Kevin McAllister
5,205 -
Everything posted by Kevin McAllister
How to reset walls stuck at the wrong height?
Kevin McAllister replied to Christiaan's topic in General Discussion
Christian, I noticed in another post some of your work is contained within symbols. I'm curious if the walls you're having trouble with were in symbols? I have recently had no end of problems with wall and column heights in symbols. There is some sort of bug related to stories I think. Kevin -
It should be. I have done something similar. My line set schedule symbol contains a line set symbol duplicated for each line set. I created a worksheet that counts and sorts based on line set #. When I update the worksheet it updates the linked text in the corresponding line set symbol record. As long as your Excel layout matches your Vectorworks worksheet layout cutting and pasting shouldn't be a problem. Kevin
I've noticed that if I include layer that contains a Design Layer Viewport in a Sheet Layer Viewport it doesn't automatically update if I update the Sheet Layer Viewport. Is there a specific type of workflow that need to be follow when including one type of Viewport in another? Specifically I've noticed it when printing a batch PDF which includes an option to update all Viewports. It feels like there should be menu commands to update Design Layer Viewports and Sheet Layer Viewports separately, or that Vectorworks should have a smart update which updates Design Layer Viewports first. Does anyone else have experience with this? Am I missing something here? Thanks, Kevin
Something changed with the addition of Stories in VW2012. Things seem to behave ok when Stories are defined, but if they're not they behave differently than they used to..... I often find things at unexpected heights. Kevin
I use the B&W option in the Advanced tab of my Sheet Layer Viewports all the time. I wish choosing that option did not affect the Viewport's Annotations. Often I want to homogenize (ie. make B&W) someone else's crazy colourful Autocad layers and then flag things in colour in my annotations.... Kevin (Yes, I know I can do it in class overrides to some degree (other people's symbols are often a problem) but I'm not looking for a work-around.)
Better 3D Connexion Support
Kevin McAllister posted a question in Wishlist - Feature and Content Requests
So I've been trying a 3D Connexion Space Navigator out. I actually bought it to use with Cinema 4D. It integrates very naturally, much like your holding the model and turning it in your hand. Because you use it with your left hand (or non-mouse hand) and because of the way the Cinema 4D interface is set up, you can essentially model with one hand on the Navigator and the other hand on a stylus or mouse. Pretty great workflow. Anyway, I tried the Space Navigator in Vectorworks. It works, but in a very non-intuitive way. It would be great if some of the finesse of its use in Cinema 4D was available as an option in Vectorworks. This may actually speak to the general way you navigate and model in Vectorworks as well. Kevin -
Is VectorWorks 2012 Architect 64 bit or 32 bit???
Kevin McAllister replied to taoist's topic in General Discussion
Based on my own experiences I would say Vectorworks isn't really optimized for anything yet. There have been some small steps forward in recent versions but probably not as fast as many users would like. It doesn't take much detail in a 3D model to start to bog things down on any machine (try a full stadium and scenery and it chokes). Take a Vectorworks model into Cinema 4D and see how much better it is at dealing with it. No slowdowns or hiccups. Faster rendering. Cinema 4D is built for use in production pipelines where seconds add up. That industry expects it. I'm sure that Vectorworks has a lot of legacy code. Apple is probably the company most likely to push things forward. It has no problem jettisoning old processing models in favour of the future and does so with each new release of its operating system. At some point Nemetzchek will likely have to choose either the power of the future or backwards compatibility of all the old PIO etc. I'm sure that Autocad for Mac has a great advantage in the area of optimization since it was build clean from the ground up. KM -
Perspective "Viewport"
Now that we have sheet layers & camera viewports please fix perspective view so it no longer uses the adjustable "crop" box that was previously used for presentation. The perspective view should fill the entire drawing window all the time, so the drawing window is the viewport. This would make perspective view so much more useful in everyday 3d modelling. Kevin -
I'm curious to know how other people are working in 3D. Are you - - working in a true 3D view most of the time or a projected view (top/front/side etc.)? - do you work in Vectorworks standard 3D (what Cinema 4D calls parallel) or in perspective (the cropped perspective "viewport" Vectorworks creates)? - do you class or group so you can easily isolate components? I've been working on a 3d model for a project that involves modular scaffolding running diagonally across the stepped audience risers of a stadium. I've found that its essentially to get right "into" the model to check interactions between the stadium structure and the scaffold. If Vectorworks had dynamic clipping planes this would be easy (see my wish in the Wishlist Forum) but unfortunately its more of an adventure than I'd like. Today I discovered that I could somewhat do what I needed by working in the perspective viewport and using the translate tool to move in and out of the model. Perhaps there is a better way but I haven't found it yet.... Kevin
Ha, I was wondering the same thing. Glad to hear it may be sometime soon.... KM http://techboard.vectorworks.net/ubbthreads.php?ubb=showflat&Number=167415#Post167415
Use the Visibility tool. It looks like an eye next to a small pointer. It can be set to turn off either layers or classes. KM
Its coming but you start to wonder when. Clearly two different marketing strategies.... A week ago an invite was sent out and today a new iPad was released.... A teaser on January 10th, a trailer of sorts on January 31st and then silence for over a month, the Vectorworks "Cloud" seems MIA...... KM
After some testing it seems that most files come into Cinema 4D with the origin aligned correctly. Is this a bug? KM
Does anyone know what determines what is used for the origin when using the Send to Cinema 4D command? My model is centred around the origin in Vectorworks but comes in way off to one side in Cinema 4D. Kevin
Displaying X Y Location Coordanites
Kevin McAllister replied to Mickey's topic in General Discussion
What's it giving you? I can get either x or y and it seems accurate.... (Each plugin is unlocked. It is possible to edit it and have it show both x and y....) KM -
There was a plugin at Vectorbits called VB XY. It would display its XY position. Unfortunately it seems that the Vectorbits website is dead. There is also a plugin called "Coordinate Dimensions" at vectordepot.com It gives you individual plugin objects for x and y. Unfortunately the demo file containing the symbol examples was created by an illegal copy of Vectorworks (you get the warning when trying to open it) so its hard to see how to implement it.... I guess that's not so helpful..... Kevin -
I notice they are in a group. Was that group ever in a symbol? I had all sorts of wall weirdness earlier in the week when I nested a group of walls inside a symbol..... Kevin
Tick Type of Marker
Kevin McAllister replied to Kevin McAllister's question in Wishlist - Feature and Content Requests
Thanks Kevin. I appreciate the tip. It worked great. (Though I must admit its suspiciously like a work around :-) ) -
I wish there was a tick type of marker available. Ticks are used in theatre drafting at the ends of soft goods as per USITT standards. This is an essential marker for Spotlight. It would be great to be able to control the length and weight of the tick. Thanks, Kevin
This is a very interesting discussion. I have often wondered what "Emitter Brightness" does. I would suggest that it is poorly labelled for what it does, since essentially it's a global multiplier..... Kevin
I've been working working on a project that uses some Wall and Column objects. Initially everything was behaving well. Some of the Wall and Column objects were grouped to make the drawing easier to edit. When I converted some of those groups to symbols, things started misbehaving. I am wondering if other people have had trouble with Wall, Columns or other plugin objects when they are within groups within hybrid symbols. The various problems that have shown up include - - sometimes you are unable to snap to the Columns in Sheet Layer viewports. - sometimes the Walls get confused and parts disappear or are displaced in 3D views. - sometimes things ungroup themselves. The issue is clearly related to the screen plane / layer plane adventure and VW trying to separate the elements to create a hybrid symbol. The obvious solution is just not to use groups in hybrid symbols involving these elements. However I often use groups for easier editing because it is an easy way to isolate specific areas. Is this a known workflow limitation? Are other people running into these quirks? Thanks, Kevin
Has anyone else had trouble with doors and Features In Walls? I am drawing an existing theatre space which has two instances where there are indentations in a fairly thick. The indentations are about 5' wide by 9' high. Each of these indentations also contains a door centred left/right within it. I used the Create Wall Recess menu command successfully to create the indentations. However when I insert the door Vectorworks gets confused and each end of the door returns the full depth of the wall. Is this a limitation of the Feature in Walls object? Also, is there a way to make the door plug in draw what I would call a "stop". Essentially its the rectangular piece of molding within the jamb that the door hits against so it won't swing all the way through. Thanks, Kevin
