702 -
Everything posted by J. Wallace
Hello everyone I have a question that I haven't been able to answer as of yet. I just imported some shapefile contour lines from a drone survey and the 185 acre site model creation was quick and painless...yeah! The high resolution Tiff file (overhead view of site) is about 1.6 GB and will not import into VW or any other software I have which is not a total surprise. The drone operator has asked me what is the max size I can handle??? No idea...I do see that I've used images that are 200+ mb but I'm not sure of VW limitations. Any thoughts would be appreciated. Thanks 😀
Site modifier offset command
J. Wallace posted a question in Wishlist - Feature and Content Requests
When adding multiple site modifiers to a site model, it would be awesome if VW had an offset option specifically for modifiers. Perhaps a control that would allow someone the option of snapping to an existing modifier, this would automatically offset the new modifier by a per-determined distance (example might be 1mm). This way modifiers could be easily added to a model (in particular pads) without the inevitable conflicts occurring. This would certainly speed up my workflow on some projects, thanks for considering this.- 1 reply
- 4
Creating terrain site model from Digimaps DTM download
J. Wallace replied to CPoppy's topic in Site Design
You should be able to import this into excel (https://support.office.com/en-us/article/Import-XML-data-6eca3906-d6c9-4f0d-b911-c736da817fa4) then export as a text file, This from the VW help menu Site model source data can be generated by tabular coordinate information from an external file. This file must be a text file with fields delimited by separators in one of the formats available. Hope your able to get this to work. -
You may need to create a pad beneath your stairs for it to rest on, also check into grade limits as a way to control the amount of space that is graded to accomidate the site modifier. Also your smaller pad would need to be next to but not touching your other pad. You might also be able to adjust the existing pad your walkway is using and modify it to take your stairs. Posting a screen shot might help. Hope that helps.
I posted this within the site design forum but perhaps it is better suited here. Hello everyone I started having an interesting challenge on Friday with a small site model and a curved retaining wall site modifier that was inserted. I've never experienced this issue and hope others might see an easy fix. To clarify: I have a small site model (under 1/2 acre) that was created using survey 3d polygons. All the polygons have low numbers of vertices so the model itself seems stable and easy to move around. In this design we are placing a new retaining wall that curves across the rear landscape. The file is not huge 120+ mb It appears that when one creates a retaining wall site modifier in a curved shape that the results can cause severe slow downs and crashes in this file. If you take a look at the second image I attached you'll see countless lines coming from the site model and running behind the retaining wall, this is where I think the issue is If I delete the retaining wall site modifier the file behaves itself, when it's present I have to wait several minutes for the site model to update and for the open GL to render. Even then the open GL looks poor regardless of settings. This has never happened to me on my current computer. When I change the retaining wall shape and reduce the curves, add a new retaining wall site modifier makes for a more stable file. I can conclude that these curves are causing some issues with the site model and making the file un-workable even with a robust computer. Has anyone noticed this limitation before? It's not great for us as we often work with organic shapes. I've attached the file having removed everything but the site model, the wall, retaining wall site modifier and a small pad in front. No modifier conflicts are reported. I would love to hear peoples comments on this. Thanks for any thoughts you might have. Site model.vwx
- 2 replies
- sitemodel
- retainingwall
(and 1 more)
Tagged with:
Site Modifiers - allow Existing + Proposed to cross
J. Wallace replied to E|FA's question in Wishlist - Feature and Content Requests
Totally agree... -
@fhunt whenever I have run into similar challenges I make another plant symbol (duplicate the original in the resource browser) and give it another schedule size. Not ideal, but it works.
.LAZ file coming in to document way out of scale.
J. Wallace replied to tekbench's topic in Site Design
Kelly have you tried to import in meters vs mm?- 29 replies
- point cloud
- .laz
(and 1 more)
Tagged with:
Good point @Tony Kostreski it's a bit opposite in my situation. The plant cloud which is working was produced in a 1:96 scale, this distorted version is coming from a layer that is 1:2500.
I seem to be having a challenge using/creating landscape areas within a specific file. If I draw a polyline or directly draw a landscape area I get a very distorted shape that is not close to what I'm after. If I create the shape/convert to a landscape area in a new blank file it works fine, as soon as I copy and paste this into my working drawing I get the same distortion. Not seen this before but hoping I can sort this out.
Thanks very much @Tony Kostreski That's a huge help. I like the fact I can add a common or botanical name.
I ended up sorting this out using this section from the help files. It's a bit vague but got me to where I needed to go. http://app-help.vectorworks.net/2019/eng/index.htm#t=VW2019_Guide%2FAnnotation%2FCreating_Data_Tag_Styles.htm%23XREF_33520_Creating_Tag_Styles&rhsearch=edit data tag&rhsyns=
Hello everyone I'm trying to sort out how one can create a custom data tag. I'm hoping to do so for use with existing trees. I find the tags for existing tree symbols really cumbersome, for some reason they are much harder to work with when compared with plant symbols. See image below as an example of aligning tags, plant symbols align easily using the align tool, the existing tree tags never seem to align correctly which leaves one to adjust tags manually which can be a large task if your drawing contains hundreds of ex trees. I was hoping to work around this by creating a data tag for existing trees but haven't sorted out how to do this. Any advice would be much appreciated. Thanks
We had to shift form a 2012 Mac Pro last year and opted for the Imac Pro. Happy with the performance to date, the price was a bit tough to swallow. Saying that we hope to get five years of service from this unit which makes it affordable when looking at the yearly cost. Good luck with your journey.
Happy to finally see an announcement for the new Mac Pro... Pricing will be interesting, but happy to see expandability is part of Apples focus. https://www.apple.com/mac-pro/
Thanks for making computer work fun again!
J. Wallace replied to Jeff Prince's topic in General Discussion
@jeff prince the property sizes I work with would be 1/2 acre up to 30...at least at this point. I think a big difference is your collecting your own drone data. I'm receiving the data from an operator. I'm going to send along a message later today and ask him some specifics. Your project is looking great, have fun. -
That is fantastic. Your mesh looks very good, do you find it cumbersome to navigate with? The mesh files I receive are usually huge 500gb+ so I find I set up a file for the mesh only to make it easier to reference. Exciting to read about your experience and thanks for sharing. -
Nice looking work...your mesh looks great overlaid onto the site model. Well done. -
I'm sad to hear you are leaving, but very happy to hear that family is a priority and this is were your energies will be going. Take care Jim and thank you for all your work.
I'm no expert; if I were in this situation I would consider exporting the worksheet and create an excel sheet which you can easily modify. You can then import it once you're done, saying that I've not imported a sheet before so I'm not certain of the implications of this.
- 1 reply
- 1
Hi I'm putting together a site model using shape files from a drone survey. Done this a few times in VW2018, the first time in VW2019. Files import just fine and it looks good in 2d, when I go into a 3d model I'm getting some areas that are blacked out. I repeated the same procedure with a blank fresh file (first was a template file) and I get similar results but the colouring is white instead of black. If I repeat this in VW2018 is works flawlessly, and if I save this file and re-open in VW2019 is looks fine as well... Not sure if anyone has run into this or not?
Drainage networks
J. Wallace replied to ScottLebsack's question in Wishlist - Feature and Content Requests
Totally agree with you @ScottLebsack -
I got this sorted out...http://app-help.vectorworks.net/2019/eng/index.htm#t=VW2019_Guide%2FAnnotation%2FEditing_Data_Tags.htm&rhsearch=data tag&rhhlterm=data tag&rhsyns=
I've been playing around a bit with the new data tag tool, great addition. Just wondering if there is a way we can easily edit what is displayed in the tag (other than the pre-configured options). I usually have additional information showing in plant tags such as the ID and I was hoping to be able to customize the data tag to show similar info. Love the new tool as it makes it easy to label various plants without worrying about class visibilities, and I hope customization becomes easier. As a side note, I noticed that you can 't make any font or font size changes unless you enter the edit mode.
