with polygons/polilines/number or vertices/possibly number of groups or symbols in the drawing. It's hard to say.
Ususally i need to spend few hours to find set of polylines/polygons that behaves funny and after removing these drawing can be exported properly. It is not a general rule - sometimes i simply can't find the problem.
It's quite often in my office though. And it started when we moved into 2008 from 12.5. So i have all the reasons to believe that it is not just my computer.
After exporting that creates corrupted dwg files, my VW crashes or forces me to restart VW. In the beginnig markers around blocks and objects vanish and then, when tring to switch between vieports/layers/groups it can suddenly crash.
I'll try to submit this bug today after work - just thought that some of you might have had same issues.
Is there some other way to contact technical support more directly (except reporting the bug online)?
Thank you for your quick response
Best Regards
