BillV
    156
Reputation
26 Great
1 Follower
Personal Information
  • Occupation
    Vectorworks Sales
  • Location
    Wellington, New Zealand
Recent Profile Visitors
2,701 profile views
  1. The Number Tags are already in the object styles. You would need to edit the Tag to enable you to select the prefix from a drop down list.
  2. Here is a model I did using the Foliage Tool and send to surface. Both the plantation pines and hedge done with Foliage. The wind Turbines are a Plant Symbol ! with the Turbine imported from Sketchup The Hedge is Linear Mode and the Tress are Area On Ground mode.
  3. Kevin, I agree and I know Ross from Aspect Design does. So what do we do to get Vectorworks inc to act on it. With the new rendering options available to us we really need proper 3D presentation and texturing ability like this for walls and roofs . Displacement mapping is old hat and not particularly effective
  4. With walls I am sure there are many users who would want to see more realistic Wall Coverings instead of the current Texturing which has been around seemingly for ever. This image shows what can be done with an existing tool - Create Planar Display - to produce an accurate siding weather board. The second image shows metal siding/ roofing material. How difficult is it then to extend this and produce realistic wall coverings.
  5. Good call that works Thanks I appreciate the advice.
  6. Thanks for the advice. Applying to a 3d Poly solves the issue.
  7. I have created a few grass textures. In the attached image the grass texture creates some annoying horizontal shoots. The higher the density the more shoots I get. In a planter box for ornamental grasses this looks kind strange! I have included a screen shot of my settings for the texture Is this a bug or a new type of grass - Herba Vectorworkus perhaps ! Any help here would be welcome.
  8. Dave, there appears to be an issue importing Sketchup these days. It used to work well but it appears the necessary translators have not been updated for some time in Vectorworks. I ran a test on Vectorworks 2019 on Mac OS 10.14 and was unable to import version 2019, 2018 and 2017 Sketchup files The 2019 had been produced with Sketchup Pro. It was only when I got back to a very much earlier Sketchup model that the import worked. Given how many of our Architects use Sketchup this could become a real issue. I have attached a Schneider wall socket file for test. 4025XA_SOCKET_OUTLET_10A_TWIN_WITH_EXTRA_SWITCH_Horizon_Silver 2019.skp
  9. There is a clear need for an ability to draw walls as panels. This method of production is common in Europe and increasingly so elsewhere. We are seeing a move towards factory production using SIPS panels and its worth noting that this is available as a plug in Autocad. Unfortunately when I raised this NVI some time ago it was deemed not necessary. Go figure!
  10. Have you seen or created a Marionette to create a SIPS Panel. We are seeing a lot of SIPS being used and no software really addresses that. I can create a panel but it becomes a Group which does not allow me to insert a window or door which is what is needed when cutting the panel on a CNC via DXF. Any ideas would be welcome.
    SIPS as Plug In.vwx
  11. Good call Marissa that works well. On another note have you seen or created a Marionette to create a SIPS Panel. We are seeing a lot of SIPS being used and no software really addresses that. I can create a panel but it becomes a Group which does not allow me to insert a window or door which is what is needed when cutting the panel on a CNC via DXF. Any ideas would be welcome. SIPS.vwx
  12. Patrick If you do a lot of this the simpler way is to Export a DXF to a nesting programme like Enroute. Get in touch if you need more information. Enroute will read both 2D and 3D DXF and will post to CNC. Interiorcad to Enroute.mp4
  13. Has any thought been given to allow a Marionette wrapper to be placed on a New Tool Set I know you can create a menu item - it appears under Tools> Marionette Commands and which is stored in your User Library. To be able to select your wrapper and then edit via OIP would be great. Alternatively have the Node create a Tool on a tool set.
  14. BG I have to stress that the tool is a beta version only. Both Jonathan and I had input in the same way with the foliage tool. Your feedback is important though as all the comments so far are very relevant relevant and appreciated. Please bear in mind the value of Andrea's contribution these things start off as a hobby for him and he still provides the downspout for free. What is important I feel is that if we make enough noise someone at NVI will wake up and take notice. Surely roofs in the US have gutters, flashings and downspouts or maybe none of the homes owned by NVI employees have those items! In answer to the question about brackets the answer is yes and the spacing is variable. Aspect Design - I don't regard what we are asking for as small stuff. It is fundamental to virtually any building!
  15. Hi BG I will be talking to Andrea. At the moment it does not follow a sloping roof. I think the tool also needs to connect to his downspout tool. Watch this space.
