877 -
Everything posted by twk
The aim is to have the worksheet as a sort of staging area for the filtering and sorting of windows/doors. -- (I'm creating an automatic window/door elevation tool for schematic scheduling) Once the filtering was set I found there was no way for me to sift through the displayed subrow data and grab the object handles to create the elevation on the drawing. Now I can! I did use the ForEachObject() on the db criteria, however any sorting that happened on the worksheet was difficult to replicate through my script. I'd rather have the sorting/grouping all done on the worksheet, and then have the graphical display just pull from the UUID on the worksheet.
This will actually do it. Thanks a million guys. How do you find these @JBenghiat! On that note, would you know if there is a function call for this for worksheets? I've resorted to creating a script to pull that info into the worksheet, and can then cylce through the worksheet to grab the UUID and the object on the drawing. Would be perfect if I could skip the script part, as everytime the worksheet resets it asks me to execute the script. In any case, thanks again.
Interesting. How do you convert a handle representation back into a handle?
Greetings all, I have a worksheet that shows all windows/doors in the drawing. I was trying to grab handles to these objects from the worksheet database, but could not find any sdk functions to call it. So I added an extra column that calls the GlobalID from the IFCDoor/IFCWindow, and noticed that these are as expected all unique ids. My question is, does this ID, remain throughout the life of the drawing document? as opposed to handles? Could I then use these ID's to uniquely identify these in a script database somehow? Cheers, Tui
I was wanting to call a function from another script that is within the document resources. Not on a file somewhere else on the computer. cheers
We class our Site Model (Site-DTM-Main), then toggle that to grey when we need to manipulate other objects on the same layer as the site model. You are true that it is a pain that the Site Model takes precedence over any other object.
Twinmotion Plugin + Sync
twk replied to Tom Klaber's question in Wishlist - Feature and Content Requests
FYI: Unreal has bought out Quixel now. Making megascans available to all UE users for free! Also, free Twinmotion extened to the 1st quarter of 2020. https://www.unrealengine.com/en-US/blog/unreal-engine-4-24-to-ship-with-free-quixel-megascans-unreal-studio-features-and-more Not sure what the gameplan is for UnrealEngine, but they seem to be making alot of assets free. Would be beneficial for the Devs @ Vectoworks look into a direct import/export process. -
You'd have to use document list handling. Symbols are resources, so you'd build a resource list and cycle through the names in that list to see whether that symbol exists. http://developer.vectorworks.net/index.php/VS:BuildResourceList2
Oh ok. You mean in another file? or the current document?
You have to check whether the symbol 'name' exists in the drawing. You can check using vs.GetObejct(symName) to see whether it returns None or 0.
When you edit the marionette network you can paste in there all the symbols you need and then exit that wrapped network. You can then copy the marionette object from file to file and the symbols will move with it.
Confirming this happens to me as well. A workaround is to apply a roof style to the created roof. vs.BeginRoof(roofAxisPoint0[0], roofAxisPoint0[1], roofAxisPoint1[0], roofAxisPoint1[1], upslopePoint[0], upslopePoint[1], rise, run, 1, 0) vs.Rect(rectTopLeft[0], rectTopLeft[1], rectBottomRight[0], rectBottomRight[1]) vs.EndGroup() roofFace = vs.LNewObj() vs.SetObjectVariableReal(roofFace, 170, roofFaceThickness) # vs.SetFPat(roofFace, 1) style='' # import/create a roof style and add to this variable vs.SetRoofStyle(roofFace, vs.Name2Index(style)) vs.ResetObject(roofFace)
Appreciate the response @KIvanov.. will file enhancement request for second point. Cheers
Just moving into 2019 now, and transferring one of our larger projects to take advantage of the new features. Having testing 2019 through SPs 1-4 and now on 5.2 with smaller projects, we are confident to take the dive. First off, the data tag has been such a breath of fresh air, in terms of a common-sense tool release, so thanks again to the devs at VW. Secondly, a couple of questions for other users who have being using 2019 in the wild since its release and the data tag tool. a) Is it possible to un-link an existing data tag thats been placed in the annotations viewport, to another object? e.g, A tower type building, you tag all the windows on level 1, in the annotations space, you then duplicate the whole layer (to do the next story up), you change the layer visibilities for the viewport to have the design layers for the next level up. Then realise the data tags from the previous level are still in the annotations space for this new level, however theyre still linked to the windows from the level below. Would be great to relink these tags to the new level. I havent found a way yet, if others know of way that would be great. b) Is it possible to have the data tag look into design layer viewports on a design layer, while your in the annotation space of the sheet layer? Again, I couldn't see a way, wondering if anyone else knows. If neither are possible, I will file an enhancement request. Cheers, Tui
There isn't much script functionality on the DevWiki regarding Data Tags. I was wondering if anyone knew how to get a handle to an object a data tag is attached to. Say I can collect all the data tags in a viewport, as handles, does anyone know how to get handles to objects those data tags are attached to? Cheers, Tui
Havent tested, but you could use the WallFootPrint(WallHandle) function to create a dummy polygon of the outline of the curved wall. And check if that polygon is within LOC, then delete this dummy polygon. May create memory overhead with creating and deleting objects. Again, havent tested.
Is there a command for list of available targe SP's? For the NZ version I had to change target from "SP4" to "MB-SP4" to get the localised SP4 version. This was done through trial and error as MegaBits(MB) is the distributor here.
You edit the titleblock border layout to do this. Maybe this video will help:
2021 Architecture Wishlist
++++ Grid Lines and Elevation Lines to auto-display in viewports. -
Good spotting guys. There's no mention of this anywhere on the socials.
Thanks for the help everyone. Much appreciated
Sorry, I totally forgot about this thread. What a shame, that resource was a treasure trove. Yes please @_c_, that would be greatly appreciated.
How can I scale multiple objects from each objects center?
twk replied to cdavis's topic in General Discussion
Swapped out the HScale2D for HScale3D, and seems to scaling fine here. Working on Extrudes though. What particular 3D objects where you trying to scale? # DISCLAIMER # - Python Novice # - Script presented as is # - save your work before using # - use at your own risk # - no responsibilty taken for damage to your property from the use of this script # - copyright twk 2016 # - forum link = https://forum.vectorworks.net/index.php?/topic/19675-how-can-i-scale-multiple-objects-from-each-objects-center/ # - Tested on Windows 10 x64, Vectorworks 2016 SP4 def List_SelectedObjs_in_Layer(): # small function to store all selected objects on the current layer into a usable list (python list) h_FirstInContainer = vs.FIn3D(vs.ActLayer()) listObjs_inContainer = [] while (h_FirstInContainer != None): if vs.Selected(h_FirstInContainer): listObjs_inContainer.append(h_FirstInContainer) h_FirstInContainer = vs.NextObj(h_FirstInContainer) return listObjs_inContainer list_selObjs = List_SelectedObjs_in_Layer() # function called, selected objects stored countIt = len(list_selObjs) # number of selected objs store in countIt variable if countIt > 0: # checking to make sure at least 1 or more objects are selected scaleAmount = vs.RealDialog("Enter Scale Amount", "1.5") if not vs.DidCancel(): # checking to make sure predefined Dialog's OK button was pressed for eachObj in list_selObjs: center = vs.HCenter(eachObj) # getting center of obj to be used in next function # vs.HScale2D(eachObj,center[0],center[1],scaleAmount, scaleAmount, True) vs.HScale3D(eachObj, center[0], center[1], 0, scaleAmount, scaleAmount, scaleAmount) vs.ReDrawAll() # redraw-ing the screen as is needed after running HScale2D vs.AlrtDialog("{} Objs scaled".format(countIt)) #indicates the number of objects scaled else: vs.AlrtDialog("At least 1 object must be selected") # checking to make sure at least 1 or more objects are selected
