Henry Finch
Content Count
104 -
Calendar
Everything posted by Henry Finch
I also had trouble installing VWA10.0.1. Katie suggested restarting the computer which made no difference. I finally downloaded the updater again and it worked. I have only one registration number so that wasn't the problem. VWA 10.1.0 installed without a problem. VWA10.1 seems to have fixed many problems I was having with snapping and smoothness of mouse operation. The freehand tool in VWA10.0 had jerky movement and left a jaggy object. 10.1 is now smooth. Henry
unpredictable snapping VWA 10.0.0 on MAC OSX 10.2.4
Henry Finch replied to Henry Finch's topic in General Discussion
initial use of VWA 10.1.0 seems to fix the above problems. Thanks NNA Henry -
This came up a few years ago and I assumed it would be repaired in future VWA versions. Having just started with VWA10 last week I see it wasn't taken care of. In wood door construction in the USA and Canada a STILE is ALWAYS a vertical member and the horizontal members are ALWAYS RAILS. This applies to window construction also. The way VWA has invented the new definition for rail as a horizontal stile is like calling all beams horizontal columns. I do a little work for a window manufacturer. They think NNA should hire an architect or someone in the building industry who knows these basic terms. An architect I was showing VWA almost wrote off the program as probably not specialized enough for architects because of this simple basic ignoance. Maybe in other english speaking countries other terms are used. That's why there are country specific versions. In any case the USA and Canada are major markets for NNA. Please make the standard door ands window plugin terms correct and if someone wants to have a creative language version they can do it with vectorscript. The only good thing about this is it's not a programming bug. Henry
I believe it would be easy to write a vectorscript to select or assign a particular color. This could go on a custom named palette such as 'my colors'. The name of the each script could be whatever you wanted such as 'really red' or 'grassy green'. (If you want you could assign numbers to the color commands but.......) They could be assigned a keyboard shortcut for each color and therefor chosen by clicking the palette or using the keyboard shortcut. Doesn't his answer the whole thing? I even think this script is already written. Henry
MAC 1.25Ghz dual 256MB ram OSX10.2.4 VWA10.0.0 When printing a simple VW drawing to an HP 4MV 11x17; The first print usually prints OK but the next print sheet attempt crashes VWA immediately. OSX remains OK. The files I've had this problem with are all converted from VWA 9.5.3. I just got the computer and installed VWA10 so have no new VW10 files yet. VWA 9.5.3 is also installed and crashes in the same way when trying to print. I downloaded and installed a new HP4MV driver but that made no difference. I selected all and made sure only one font is used : Times Print as PDF crashes VWA in the same way. No new fonts have been installed. Other programs installed which didn't come with the machine are: - appleworks 6.2.4 - writenow 4 which I only opened once and it was a problem but worked. (To read old files) - safari which I also only tried once. All other programs seems to print OK. Any insight is appreciated Henry
Henry Finch posted a topic in General Discussion
MAC OSX 10.2.4 1.25Ghz dual 256MB ram VWA 10.0.0 (having trouble getting VWA10.0.1 to install) snapping seems not to work predictably in the above setup. example: 1. make a rectangle 2. use constrained dimension tool 3. snap to one corner, top left.... works fine 4. bring cursor to top right corner 5. It is almost impossible to obtain the 2nd snap point. I am completely aware of all the options on the constrain palette and believe I have it right. The first snap works fine. The snap to object selection is on. Is this a known bug? In addition the selection box with the pointer tool seems to hesitate significantly and is inaccurate. I have to wiggle the pointer's location to sort of get it where I want. Has this been discussed already? I couldn't find it. Are these issues fixed in VWA 10.0.1 or 10.1? Thanks, Henry -
installing VWA 10.0.1 on 10.0.0 on new MAC OS 10.2.4 does nothing
Henry Finch posted a question in Troubleshooting
I downloaded VWA 10.0.1 and ran the installer. It thought for a while and seemed to do something but when I looked at the get info about the application it said it is still VWA 10.0.0. I know VWA 10.1 will be released soon. ? Perhaps that will work. Mac OS10.2.4 on a new Powermac 1.25Ghz dual still only 256 MB. Henry -
I've been working on a 12 MB file converted from VWA&R 9.5.3 into VWA&R 10.0 in OSX 10.4.2. After a few hours of seemless work it crashed after trying to print to PDF. Did I miss a note(s) on print to PDF crashing VW? (Should this be a new topic?) Henry
I just got the new dual 1.25Ghz G4 (and new spectacular 20" LCD screen) last week. VWA&R 9.5.3 crashes every time after about 5 to 10 minutes in OSX10.2.3 and after updating to OSX 10.2.4 still crashes in about the same amount of time. VWA&R 10.0 seems to work fine except with a few bugs but this is the first time using VWA10 having bought it a few months ago but held off using till now. I prefer to have both both VW9 and VW10 available for the transition to VW10. I keep all old jobs in the original version until translation is proven solid. With VW9.5.3 crashing I either have to keep old projects on the old G3 266Mhz or translate to VW10 before feeling confident of reliability. The speed of the new computer is amazing. All functions except render are instantaneous. I had gotten used to the G3 lag! The VW10 worksheet editor is instantaneous meaning I'll jump into it to throw in a new shortcut and out again without the previous minute lag. I'll be waiting to hear if VWA&R 9.5.3 runs on my new machine. Henry
I have a very basic question which I'm sure I missed in the VW9 manual or earlier discussions. To select many objects in VW8 you held down SHIFT as you selected objects. You could use a number of selection marquees of selecting to get all the objects you wanted selected. In VW9 as you select objects with shift down any objects previously selected get DEselected when within the selection marquee! I can't find the combination of keys or method to only add to selected objects. The present VW9 method only allows you to selectively deselect objects. (Using option-select selects too many objects in many cases) HenryIt took VW9.5.1 before I would use VW9 because of speed issues; now I'm adapting to the changes.
Irving, As CEA said, the HP printers are all software postscript meaning the postscript is calculated by a software program in the host computer and then sent to the printer. This is slower and in the case of MACs has bugs in this software program - according to other posters. The GCC laserwriters have hardware postscript meaning the postscript file is sent to the printer and the printer figures out the postscript. It's faster and I guess less likely to have problems. Please correct me if I'm wrong with this assessment. The GCC paper size of 13" wide is also very attractive. Henry
The HP 4MV 11 x 17 hardware postscript machine has been wonderful for us at 600dpi. Prints complex 1/2 size architectural drawings exceptionally sharp in just a few seconds and beautiful grey scale and black and white photo for graphics proofs from photoshop and Quark. Used machines are often available at ?$500?. It was $3000 new quite a few years ago. We have printed tens of thousands of 11 x 17s with minimum service. You probably really want info on new machines?I see that the HP5000, 11 x 17 B&W, fast, $1400., is software postscript RIP so probably not good for MAC. It looks like the new machine after HP4MV but without hardware RIP. Oh well. I just checked the 8000 and 9000 series from HP - all emulation postscript. They must have stopped making hardware postscript laserwriters! GCC looks very good. The company has been around quite a while. Their Elite XL20 series starts at $1600. 600+dpi, 20ppm, builtin postscript and 13" x 35" max paper size. Check out:http://www.gcctech.com/products/20ppm.html Henry
what printer? D size; MAC; VW9.5; small network
Henry Finch replied to Henry Finch's question in Troubleshooting
Looking at the Encad webpage it looks like the cadjet 2, their cheapest machine is also the fastest cheap printer? Encad also just announced being bought by Kodak. Henry -
Fred, My problem now is getting the 350C to work. It wasn't used for a month and since (10 months) it constantly gives bad cartridge errors. There are only so many new cartridges you want to stick in the thing at $34 each x 4. A repair place says it isn't supported by HP any more? And it's print head needs replacing?? I have found a page on HP tech help on cleaning more than just the cartridge heads. The secret to the machine as I've heard is printing at least one sheet a week. (Or take out and store cartridges in ziplock baggies with a drop of water.) People do complain about the lack of drivers for the Mac, and NNA not addressing the issue. But as you say, Micrpspot takes care of it. A friend with Archicad uses an Encad cadjet 2 with the driver from Archicad but he had to pay $4000 or so for archicad and much more for upgrades than VW. I guess the low cost option for sole practitioners is an HP 430, D size, black only, (I just saw it new for $1283, usually $1495.) and Macplot. That's less than 2 grand. Or the HP500 ($2500.?), (black, red, yellow, blue cartridges make for lots of color), used with Macplot?? or Encad cadjet 2 (black and one combo color cartridge) with Macplot. Most of the other printers are much more money for workgroups. The other HPs are 4 grand and up. We use the Epson 3000 which comes with good postscript rip, 17" wide x long which was $850 refurb and now $900 or so new, with giant color cartridges, poor sheet feeding, but prints most of 17" wide as compared to Epson 1520. Henry -
New Printing/Plotting section
Henry Finch replied to a question in Wishlist - Feature and Content Requests
Katie, The new discusssion area worked.... sort of. It said the topic wasn't allowed but then posted after a delay. Henry -
Katie, It looked like it was working but when I went to post a topic it wasn't allowed. Could you post a topic? Like: What choices are there for a sole practitioner architect to get a $2000 D (24" x 36") size low volume printer that works for VW9.5 on a Mac. Fancy color quality unecessary. Accurate line work and fills mostly in black and white. And not too slow.. Maybe 1 - 4 minutes per print. What companies besides HP fit the above specs? What about getting a cheap wintel machine ($450) that for a print server? Would postscript then not be needed? Henry -
I'd like to hear suggestions for a D size (24" x 36") printer for MAC; VWA9.5, for one person or very small network. Black and white; some spot color would be good. This is a setup needed by many sole practitioner architects who use VWA. The printer is for construction documents and NOT fancy color output. (I have an HP350C on powerplot that doesn't work anymore. Powerplot is discontinued and doesn't work with Mac sys9 I'm told.) Many have said that the HP software postscript RIP is very flawed. I think that is what goes with the HP500ps. I see Macplot with a printer is an option. Or should I get a $450 wintel machine to output to an HP printer? Then would I get the nonpostscript HP500? Is there an Epson or other company equivalent to the HP printers which is very low cost, say $2000, D size and works with MAC? ... and is reasonably fast? (1 to 4 minutes/print, line work mostly) Henry Finch, ArchitectNewton MA USA CW
Katie, Printing Plotting discussion board still not working as of 10:49PM EST 4 Feb. 2002Henry (Sorry, I couldn't find your NNA Email address. You can remove this post after fixing the discussion area.) -
PRINTING SOLUTIONS
Henry Finch replied to Henry Finch's question in Wishlist - Feature and Content Requests
Katie, Thanks for the new printing/plotting discussion area. However it has been made with limited access. I wasn't able to post a question. Thanks, Henry -
PRINTING SOLUTIONS
I'm so excited about the new PRINTING discussion area located just below (or above) the INSTALLATION PROBLEMS discussion area! Not to be too pushy but this would go a long way to making the printing questions and answers more accessible to everyone without NNA having to recommend a particular solution. Henry -
I have a Mac G3/266 416MB ram, OS9.0.4, VWA9.5. VWA 8.5.2 works very fast No hesitation. VWA9.0.1 was way too slow to be productive on my machine. Long (seconds) hesitation between most operations. VWA9.5 is very nice and much faster than VWA9.0.1. However, it still has a 1/2 to 1 second hesitation between many commands and operations. I am noticeably slowed down in production. I'm pretty sure I have enough ram and the proper amount assigned to VWA. The question is; How much faster would be a G4 733mhz for normal production. I understand that rendering would be much faster, but I am most interested in knowing whether the hesitation associated with basic tool use is decreased? (I have also heard the word that somewhat speed bumped Macs probably will be introduced in the next few weeks. 800Mhz, 900Mhz, 1Ghz)
duplicate with option drag; mac & VW9.5
thanks John, option shift duplicate works great - keeping option pressed. I figured it had to be a subtle change in rules. Henry -
I'm having trouble with Option Drag Duplicate. It often doesn't work in VW9.5. Sometimes it duplicates the object sometimes not. It never works to option drag and then push shift to constrain the duplicated item. (It worked in VW8.5.2) Is this a bug or are there new rules? Henry Finch, ArchitectNewton MA USA CW
PRINTING SOLUTIONS
To add 4 more cents: I'd like NNA to add a new discussion area titled PRINTING. The read only support area for printing is from Katie's note useless. -
Perhaps I'll jump in on the complex roof creation discussion. It looks like no one has answered your list of roof questions. 1. True. Create roof from polygons or walls is for very basic roofs. I have to say that I never use it. Create roof face does just that, create a face at a time. A third thing to remember is that you can use any solid as a roof for a model. I have created many barrel solids to be used as roof elements.What you also seem unaware of is the EDIT GROUP command. You can always edit slope and other variables of a roof face in the OBJECT INFO pallette. But to change the face plan shape, select it and EDIT GROUP. Make changes and EXIT GROUP. I have keyboard shortcuts for these since they are so helpful. They are under ORGANIZE. The other command you should be famuliar with to work with complex roofs is PASTE IN PLACE. You use this to paste registered guide lines on the roof face to guide in editing the face. 2. T&F. Probably more F.You can't use extend and trim on roof faces. You can however still edit the 2D polygon of a roof face in EDIT GROUP described above. For simple roofs of the same pitch it is fairly easy to know the intersection lines for the roof faces. The challenge is to do this with roof faces of different slopes and base creation heights. I sometimes create oversize faces and view the roof layer in PLAN 3D orthogonal (not perspective) in Quickdraw 3D interactive (VW8.5.2) or OPEN GL VW9.5. Make sure to throw in a LIGHT so the roof faces will show the insection of the oversize faces. Now draw a line along this intersection. You cannot snap but can get very close to the exact location. CUT this line out. Select one of the oversize roof faces. EDIT GROUP. You now have the polygon used to make the face. PASTE IN PLACE. The line will be placed on the polygon at the correct intesection. Cut away the extra roof with CLIP SURFACE or just edit the polygon the usual way. Remember to delete the guide line before EXIT GROUP. Do the same to the other roof face. Now these roof faces are cut at the correct intersection. Once you get good at this it becomes quite fast. I remember struggling with it when I first got the program. The first day I got the program I started with 3D and spent 10 hours creating a complex roof I could do in 20 mintes now. Complex roofs of different slopes and heights are custom work. All custom work takes more time. At least it can be done in VW. 3. I have just started using VW9.5 and have to answer for VW8.5.2. A roof object is a grouped collection of locked roof faces which can be minimally edited. UNGROUP the roof object and UNLOCK the resulting roof faces to be able to edit them. 4. see above 5. I don't understand the question. Perhaps they are just working with many roof faces on one layer and not combining. I hope this helps. We all do things different ways. VW offers so many different ways to do the same thing that it is overwhelming at first. VWA tries to standardize some of the methods. Henry
