John Meunier
  • Content Count
    183
Everything posted by John Meunier
  1. Any one having issues importing some revit files? I get a dialog with version not supported. Trying to import some lights from Selux. http://www.selux.us/en/resources/3drevit-downloads.html 3d_MTR_Column.zip
  2. Bump, curious if this is corrected. I'm running into issues with exported fbx files from VW2018.
  3. Thank you guys. Updated the object to add bends to go around band boards and brick/cultured stone at the bottom. I'm not sure why, any insight would be great, when adjusting the variables in 3D view the object 'jumps' around on the screen. Downspout.vwx
  4. We have the same problem when importing a pdf from the server. When a PDF is on the desktop it comes in with no problem.
  5. A simple downspout object for use. Downspout.vwx
  6. When deleting a window or door style to have the ability to replace it with another style similar to when you delete a symbol.
  7. Also would be nice when deleting a style to have the ability to replace it with another style similar to when you delete a symbol.
  8. To bad, you can't change the style in the worksheet.
  9. Love it, didn't think that it would be in functions. Thank-you Matt!
  10. Anyone know how to pull out the window style being used for a window in a worksheet?
  11. Anyone know the worksheet commends to pull the following: 1) The style being used 2) Hide style parameters
  12. Great, I see its working now is SP1. Thank-you
  13. When a data stamp is inside the title block border it will not update when selecting the checkbox when printing. Is there a way to auto update the plot date on sheets when printing in VW2018, or is manually updating the date?
  14. Part of the bug is that the section VP thinks the objects not in a symbol are beyond the section plane, you can see this by toggling on off objects beyond.
  15. The 2 objects on the left should render with the same hatch as on the right.
  16. Good Day, 1) When creating a section viewport of a DLVP the objects not inside a symbol do not 'cut' and render with the selected 2D attributes. See the attached VW file and PDF. 2) When making changes to the layer with the objects, the changes are not reflected when updating the section VP unless you toggle on and off layers. DLVP Section Rendering Bug.vwx DLVP Section Rendering Bug.pdf
  17. Awesome, worked perfectly! Thank-you
  18. Anyone have a clay tile hatch they could share?
  19. Still not working http://www.vectorworks.net/downloads/notes/2017SP1_Notes. Would love to see all the fixes:)
  20. Great Job on the hierarchy view and arrangement of the resource manager, this has been a long time coming. What a huge difference a small change can make, looking forward to the tweaks and adjustments that improve it further in the updates to come.
  21. Good Day, Below is a link to a VW file with a very detailed site model for a townhouse project. All the other information has been stripped out and this file just contains the site DTM. VW File Several stake objects, highlighted in yellow, are reporting 0m when in fact the site DTM is not 0m. When they are moved to other areas they report the correct elevations. The phenomenon happens in a localized area. Any ideas to what is causing this behaviour in this file? Any input is appreciated. Cheers [img:left]https://dl.dropboxusercontent.com/u/32955816/Screen%20Shot%202016-01-07%20at%201.33.10%20PM.png[/img]
  22. The link under Vectorworks Community Links for "Bug Submit" does not take you to the bug submit page, it redirects you to the Tech Support Request page. It was working yesterday. I have tried in multiple browsers. Anyone else having this same issue? Or have I gone mad.
  23. What about using the framing member tool instead of a extrude, this allows for a top plan edit with the handles.
  24. What a great invention. Thank-you Mark. I can see expanding this tool to bring the map into VWs at scale, and increasing the the size of the map via getting multiple snapshots 'and stitching' to complete a larger area with a lat/long offset.
