654 -
Posts posted by DomC
Hi
This Marionette object contains a custom node, which reads a text file. One special application could be to automatically write something like an address or a descreption etc. into the plan.
Can be very interesting for customers which has to integrate Vectorworks in their software enviroment and rather more pushing data into the document than "self-drawn" content.
Maybe first read the "instruction.pdf" to see for which special case this example is thought.
Hi Jonathan
Very cool and applicable example. Thanks for sharing.
Dom
If we play around with Record Formats and Lists. It can be useful to access external Lists of Data.
I Attached a node, which bases on the python csv standard module. It can import lists as strings (text) or as numbers. It can't mix numbers and strings. Except Header (first Line) can be strings during the rest of the lists are numbers.
It could be used for:
1. Import csv (or tab) separated text files by using an absolute path.
2. Import a csv with the same path and name of the Vectorworks file (for Metadata/Project data like Title Blocks etc.)
3. It puts out rows and lines separately. The used path and rows- and line quantity.
v03:
Popup with Text encoding List. Python Standard is 'utf-8'
Check this out:
A Quick-Modification of the "Get Record Field-Node", which returns a list of Field Names instead the Field Values. So you are able to automatically feed your Field Names.
I hope this was not already part of the native nodes content.
Dom
Hallo Michael
You can just input more than one object or more than one Field Names. This works good, if you know the field names respectively if you always have the same kind of record format.
If you want to have the field names dynamically (another record with other field names) You need another construct (or node) which generates the field names automatically.
Dom
Hi
Type ID's you will find in the appendix of the function reference:
http://developer.vectorworks.net/index.php?title=VS:Function_Reference_Appendix
At the moment a do not know what saved sheet means (German Version here) I think this are saved view? Then maybe check out this:
https://techboard.vectorworks.net/ubbthreads.php?ubb=showflat&Number=218533#Post218533
Dom
Hi
I just work on a script, that let us jump to the next saved view in alphabetical order. (I know Vectorworks Remote could do that)
First Problem: Handle the saved views by script (I tried with ID, Parent etc. and failed). Thanks to Pat Standford (My Hero) which found a solution with vs.FIn3D :-)
https://techboard.vectorworks.net/ubbthreads.php?ubb=showflat&Number=118441
Second Problem:
The saved views are stored in the order they was created. Here Python scripting is showing one advantage. We can beatifully sort list with python.
#Python code to create list h=vs.FIn3D(vs.GetObject('Darstellungen'))# International Version "saved views" views=[] while h != None: name=vs.GetName(h) views.append(name) h=vs.NextObj(h) views.sort() # Sorts the list alphabetically
An extended Version. It maintains a Text Block inside the document which acts as a counter in the document. Because after execution the script can't remember the last saved view. Maybe there is a more smarter way by using a hidden record or something like this. I am not familiar with that.
#Python code to create list, grab and change the named(Info Palette Data field) text block and call up the saved view h=vs.FIn3D(vs.GetObject('Darstellungen'))# International Version "saved views" views=[] while h != None: name=vs.GetName(h) views.append(name) h=vs.NextObj(h) views.sort() # Sorts the list alphabetically zähler=vs.GetObject('zähler') #Handle to the text block Darstellung=vs.GetText(zähler) #Read Text index=views.index(Darstellung) #Check on which index of the list (of the sorted list) this view is stored if index < len(views)-1: # -1 it's because len counts from 0 I think vs.SetText(zähler, views[index+1]) #Change the Text block to the next saved view vs.Message(index) if index+1 == len(views): vs.SetText(zähler, views[0]) #Starts from the beginning vs.ResetObject(zähler) vs.VRestore(Darstellung) #call saved View
This hits on an idea to make a slide show, from save views. With an automatically delay. But this is tricky, because it seems to be a feature from scripts, that they do not regenerate views during the script execution. I tried out with a Dialog Box. That seems to work. But who want's to klick a away a Dialoge Box after every Slide.
I tried to do this this way:
import time h=vs.FIn3D(vs.GetObject('Darstellungen')) views=[] i=0 while h != None: name=vs.GetName(h) views.append(name) h=vs.NextObj(h) views.sort() length=len(views) def view(): for i in range(length): #vs.Message(str(views[i])) #time.sleep(0.5) #vs.SetZoom(100) #vs.SetZoom(50) #vs.ReDrawAll vs.VRestore(views[i]) #vs.Wait(1) return() view()
A new Version.
We are able now to reshape control geometry directly (take 2D Plan view please ...) without any spam-messages :-)
combined with the random box-fassade example.
One step nearer to the solution ... anything goes with script, forget crampy worksheet formulas.
#Formula in Worksheet: =RUNSCRIPT('script-1')
#python script-1:
A1=vs.CellValue(1,'A')
pic=vs.GetObject('pic-1')
if A1 >= 0:
pic=vs.GetObject('pic-2')
vs.WSScript_SetResImage(pic)
"Just" have to find cell number, the script runs. To read out relative cells to the script cell.
Hi
Maybe not the right forum for worksheet formula questions.
I am searching a way to insert an image in a worksheet cell by using a formula. I already searched the forum but could not find any related questions.
What I am trying to do:
If want to show an image in cell D1, if the cell A1 has the value greater than "0".
=if((A1<>0), 'here i want an Image', 'false')
I tried this:
=IF((A1<>0), (IMAGE(N='k1')), '') #-> cell is empty
=IF((A1<>0), D1, '') #D1 is refering to the cell "D1" which shows the image by =IMAGE(N='k1')
=IF((A1<>0), IMAGE(N='k1'), '') #-> cell is empty
also tried from other direction:
=IMAGE((IF((A1<>0), "N='k1'", ''))) #-> error because of the double quote I think
=IMAGE(E1) #Simple test, if IMAGE() formula can use values from other cells
I give up... Any tips?
Another one ... Fibonacci Sphere Point Node
Somebody knows if we just can copy paste and utilize python code from the internet?
I think yes. But it's courtesy to write the source of the script into the script code.
Great Job Sarah,
Your nodes are exactly this kind of stuff I like to see here. Thanks.
Too bad I recognised but now :-)
Out of curiosity, I tried changing the control geometry to a NURBS surface to see if it would work on a 3d surface, but it didn't seem to like it.
Et voilà
The same stuff on a 3D NURBS Surface.
A new Version of this Object.
I created the script new and under the object and module orientated marionette phylosophy. So it is based now on this nodes and wrappers:
Some New nodes:
(Also I notice, how much faster and better it is to first calculate the values just with list handling and at the end drawing real geometry. )
2D Pt Shaker:
Move every Point (2D Point list) randomly by a value
looser:
Deletes randomly values of a list
shuffler:
Randomly grab values out of the input and creates a new list with same length
Symbol 2D and 3D
All those nodes are handy to use with point grids to get a less strict look of a grid. A natural spread of points.
If someone notice, that this stuff can be done with standard nodes, let me know this. It would be pointless to "hack" nodes for things that can be easy done with a wrapper or a standard node.
There are some routine jobs to create point grids on 2D or 3D Objects for which I created some additional nodes and wrappers. I tried to make them proper and open like the standard nodes. I post a few of them.
Core functionality:
1. Creating a Grid all over an Object's bounding box
2. Evaluating, if the created point are in or on a surface
Different nodes for that, because it is better, to have not Nodes which do to much. So we can flexible use them in different cases.
Thanks for sharing this
Good Example to learn about creating lists and combining them in the right sequence for creating new objects.
We can combine this truss wrapper with every NURBS curve we want. As example with NURBS created in the tutorial example.
And it works. Up to some minor incompatibility between tutorial NURBS and NURBS which can be offsetted by this truss wrapper. Also some "closed" NURBS curves errors the list sequence of the truss node.
But it shows impressively how easy we can combine "simple" nodes to more and more complex networks.
Hi Tim
I think this shoud be possible. But maybe not every function can be used simply inside the Vectorworks "container". Particularly functions which wants to open a dialog window, print something in the terminal Window and other user interaction.
The instruction from Mark and FunkyBass for Numpy-Installation works fine here. I Installed it in a separate folder. And then copy/pasted it in the Vectorworks Application Content.
I would not overplay with actions like this ...
I enjoy you take an interest in that tool. Thank you!
The Idea to use this on a 3d "area" seems to be very interesting.
The node script based on the vs.PtInPoly(p, h) function which handels to the control geometry. If there is no poly it will end in a script error.
For use it on a 3D Surface or a NURBs would be a complete different challenge. The symbol insertion part would be the same. But we would have to somehow build 3D Points on a NURBS Surface. Should be not impossible ...
Hi there.
A New Version of this Marionette Object is available. Fixed the "hardcoded" Foldername (Folder-1) of the first Upload :-)
Now we can use any symbol folders we like.
Thanks for hints
Stacking order was the first I tried. But in this Object I have 10 Objects inside the group. So after every editing of the control geometry objects I have to check (send back the last object then the second last object until the first object is in background and the stacking ordner is right) So I searched for a less fragile workflow for me ... with record format. Can't see any technical problems with that.
You are right, if everyone creates additional ressources for his objects, the mix of many objects will rubish up the document. But we should also remember, that a name has the same effect, like a ressource (even worse).
I just personally have a bad feeling by naming objects. It is something like a bypass (which is easy to use) but can result often enough in conflicts with the other content of the project.
Just a dalliance
Maybe instructively in this example is, how to input the vertexes of a polygon split them and do something other with them.
In this case I used it to move another object along the path. The standard move node was picked and the python sleep() function was integrated in it. So after every move it "sleeps" for a short flash and redraw the screen. Animation part could be more smarter with inch/seconds and another algorithm. I'm glad, we have AnimationWorks (http://www.ozcad.com.au/products/animationworks.php) for real animation projects.
I searched quite a while for a way to handle different control geometries without naming them.
Naming them is a possibility. But what's about copy, duplicate etc. those named object? They will loose their name, or get a new one. Also anytime, all those names will get in conflict maybe with other named objects.
So my solution in this example is, to use a data base, for identifying the object.
The other speciality is i have a Window PIO into the control geometry. So it can be used for frame etc.
Known Issues:
Elevation not implemented (routine task)
IFC date etc. not checked (should be in the window)
Instructive example. Thanks for sharing Robert.
Another Question:
For 3D wall cut, we can use 3D loci or the control geometry node (very nice, thanks for this)
For 2D wall cut i use in my example 2D loci.
2D loci is OK for most wall objects. But an exact 2D cut would be desired. Is there another way to break 2D hole with a polygon. Maybe this?
vs.AddSymToWall(wallHd, offDistance, heightDistance, flip, right, symbolName)
Database Records
in Marionette
Posted · Edited by DomC
Output values are visible, when you click with the second method of the marionette tool on a wire (the "debug" methode). If there is no wire, connect a "Dummy End", which can be found under de "Debug" symbol popup.
