Kevin McAllister
5,219 -
Everything posted by Kevin McAllister
Ok, here?s a kick at an example with some instructions. I?ve concentrate on the shapes, not finishing or texturing. Note that I did everything in top/plan view or top view and then rotated the finished object. - the back panel is a straight extrude of the entire outline - the outer border was made by using the offset tool and then the paint bucket option of the polygon tool. I had to draw a horizontal guideline to contain the shape. It was then extruded and the edges filletted. - I did a 2D layout of the diamond pattern. I traced one diamond as a polygon and converted it to a nurbs curve. I then used the ?Create Surface From Curves? menu command (3D Power Pack I believe). In the object info palette I increased the U Degree and V Degree each to 2 (From what I can tell, 1 is a flat plane, 2 is a simple curve). With the nurbs surface still selected, choose ?Show Points? in the object info palette. Change the Move drop down menu to ?Vertex Only?. Using the point arrows, step through the points until the centre one flashes and is selected. Change its Delta Z height to make the diamond puff towards you. Note that this is the amount you are moving the point, not the surface itself (I moved about 4.25? to get the diamond just over an inch high). - I repeated this process to make the custom edge pieces. - I used the Move 3D command to move the objects into their relative relationships (ie. the diamonds and the border above the back panel) since they were all generated on the working plane. - I then duplicated the various diamond variations filling the upholstered boundary. At this point I also deleted by guide lines, except the outline for the entire inner panel. - I grouped all the diamond pieces and the outline of the inner panel I?d saved. Working in the group, I converted the outline to a nurbs curve. Using the Project & Trim tool and the outline of the inner panel, I trimmed all the diamonds at the edges. This process was a little fiddlier than I?d hoped. Because the outline disappears after each trim operation, pasted in place before each operation. I did all the pieces instead of only doing half and mirroring. Mirroring with nurbs will mean you need to reverse their ?normals? so they render properly. - I created a simple button using the Hemisphere tool. I had to play with its placement a bit so it didn?t disappear into the folds. I duplicated it using the Move tool. I have attached the finished file so you can see the pieces. I have found that modeling in 3D is actually easier than I thought. Most of my initial troubles came from not understanding the tools and when to use solids, when to use nurbs etc. Unfortunately some of this knowledge is not written down anywhere. It certainly could be finessed a little more and have textures added, but you get the basic idea. Kevin
That's an excellent tip. There are a few tools there (oddly I remember using them at some point). I have been working my way through Jonathan's 3D book and there is no mention of them in there either. Once you draw the 3D ellipsoid, you can use the extract parametric curves tool to get the curve you need and convert it to 2D. KM
I recently switched from using the Print>Save as PDF function to the Export PDF function. I like some of the additional options I have but I am wondering if there is a way to control the bookmarking feature. I don't mind that in multiple sheet documents it bookmarks each page (in fact I like it a lot), but I find that it adds a bookmark for each individual sheet layer viewport a bit too much. I often duplicate sheet layers and edit from there, so my viewport names are all over the map. I can delete these extra bookmarks in Adobe Acrobat, but I wondered if there was a more direct way to change this setting. Thanks, Kevin
VW 2009 and upcoming Mac OSX 10.6 Snow Leopard
Kevin McAllister replied to AN Design's topic in General Discussion
One could also assume that Nemetschek's group of programmers are also focussing on Vectorworks 2010, including its Snow Leopard compatibility, before they will be looking back to 2009...... KM -
I think it could be made with some nurbs objects. I've discovered that mastering nurbs is all about practice and learning how the tools respond. When I first started trying to reshape in 3D space it was a bit of a mind bender. I may give it a go over the weekend to see how possible it is. What size of bed do you need it for (width and height of the headboard)? KM
Problem rendering glass in doors
Kevin McAllister replied to billtheia's topic in General Discussion
Were any of the troubled objects generated by mirroring? I have had some mirrored objects misbehave, especially when exporting. KM -
From what I read in a review of Snow Leopard from Macworld, their Non Disclosure agreement expired last night (August 26) at 6pm. I suspect NNA was probably under the same NDA.... hence no formal comment until today. KM -
Thanks Ray. This is good information to have. Clearly VW2009 is not compatible at the moment. Something I would not have wanted to discover after the fact. KM -
For the UI, Don't Even Consider This...
Kevin McAllister replied to Bob Holtzmann's question in Wishlist - Feature and Content Requests
I must admit I'm not entirely clear on what the "ribbon" interface is, but I do agree with a lot of what Chris is saying. While I wouldn't say its broken, there is a lot of duplication and room for streamlining and improvement. I customize my palettes so the tools are arranged horizontally across the bottom of the screen. I have done so for many version of Vectorworks/Minicad. With my OS dock across the bottom as well I find its efficient for most mouse movement and increases the usable space for the object info palette and navigation palette at the side. Screen real estate is at a premium when you are on a laptop. I used various workaround over the years to achieve this as the palette interface changes. Right now I find that the palette borders use up a lot of extra space. (My current experiment involves stacking the closest 3D equivalent tool above the 2D tool. My work is quite varied, so dividing the tools into categories as VWs does is not that efficient.) Additional duplications include the object info palette and properties dialog, which are almost but not quite the same as I discovered recently. And even I have fiddled with scripts to try and make the prime preferences Chris mentions accessible from the tool palette (black and white is another). Kevin -
I discovered something new about this the other day. If the symbol is the only thing selected, a custom move dialog appears when you use the move command (VW 2009). I think that dragging only works in top/plan view. I see that you are using Vectorworks 12, so dragging may be the only option for you. KM
Import DWG file results in numereous design layers
Kevin McAllister replied to Gerrit's question in Troubleshooting
Here are a few thoughts based on my own experience of importing DWGs. Hope they help. You can choose to centre on import (primary setting>model space in the import dialog). This should help with this problem. After years of bringing in Autocad layers as Vectorworks layers, I finally switched to bringing in Autocad layers as classes. I would suggest you try the same. When you delete classes to clean up the drawing, you are given an option to move or delete the objects within that class. So the scattered objects can be brought together into one class or reassigned to other classes, instead of being deleted. Also, classes can be quickly grouped by using the dash ( - ) within the name of the class, so in the class drop down menus they nest cleanly. Usually this means either objects within the symbol in a class that is turned off (may not be likely in your case, since you are importing layers), or that there are loci (Autocad points) in the symbol. Often the points are the WCS/UCS 0,0,0 of the block. Try Vectorworks>Preference>Display and turn Display 3D loci to Always. Hope these suggestions help. Kevin -
I have had the best results with DWG or DXF. I suspect you may be able to edit a Vectorworks generated PDF to some degree (especially if its generated by the export PDF option), but I haven't experimented with this too much. KM
This is a good question given that Snow Leopard is shipping on Friday. Will the current version of Vectorworks 2009 run without problems under Snow Leopard? Will Vectorworks 2010 be Snow Leopard ready out of the box? KM -
Is it possible to list the starting and ending co-ordinates of an open 3D nurbs curve in a worksheet? I can find functions for the centre x,y,z co-ordinates, but not for end points. I have spent some time looking through the archives and it sounds like it may require writing a script to feed data into a record to do this. Thanks, Kevin
As far as I can tell the length values are for the true length in 3D. I can verify this in two ways - 1) Draw a nurbs curve in plan view with a few points. This creates a nurbs curve with no Z value. Duplicate it. Edit the duplicate by moving some point in the z direction only. Both curves look the same in plan view (ie. the plan lengths are the same) but in the properties dialog the one with a Z value is longer as expected. 2) I had a colleague import the file into Autocad. Using the list function it returns the same length values I am getting. His understanding is that the length shown in the true length, as everything in Autocad is 3D.
Yes, I wondered the same thing. Wasn't sure if I should add it to the wish list or report it as a bug.... KM
I should have searched the archives before posting my question, though there is an ironic twist. So if you right click on the nurbs curve and select "Properties", opening the properties dialog, it shows the length of the curve. I had always assumed that the properties dialog showed the same information as the Object Info palette. Clearly a bad assumption, though I suspect its a common one..... KM
Is there a way to find out the true length of a nurbs curve in 3D space? I thought for sure this could be done in Vectorworks but I am at a loss to find it. I need to figure out the time it will take to travel along the distance of a curve I've drawn. Thanks, Kevin
VectorWorks 2009 Autosave crashes on network
Kevin McAllister replied to Abz's question in Troubleshooting
I was having some saving issues with Autosave when it is set to XX minutes. Try changing it to XX operations instead. I remember it being suggested in another thread at some point. It seems to have worked for me. KM -
Can you detail the viewport rendering settings you are using (perhaps a screen shot of the Object Info palette)? I think you may find you need to use a combination of foreground and background rendering settings to achieve the look you want. Creating the object as a solid subtraction (an extruded surface minus the two holes as cylinders) is half the battle. The other lines are part of how Vectorworks sees the object in wireframe. The object will need to have a solid white fill and have a transparent rendering texture assigned to it (ie. glass clear texture). Some rendering modes don't support transparency (ie. Artistic Renderworks). It looks like you have given the object a fill of none as a workaround and now it is rendering as wireframe. The rendering mode you choose for the background rendering settings may want to support "smoothing angle" as well. KM
Interestingly I have had a similar thing happen in a file. I have two viewports on a single sheet layer, two different views of the same design layer, set to exactly the same render settings. One renders very clean, one looks pixelated. I checked the resolution settings etc. but they were all ok. Very strange. KM
Improved Tool Consistency
Kevin McAllister replied to Kevin McAllister's question in Wishlist - Feature and Content Requests
As the others have clarified, its the overall sequence of the clicks. I would prefer to define the rectangle on the working plane and then give it a height. My apologies with this one as I didn't explain myself very well. My comment is with respect to editing existing Drawing Labels in a drawing by double clicking on them, not double clicking on the tool to create new ones. I am so in the habit of double clicking to edit (it comes from years of using text objects as labels). KM -
Kevin McAllister posted a question in Wishlist - Feature and Content Requests
Hello All, I have been a Vectorworks user since Minicad 5. I really enjoy using the program and have found it quite powerful for 2D work. Recently I started using a lot more of the features, especially full 3D modeling. Vectorworks 2009 was one of the things that encouraged this. In future versions, one of the things I would like to see is a continued finessing of the tool consistency. Here are a few examples - 1) more consistency between 2D and 3D tools ie. the 2D rectangle tool takes two clicks to make a rectangle. For whatever reason the 3D rectangle tool insists on asking for a extrusion height first, instead of the first two clicks being the same as the 2D tool with the third click being the height. 2) more modifier tools that have select object first functionality (ie. like the Offset tool, which has a mode where the first click selects the object). This would be ideal for the Move Object, Mirror and Rotate tools, among others. Imagine choosing the tool, clicking on the object (or objects with shift selected) and then doing your action. 3) the ability to double click in an empty area of a drawing to choose the green checkmark action box that is used with many of the 3D nurbs tools (ie. shell solids, protrusion/cutout). 4) consistent double click editing across all plugin tools. The Drawing Label tool is a prime example of this. Why doesn't double clicking bring up a basic dialog with the four basic things you input (item number/drawing reference/drawing title/scale). Instead I get the mode bar error. The same is true of the Reference Marker tool. At a minimum double clicking could drop you into the primary field of Object Info Palette This was fixed with some tools (ie. leader notes) but not all. My two sense for the future.... Kevin -
Rotate Around Hinge Line in 3D
Thanks for the advice. Mastering the Working Plane tool was a good workaround. The tool has confused me for some time now. It turned out it wasn't the tool that was confusing, but the demo instructions in the manual for the 3 point mode. I was following their selection suggestion and, of course, because they were selecting a vertical line first, every time I chose to look at the working plane the entire view would rotate 90 degrees, causing great confusion with navigation. Weirdly the select face mode for the same tool defaults to the same thing. Once I understood why it was doing that, I could select more intuitive points.... Now that I understand the working tool, and by choosing views while using the working plane instead of the ground plane as the base, its much easier to do what I'm trying to do. That said, rotating around a pivot line would still be a great addition. Thanks again. -
Thanks Jonathan. You are a great resource to the VW community. The "Nearest Point on Edge" checkbox under Object Snaps seems to be the key. It is turned off by default and since I wasn't trying to snap to an edge I didn't think to try turning it on. Kevin
