I made some changes to PIO's that are used in VW12.5. Since I pasted them back into the plug-ins folder they no long show up in workspace editor or VS Editor. They are definatly in the correct folder. The only thing I can think of is I modified them in VW2009... I'm sure i've done before with no problems?
Could this be my issue?
orso,
I agree, if it was done intentionally it should be explained clearer in the help files with 'SetParameterVisibility'. The fact it isn't pointed out makes it sound like a bug?
ccroft
Cheers, I will have a read of that. Looks interesting
My PIO works fine at the mo. All params are hidden until the user makes a choice on a popup. That will do for now
Orso, I am not having this issue, I have most params hidden with double underscores and they work fine.
One thing I did discover is they seem to need an Alternate Name as well to work, I had some with and some without and only the ones with seemed to work... now they all do
Thanks Andrew, I tried your idea with not success. Is this what you had in mind?
resultstatus := GetCustomObjectInf (objName,objHd,recHd,wallHD);
If (objHd = Nil) then
Begin
objHd := GetObject (objName);
End;
Cheers
I'm creating a plug-in using SetParameterVisibility to change visibility of parameters in the OIP, which works fine. However I am wondering if it is possible for this to work in the properties dialog before the object is placed?
I had a search and it looks like this has not been answered yet. My apologies if it has been covered already.
At the moment I have everything hidden by default (using __PARAM) except for a popup. Once the object has been placed you select the detail from the popup which then shows the relevant params? This might be the best way.
WIN Vista
VW2009 SP4
Cheers
