Hum_Scum_Dave
    2
Reputation
0 Neutral
Personal Information
  • Occupation
    Theatre Technician
  • Location
    UK
  1. I work as a resident in a venue, and would like to have to enter the plan data (production name, designer, etc) to appear on plans only once - is there a way? At the moment, I have title blocks set up on each of the standard plans (an overall one, and several others for rigging specific areas) and I have to fill it in on each sheet individually. As far as I can tell I can't insert it on a Design Layer and viewport it without it losing the ability to enter the information in a form - is that correct, or is there a more cunning way? Does anyone have any suggestions?
  2. Hi... I've run into a bit of a problem with updating Vectorworks. I've downloaded the installer (I could only see one...is there a special 64 bit one somewhere?). Every time I run the installer, it gives an error box giving the location of the update software, and saying "This application has failed to start because the application configuration is incorrect. Reinstalling the application may fix this problem" On the basis I haven't installed the update...that's the problem...I have no idea what to do next! Any ideas? Thanks muchly, Dave
