Kevin McAllister
5,210 -
Everything posted by Kevin McAllister
Offset door in depth of wall?
Kevin McAllister replied to Kevin McAllister's topic in General Discussion
That's an easy solution too. Thanks, Kevin -
Awesome, thank you! I love learning new things. Kevin -
Often in theatre I want to give a door depth even though a standard theatre flat wall is only 4" thick. Is there a way to offset the door in the thickness of the wall? See image. I feel like I've done this in the past but I can't find it as an option now. Kevin
Snapping to the internal origin / axes
Kevin McAllister replied to Kevin McAllister's question in Wishlist - Feature and Content Requests
I suspect the reason it has never happened is because NV has been slowly modernizing the code to VW and the snapping module still hasn't been updated ( @JuanP ?). There's probably a long list of snapping improvements that are waiting for that update to happen. But it's still weird not to be able to snap to the origin in views other than Top/Plan ten years after the original wish. Kevin -
Bumping this long ago wish. I still don't understand why the origin is only snappable in top/plan view. The drawing origin should work like the origin in a symbol, where it is snappable in all views. Not being able to snap to the origin in 3d views sort of makes it useless. Kevin -
I've never used this keyboard shortcut before but I'm curious as to how the same short cut flips both horizontally and vertically 🤣. I think maybe the Help also needs updating. Kevin
Hi Dave, Just looking at the options you selected and wondering why you didn't select the checkbox "Enable seamless tiling"? If it's not used for this, what is it used for? I have tried making seamless textures in the visualizer before without much success. Ironically, seamless tiling textures are one of the few uses I can see for AI in regular use. Kevin
Edit the polyline using Command [. Select the interior void polylines and either copy or cut them depending upon the desired outcome. Exit the polyline edit mode. Paste in place. Change the colour of the polylines. Kevin
Rounded Rectangle not working to crop viewport
Kevin McAllister replied to Luxedavid's question in Troubleshooting
It worked fine when I did a test. What's the corner diameter? For a viewport crop, the corner diameter will need to be big enough to show in the scale of the viewport. I suspect that making the corner diameter much bigger will solve the issue. Kevin -
Vectorworks abandoning perpetual licences
Kevin McAllister replied to line-weight's topic in General Discussion
I received this email from Vectorworks today too. I would guess eventually their pricing will align with Autodesk. At the rate they're going they will price themselves out of the entertainment market I work in. Fees aren't big enough to cover a Vectorworks subscription and pay yourself. It's funny to me they still use the Buy Now button on their website. It should really say Rent Now. Kevin -
Navigation should not be tools
All workarounds. If you don't have a middle mouse button there is no temporary way to invoke the Flyover tool. In your example you're still activating the Flyover tool and disrupting your workflow. The View Control Cube is good but still means an extra mouse move to access it. And how about translating in and out? Basic tool-less navigation is not baked in like any other 3d program. Kevin -
Bumping this wish again. Today I downloaded a trial version of Blender. I've only just started playing with it but it has the best navigation I've ever tried on a Mac for a 3d program. Orbit via finger scrolling on a Magic Mouse is the default. Simple single modifier keys to switch to pan/translate and zoom. So simple, no tools involved. Kevin -
It hasn't always been like this. It used to duplicate a sheet as is with the numbering intact. I submitted the new behaviour as a bug a few times, but the change goes back to when JimW was still on the forums. If you duplicate sheets a lot like I do in my workflow, it can cause a fair amount of extra work. Kevin
Radial Dimension Tool question
Kevin McAllister replied to hollister design Studio's topic in General Discussion
It's interesting that you can't find a radial dimension on that planar object located in 3d space in the Front Viewport. I would consider that a bug. I don't normally put any 2d objects in the Design Layers so that's not a situation I've encountered. Kevin -
Are you able to post a simple example file? Kevin -
What version of Vectorworks are you running (normally users add a signature to their profile with this info)? What rendering mode are you using for your viewports? I've had mixed results myself, depending upon the complexity of the 3d geometry and how deep the solids operations go. The sensitivity to nested curves has gotten better over time but its definitely not perfect. I often have to add helper geometry in the annotations to dimension curves. Kevin -
Render with a possible memory leak?
Kevin McAllister replied to Cristiano Alves's question in Troubleshooting
Vectorworks and Time Machine definitely don't play well together. If Vectorworks starts behaving weirdly you can often check and find that Time Machine is backing up. Kevin -
Text Tab Stops
Kevin McAllister replied to bcd's question in Wishlist - Feature and Content Requests
Bumping this. I'm surprised that proper text editing and formatting has still not seen any upgrades..... today I really needed a right tab in the General Notes tool. Kevin -
Hello, I've been a Vectorworks user since 1994 (Minicad 5). I mainly use it for theatre and is often the case in the industry I am single person design business. My comments are about Vectorworks marketing. One of the most important things in marketing is know your audience. When I bought my Vectorworks license through Paxar Technologies they knew exactly who I was. When Vectorworks took over and opened a Vancouver office I became an email address. Vectorworks often sends marketing "deals". I don't think I've ever qualified for any of them (always deals on new licenses). I just feel spammed and wonder why am I receiving this offer. Here's the current example - And here's the fine print - I will only ever need one license and its current. I can never be a new customer (user since Minicad 5). I use service select so this info should be on file. I guess I stay on the mailing list thinking that one day I'll get a deal for being a loyal (30 years and counting) user..... 🙃 It really seems a waste to use these marketing dollars on me...... and I'm sure I'm not alone thinking this. Kevin
Stage Deck Tool - Xs
Kevin McAllister replied to Andy Broomell's question in Wishlist - Feature and Content Requests
I'll second that bump. KM -
I thought that might be the case 😔 @JuanP is correcting this on the roadmap somewhere? Thanks, Kevin
I've been having this same issue, both in Vectorworks 2024 and now in Vectorworks 2025. I've tried a variety of things to combat the shift, including making sure all my images for textures are converted to CMYK before importing them into Vectorworks, but the colour shift still happens. Quality of colour output is important in design. Its difficult when the intended colours don't transfer to output shared with clients. How do we solve this? Kevin Screen shot from Vectorworks vs. Screen shot of PDF output. The colours are more garish and saturated.
Just to confirm, since it's not clear from the screen shots, you need to select Custom from the dropdown in the 3D Options dialog to change the "texture" of a Softgoods object.... I have seen other anomalies myself but this wasn't mentioned above. Closing and reopening a file can sometimes help, but a full restart is a sure way to differentiate between an anomaly and a corrupt object or bug. Kevin
Lock Proportions
Yay! This was implemented in Vectorworks 2025! See screen shot. Amazing that this wish is almost 15 years old! Kevin
