Kevin McAllister
    5,191
Posts posted by Kevin McAllister
  1. Here are a few thoughts based on my own experience of importing DWGs. Hope they help.
    2. the object is extremely far away from the absolute 0,0. I'm talking 15 km, more than I've ever seen before. Is there an option during import to avoid this awkward position ?
    You can choose to centre on import (primary setting>model space in the import dialog). This should help with this problem.
    3. Right after importing the drawing, I'm facing a whole list of new design layers, named : _Layer_Crop-xxx, where xxx represents a value from 0 up to 287. Many of these additional layers have a few objects, so I can't just delete them.
    After years of bringing in Autocad layers as Vectorworks layers, I finally switched to bringing in Autocad layers as classes. I would suggest you try the same. When you delete classes to clean up the drawing, you are given an option to move or delete the objects within that class. So the scattered objects can be brought together into one class or reassigned to other classes, instead of being deleted. Also, classes can be quickly grouped by using the dash ( - ) within the name of the class, so in the class drop down menus they nest cleanly.
    4. Several symbols have a selection area that is way larger than the object(s) would have you to expect. Scale to Objects results in a zoom number like 0,004%. Top right would be the actual symbol, while the rest of the area seems empty. I already checked for text objects size 0, arc centers etc.
    Usually this means either objects within the symbol in a class that is turned off (may not be likely in your case, since you are importing layers), or that there are loci (Autocad points) in the symbol. Often the points are the WCS/UCS 0,0,0 of the block. Try Vectorworks>Preference>Display and turn Display 3D loci to Always.
    Hope these suggestions help.
    Kevin
  2. Is it possible to list the starting and ending co-ordinates of an open 3D nurbs curve in a worksheet? I can find functions for the centre x,y,z co-ordinates, but not for end points. I have spent some time looking through the archives and it sounds like it may require writing a script to feed data into a record to do this.
    Thanks,
    Kevin
  3. As far as I can tell the length values are for the true length in 3D. I can verify this in two ways -
    1) Draw a nurbs curve in plan view with a few points. This creates a nurbs curve with no Z value. Duplicate it. Edit the duplicate by moving some point in the z direction only. Both curves look the same in plan view (ie. the plan lengths are the same) but in the properties dialog the one with a Z value is longer as expected.
    2) I had a colleague import the file into Autocad. Using the list function it returns the same length values I am getting. His understanding is that the length shown in the true length, as everything in Autocad is 3D.
  4. I should have searched the archives before posting my question, though there is an ironic twist. So if you right click on the nurbs curve and select "Properties", opening the properties dialog, it shows the length of the curve.
    I had always assumed that the properties dialog showed the same information as the Object Info palette. Clearly a bad assumption, though I suspect its a common one.....
    KM
  5. Is there a way to find out the true length of a nurbs curve in 3D space? I thought for sure this could be done in Vectorworks but I am at a loss to find it. I need to figure out the time it will take to travel along the distance of a curve I've drawn.
    Thanks,
    Kevin
  6. Can you detail the viewport rendering settings you are using (perhaps a screen shot of the Object Info palette)?
    I think you may find you need to use a combination of foreground and background rendering settings to achieve the look you want. Creating the object as a solid subtraction (an extruded surface minus the two holes as cylinders) is half the battle. The other lines are part of how Vectorworks sees the object in wireframe. The object will need to have a solid white fill and have a transparent rendering texture assigned to it (ie. glass clear texture).
    Some rendering modes don't support transparency (ie. Artistic Renderworks). It looks like you have given the object a fill of none as a workaround and now it is rendering as wireframe. The rendering mode you choose for the background rendering settings may want to support "smoothing angle" as well.
    KM
  7. The dialog box is only when you are in a plan view (or perpendicular to the working plane). Since you are drawing on a flat screen there is no way to set a "Z" height into or out of the screen, so it asks with the dialog box. If you draw in an isometic (or other 3D) view, you get the 3-clicks you want.
    As the others have clarified, its the overall sequence of the clicks. I would prefer to define the rectangle on the working plane and then give it a height.
    I am not seeing the errors here. I double click on the Drawing Label or Reference Marker and they do open the dialog box. Are you running a custom workspace that started in a previous version of VW? If so, try editing it and remove the tools and then re-add them. Or try one of the standard workspaces and see if they work there.
    My apologies with this one as I didn't explain myself very well. My comment is with respect to editing existing Drawing Labels in a drawing by double clicking on them, not double clicking on the tool to create new ones. I am so in the habit of double clicking to edit (it comes from years of using text objects as labels).
    KM
  8. Hello All,
    I have been a Vectorworks user since Minicad 5. I really enjoy using the program and have found it quite powerful for 2D work. Recently I started using a lot more of the features, especially full 3D modeling. Vectorworks 2009 was one of the things that encouraged this.
    In future versions, one of the things I would like to see is a continued finessing of the tool consistency. Here are a few examples -
    1) more consistency between 2D and 3D tools ie. the 2D rectangle tool takes two clicks to make a rectangle. For whatever reason the 3D rectangle tool insists on asking for a extrusion height first, instead of the first two clicks being the same as the 2D tool with the third click being the height.
    2) more modifier tools that have select object first functionality (ie. like the Offset tool, which has a mode where the first click selects the object). This would be ideal for the Move Object, Mirror and Rotate tools, among others. Imagine choosing the tool, clicking on the object (or objects with shift selected) and then doing your action.
    3) the ability to double click in an empty area of a drawing to choose the green checkmark action box that is used with many of the 3D nurbs tools (ie. shell solids, protrusion/cutout).
    4) consistent double click editing across all plugin tools. The Drawing Label tool is a prime example of this. Why doesn't double clicking bring up a basic dialog with the four basic things you input (item number/drawing reference/drawing title/scale). Instead I get the mode bar error. The same is true of the Reference Marker tool. At a minimum double clicking could drop you into the primary field of Object Info Palette This was fixed with some tools (ie. leader notes) but not all.
    My two sense for the future....
    Kevin
  9. Thanks for the advice.
    Mastering the Working Plane tool was a good workaround. The tool has confused me for some time now. It turned out it wasn't the tool that was confusing, but the demo instructions in the manual for the 3 point mode. I was following their selection suggestion and, of course, because they were selecting a vertical line first, every time I chose to look at the working plane the entire view would rotate 90 degrees, causing great confusion with navigation. Weirdly the select face mode for the same tool defaults to the same thing. Once I understood why it was doing that, I could select more intuitive points....
    Now that I understand the working tool, and by choosing views while using the working plane instead of the ground plane as the base, its much easier to do what I'm trying to do.
    That said, rotating around a pivot line would still be a great addition.
    Thanks again.
  10. Thanks Jonathan. You are a great resource to the VW community.
    The "Nearest Point on Edge" checkbox under Object Snaps seems to be the key. It is turned off by default and since I wasn't trying to snap to an edge I didn't think to try turning it on.
    Kevin
  11. Have 3D snaps been downgraded in VW 2009?
    I stumbled across a tech tip online where you could double click on Snap to Object to set a 3D snap preference. This preference allows you to snap to the centre of circular surfaces on cylinders among other things. It turned out the tip was for VW 2008. (I opened up my copy of 2008 and it indeed works)
    The option doesn't seem to have disappeared VW 2009. I though perhaps it had been integrated into some of the other options, but I have not been able to get it to snap to similar points.
    Has anyone else had a similar experience?
    Kevin
