Amorphous - Julian
    424
Posts posted by Amorphous - Julian
  1. One of the annoyances we find with the Titleblock Border object is that, in a multi-user situation, only one person can work on ANY titleblock.
    It would be ideal if different 'parts' of the titleblock can be checked out by different people.
    For example:
    • I ask STAFF A to work on making sure 'Current Plot Date' - 'Auto - Short' is turned on for all sheets (more on this issue later**)
    • And, I ask STAFF B to apply the latest 'Revision number' to ONLY the sheets we are issuing (more on this later too##)
    Because Titleblock Border is one linked object across all sheets, I can't have STAFF A and STAFF B doing the above tasks simultaneously.
    Would be nice if the Titleblock Border is somehow broken into parts so different people can do different things on different sheets at the same time.
    ** Problem with Automatically applying Current Plot Dates to sheets upon placement.
    Even though showing 'Current Plot Date' is set to show as 'Auto-Short Form' in my 'Titleblock Style', upon placing the titleblock on our sheet, the 'Current Plot Date' doesn't show up, and we have click into the PIO dialogue and manually turn that on for each titleblock we place in. This is very time consuming.
    ## Problem with applying the SAME information to MULTIPLE, SPECIFIC sheets
    Currently, we can only apply desired information such as 'Revision' to only 'ALL' or 'ACTIVE' sheets.
    I would be much better for us to be able to apply information to a list of drawings from a form that shows all drawing.
    Finally, I really don't understand why navigation of the 'Title Block Manager' is sequential (via the 'next button), instead of with a drop-down list.
    And why does clicking on the 'Titleblock manager' take you back to the first sheet, and not the current sheet you are working on.
    @Markus Barrera-Kolb fantastic worksheet. We have spent hours trying to figure out how to pull out these kind of data from the Titleblock border but in the end settled with only showing the 'current plot date' and 'current revision'.
  2. We do use separate classes for each finish (GL01, GL02 classes for different types of glass... TL01, TL02 classes for different types of tiles).
    In fact, the above elevations were generated by the 'walls components' picking-up up on the different 'renderworks texture surface hatches' of the relevant 'class renderworks texture' (a long, round-about way of achieving 'wall surface hatch by class')
    Yes- we can use unstyled walls with two 'finishes components' on either side of the wall, but it doesn't resolve the issues of the 'start and stop' and having still to define two different 'finishes components' on either side of the 'core wall'. It becomes the same multiple small, short walls as described.
  3. Hi Diogo, all those issues you have raised are valid but can be resolved by planning the model differently (as Christian as pointed out)
    1) If the first floor has a wall, and the second floor also have a wall, then just draw them as two different walls
    2) You can overcome this by doing an extra 2D layer with Dotted lines that you can turn on and off. But I agree that this is very frustrating!
    3) You can show the wall components in Section, but it takes a long while you get all the wall components set up correctly.
    And Christian, I agree with you on that may key elements is missing from Vectorworks. As an ARCHITECTURAL tool, some important tools that Diogo pointed out sorely missing.
    Furthermore, working on a model as a team presents a nightmare.
    ArchiCAD has many good points, but it has a bad interface for 2D drafting, and is more expensive.
    Revit does't run on macs.
    So Vectorworks, rather being the best choice, is the product that happens to fill in a particular void in the market. We'd love to see it being developed as a more meaningful collaborative tool.
  4. Hey guys... just wondering whether this post should get further updates... or just let it died? I think it is an important conversation.
    Blimey- has your office resolved the speed problems by switching back to design layer referencing?
    Jeffery- I second Blime's point about 'workflow'. If you have more than one person working on a project, the task of modelling has to be spread between different people in the team.
    In any case, modelling+drafting are intertwined processes. It is not like when you finish modelling, you start drafting. These two processes are very much interactive and iterative.
    All the other CAD packages on the market now have much better teamwork interfaces (look at ArchiCAD, Revit etc), they also have a teamwork structure that keeps the model in one file to maintain its BIM integrity.
    Vectorwork's ability to link one file to another a really antiquated way of teamwork. Is Nemetschek planning a better, and different way of teamwork for Vectorworks?
