702 -
Everything posted by J. Wallace
VW 2019 file has over 2000 folders appear in resource browser
J. Wallace posted a question in Troubleshooting
Just wondering what might have caused a current file that I'm working on to generate over 2000 folders within the resource browser? It appears that all the folders are empty, I'm not certain when this occurred. It was a VW2018 file in it's earlier life. It has tons of existing tree symbols on it which might be related? Thanks for any words of wisdom. -
@digitalcarbon it's always fascinating to see what you up to. Thanks for sharing.
Thanks for that @Benson Shaw I didn't realize that this feature was part of VW 2019.
@Patricia Angelu you might want to check out the resources available on VW Youtube channel. https://www.youtube.com/user/vectorworks/featured
@rowbear97 thanks for that...I didn't realize that this was a new feature of 2019. Looks very useful for Landmark applications, I may never use the traditional tags again.
Brian do you any grade limits in place? These are an important part of adding a pad, in my experience. I haven't had a great experience using pads with retaining edges but a grade limit should help your situation. I often create a pad, then copy and paste this in place, change this to a grade limits within the OIP, then offset it by whaterever distance you wish. In this image, I offset it by 1'. The model will then place your pad and use the grade limits for just that. There are lots of good videos out there on VW Youtube channel which you might want to check out. A good practice can also be to put all your site modifiers into the same layer your site model exists. Hope that helps...
So is the 2018 Mac Mini a viable VW machine?
J. Wallace replied to hobick's topic in General Discussion
Ha, quite right...2019 was what was in my mind. -
Imac Pro Vs upgraded/loaded 27" Imac
J. Wallace replied to HEengineering's topic in General Discussion
We recently upgraded to a 10 core iMac Pro. I would say my workflow has increased by 10%. Super happy with this unit, except to the cost, saying that we are looking at it through the long-term lense...hoping to get 5 good years. We have another workstation which needs to be replaced and we're giving the Mac mini a serious look. -
Super interesting @Rob Glisson we're in the market to replace an old Mac 'Cheese grater' some time in 2019. This looks like a great approach. -
I live on Vancouver Island, BC Canada. A number of areas have free LIDAR information available but I found I needed someone to take this raw data and create contours. It's not expensive but this data is usually taken every 2-3 years so if there have been any site changes it won't be reflected in the data.
Hi @JohnAthayde great to see another permaculture designer in this group. I've used both LIDAR data and elevation data from a drone survey. I've got an associate locally who can take LIDAR data and create one-foot contours which is super helpful. I've only used this once as I prefer drone data where I can get contours and high definition images. The downside is tree cover, this is LIDAR's advantabe. Are you planning on making a site model from this?
Does anyone make use of mesh from drone data?
J. Wallace replied to J. Wallace's topic in General Discussion
Thanks very much @Peter Neufeld I'll check that out -
I've noticed that in VW 2019 Landmark when you go to edit a 2d plant symbol you get the plant symbol plus other aspects of the design rather than just the plant itself. It doesn't seem to matter what my settings are when I'm editing an object. Same results regardless of this setting. I've noticed this on several files but I'm just getting around to reporting it.
Thanks very much @RussU. That is super helpful information. What your describing here looks like your taking cloud point data to make a site model, by snapping stake objects to portions of this. In my case I get a set of shapefiles that contain 1' contours. I really like your approach and if I had a drone along with additional software, it's something that I could do myself. Love the video you put together and thank you again for sharing this. -
Hi @Benson Shaw. The contours are from a site model which we created with shapefile contour data (from the drone, the shape file comes with other support files). Super easy to create, I think it took but a few moments. The high def image is from the drone, other than for observation purposes I haven't figured out how to use the mesh. It's a monster file that is best not mixed with the project data. I'm curious to hear how other folks use this type of information. -
Thanks, @Dave Donley that certainly helped, the file is now 560mb on the lowest setting. I'm curious what other folks do with this type of data. -
I'm starting a new project and have received some drone data which I've used for creating a site model as well as high definition images. My question for people is whether (and how) one would make use of some mesh data. I've attached a screen shot and some information, the file is huge and an interesting reference but I'm not sure if it has any value besides that. You can see that once imported, the saved file size leaps up to 994 mb in size (this is the mesh only, no other data in the file, site model in a separate file). Love to hear peoples comments. Thanks
Just wondering if anyone has had experience applying a high definition drone image to a site model? Not sure if this is doable...thanks for any thoughts you might have.
Great to see a new product that might help extend the life of one of 2012 Mac Pro workstations. Radeon RX 580
- 1 reply
- 1
Those are exciting results @Rob Glisson We have just two workstations and older 6 core Mac Pro and a new iMac Pro. Love the new unit as I can literally plow through work, I did not like the price(or the lack of upgradability). With another upgrade on the horizon, I like the direction your going and I would make a similar decision, and most likely will within the next year. In our situation having one computer more robust than another is very workable, I imagine this is not the case in most situations. Keep us posted. -
I'm interested in hearing other speak to this. We just went through an upgrade to one of two workstations where we purchased an iMac Pro (very pleased with it so far). Our other machine will need to be replaced in the next year and the Mac mini is an interesting option. -
Thanks for all your hard work @Jim Wilson...I look forward to hearing about your iMac Pro tests. We recently purchased one and quite impressed by the performance.
While working on a site model today it became clear to me that more intuitive controls over pad slopes and how they intersect with others would be helpful. In the image below the property is on a steep slope with a slope driveway approach. Blending all these pads together would be so much easier if we could adjust the corner or additional vertice elevation much you like do with the retaining wall site modifier where you simply click and pull up or down the vertice.
@chris I recently purchased an iMac pro to replace an older 2012 era Mac Pro. We have had this two weeks so it's early in the game for us. I'm hoping to get 4-6 years out of this and we'll see if that happens. Early tests on our 10 core machine vs our old 6 core unit saw a huge difference in render times. Mac Pro render 7:32, iMac pro 2:40. So far I'm really impressed but spent more than I was hoping for. The one thing I don't like vs my old machine is the storage. My old Mac pro had 5 hard drives within it, the iMac pro has one, so my back up and data has to go into an external enclosure. Thunderbolt 3 enclosures are not cheap. Saying that the cost is actually spread out over the life of the machine. Good luck with your choice. PS check out refurbished units, we saved $1300
