VincentCuclair
3,105 -
Everything posted by VincentCuclair
Problem is Vectorworks is virtually unknown in Sweden, I started my own business partly because I could decide what software to use, unfortunately I hit the wall (got stressed out) so had to go back to an 'ordinary' low pace employement........ perhaps the future will bring more opportunities.... I can already tell you that Revit is a good program but it's like tunnel vision compared to VWs, and 'families' (the thing Revit is based upon) is extremely tedious and complicated, each and every object you create in revit is unique (kind of like our autohybrids) so forget taking a window and quickly customizing width, height etc, first you need to duplicate another similar door/window then edit settings then save and use it....tedious
Ha ha good one Raymond!
Jupp right as rain :). Don't get me wrong Revit is a good program but having used VWs before it's like tunnel vision.......
With pain in my heart I have today canceled my VSS account, I've been forced to move over to the Dark Side, unfortunately the office I recently was employed works with Revit only. I would just like to thank everyone that has helped me on this forum through the years (my first version of Vectorworks was 11.5 back in 2004), I hope i've been able to contribute as much as I've been aided. (Please make VWs market leader soon and kick Revit ass, so that I can convince the office management to convert!!!!) Good luck to you all! Vincent
Hi Jeff here's the extrude....... what I did was to use the 2D polyline tool using the flood mode and then you can extrude the shape that is created. Good luck!
Walls Join to line or polygon.
VincentCuclair replied to Tom Klaber's question in Wishlist - Feature and Content Requests
Sorry I meant AEC>Pillar command...... -
Don't want to diminish the wish but: 1: Walls can be split at any angle using the Split Tool. 2: Odd shaped columns can be create by using the Create column from object command AEC>Pillar command. Walls can be joined to these columns using the Wall join tool. -
3d tape measure tool that stays on object
VincentCuclair replied to digitalcarbon's question in Wishlist - Feature and Content Requests
Isn't that what 3D dimensions are for?! -
Revit exports 3D dwg/dwf and Vectorworks imports 3D dwg/dwf why not try using that format instead? PS Dwf is a highly compressed file so perhaps that Will work better if you're trying to keep file sizes small.
2D Elevations , sections and plans generated from 3D?
VincentCuclair replied to Kony's topic in General Discussion
Thanks Alan! Here are the settings (however they were created in v2015 in which I always used Custom Renderworks at medium quality and I find the same settings in v2016 are terribly grainy, the nearest I can get to my settings in v2015 are using Final Quality in v2016. I still have some testing to do to see what works for me in v2016.) In addition I always override all line thicknesses to 0.13mm in Hidden line (when used as Foreground rendering), I also always create a second sun that is 'wrong' to get shadows on facades that normally face away from the sun. Good luck! -
Autohide Empty Classes and Layers
VincentCuclair replied to VincentCuclair's question in Wishlist - Feature and Content Requests
That would work too, however I have 350+ classes so being able to hide them completely would be great. -
Well to be honest I think the most logical place would be among the class and layer options in the Navigation palette, and a radar button on the Organisation palette?! Another good place would be the quick options however in this case it would control all situations. -
Here are a couple of examples of the things you are asking for in practice.....all sheet layer viewports are created from a 3D model using the various viewport render settings etc. in these examples I haven't used any 2D fixes. However VWs is still laking in individual line control for elevations and sections and depth perception. You can only manipulate line settings by overriding individual classes. Ie everything in that class will change in the viewport. -
VincentCuclair posted a question in Wishlist - Feature and Content Requests
It would be nice if we could enhance the Organization Palette so that it Automatically hides empty classes and/or layers. As it is now, to have a functional workflow we are forced to create a large number of classes and layers/levels to fullfill all the different situations however we don't always need all the classes and layers in each project, so it would be very helpful if we had a setting that automatically hides empty classes and levels. Perhaps a little radar button att the top of the Navigation palette?! -
Stair Comments and Wishes
VincentCuclair replied to Joe-SA's question in Wishlist - Feature and Content Requests
I think the handrail tool should be a well thought out flexible stand alone PIO that can be applied at will to any edge or face on any other (PIO)object including the stair tool. Basically as it is in Revit. -
I'd like to associate or 'link' one object with another - any ideas?
VincentCuclair replied to VvierA's topic in Vectorscript
Why not make them into a group? -
Auto-classing hints
Bump -
Auto classing can be switched on and off here: File>Document Settings>Standard Naming
Appreciate your trying to help guys, however even though your explanations might be correct......and I am very aware of these problems and have chosen the names as a compromise between readable sheets and layouts in my program and according to local building standards and so far I haven't had any problems along the lines described above or other. However if it is as described above why then has NV not implemented it correctly/consequently: The sheet number is A-40.1-51 The sheet name is: SITUATIONSPLAN, PLANER v2015 made this: A-40.1-51-SITUATIONSPLAN, PLANER v2016 makes this: A-40.1-51-SITUATIONSPLAN_ PLANER Why? there are still punctuation marks and spaces in the new name? Why then doesn't v2016 make this: A-40_1-51-SITUATIONSPLAN_-PLANER I think someone unwittingly added/changed this and now we're stuck with it for a year......
Why on earth would this behaviour get changed between versions? Commas in Sheet Names now 'publish' export as underscore as opposed to as commas in v2015!? I have an existing project currently with 68 Sheets published from Vectorworks as pdf:s to a project management database that tracks versions, I now will need to change all the exported pdf names each time a revision is made, all I can say is ARG!!! :mad:
Classes Not Scrolling
That's the one, excellent, that'll remove quite a lot of irritation and that is always welcome -
Strange Art I'm not seeing this, I just checked and I get a non hierarchical list in v2015 too?! Perhaps a Windows 7 thing? I'm talking about this pulldown list: -
Just been working on my Mac again and there I see that the classes list in the OIP is in fact show as hierarchical? Can this be changed. If not why is it not show as an hierarchical list in Windows? That would also save me A LOT of scrolling (frustration)?! -
Only classes that use Class settings can be overriden......
VW Crashes - Why Do We Put Up With Crashes?
VincentCuclair replied to dontevenjoke's topic in General Discussion
I'm getting 2-4 carshes a day on files imported from v2015. I don't see a clear pattern however I'm almost inclined to say it is caused by autosave and an action happening simultaneously...?!
