Hi guys
I have had this problem for quite some time where i have had to import a 3d object such as a table, bench, etc from the resource browser but when the object is in there its at an z elevation of zero. I would typically have a few level changes in my designs so some of the objects end up being underground. Then if you try z value in the object info you find that there is no where to do this.
To fix this i have been creating different design layers for each level then changing the z value to desired in the layer in edit design layers.
Is there anyway to change the z value of an individual object if you cant in the object info panel?
Thanks
