Kevin McAllister
Member
  • Content Count
    4,824
  • Joined
  • Last visited
Community Reputation
1,051 Spectacular
About Kevin McAllister
  • Rank
    Vectorworks Addict
Personal Information
  • Location
    Vancouver, Canada
Recent Profile Visitors
  1. I'd draw it by lofting and then use the Push/Pull tool to subtract the 45º and 60º chamfers. Here's an example (there's something weird about the proportions vs. dimensions on the original drawing) with each step. - I drew the bottom profile curve, copied it, moved it up and adjusted its length. - I converted both curves to NURBS and lofted them using the first mode of the loft tool and the Create Solid checkbox checked. - I drew guides on the side for the two chamfers. - I used the third mode of the Push/Pull tool to remove the 45º chamfer and then the 60º chamfer. Kevin V Shape v2019.vwx
  2. Ah, the saddle-span tent..... I've spent way too much time trying cleaning up models of it. It is possible to make a close representation using NURBS, but it will have surface breaks because of the complexity of the surface. Try doing it in quadrants. Vectorworks is not necessarily the best option because you have very little control over the NURBS tolerances when making surfaces. These days I just use the manufacturer's mesh model like you are. Its unfortunate that its so low res. I have the faceting in my renders as well. Kevin
  3. Here's an example of Pat's second suggestion - extruding a regular rectangle and then filleting the top and side edges. I think this is your best bet. Kevin Fillet v2017.vwx
  4. If you want to Loft it, it would be possible in multiple parts using the third mode of the Loft tool (two rails and a profile) - Kevin Fillet Approach Loft.vwx
  5. Hi Peter, I would approach using solids and a fillet and then extract the surfaces. Kevin Fillet Approach.vwx
  6. I think you may have misread my post. As I said, I've never found tangent snaps in VW very reliable 🙂 There's definitely room to improve the current snapping system. Kevin
  7. Interesting. When I tried it the vertical line connecting the two is not vertical at all..... I've never found tangent snaps in VW very reliable. I tend to draw a known tangent and rotate it around the circle to where I need it. I also wish there was a way for the second click to be the tangent point on the circle (eg. from a point on another object to the tangent point on a circle). Kevin
  8. I'm not sure exactly what you are trying to do, but the easiest way to create a NURBS surface is to draw a 2D surface and convert it using Command Shift K. Alternately you could use the loft tool. If you post more about what you'd like to achieve I might be able to help further. The advantage to the sectioning surface being a NURBS surface is that it doesn't need to be a flat plane. If you're trying to section along a flat plane, I would use the Split Tool. Here's a file with two examples of sectioning a cube. Kevin Solid Section Examples.vwx
  9. Hi Bruce, You need to use a NURBS surface, not a NURBS curve, for the sectioning surface. Kevin
  10. Wow, good sleuthing Matt! That worked on my system..... The handle system hasn't been moved over to the VGM yet, has it? Kevin
  11. Your file in the other thread definitely has issues with unwanted ghosting of objects when editing other objects. I'm pretty sure its not related to hardware (it occurs on my iMac Pro and your system is a similarly modern spec). I can get it to sort of reset itself when I cut/paste your object into a new file and toggle Show other objects in editing modes on/off. Its stuck in the existing file however. Kevin
  12. I can confirm that the file exhibits all the things you describe. These are exactly the types of issues I see all the time and the reason for this wish years ago - And also this wish about beta testing in user submitted files - I've filed a lot of bugs over the years, but things like you're file exhibit are hard to submit and are almost impossible to reproduce. They definitely come from the conversion process of moving a file forward into a new version. Not sure what to suggest but I definitely sympathize. Kevin
  13. Have you tried contacting Tech Support directly? It may be a faster way to resolve your issue... (Matt beat me to it....) Kevin
  14. I can see the issue from your screen shot. The object you've highlighted is a "Curtain Object" not a "Soft Goods". I wonder if the object predates when Andrew's (Landru Design) objects were integrated into Vectorworks. I'm not sure which version that happened in. If it were one of Andrew's objects, it would say "SoftGoods 2". Kevin
  15. Hi Mike, I completely agree with all of this and this is the same workflow I use. But I know from experience that there are more unexpected issues with files that are brought forward continuously, especially if they pass through a few different versions. Often, cutting and pasting a problematic object into a new clean file and then cutting and pasting it back into the original file can solve the issue. I've generally found VW2020 to be pretty stable. Did you migrate your preferences and workspace from VW2019? I have migrated workspaces but I've never migrated preferences. Hopefully someone here can find a way to make things smoother for you. Kevin
