bcd
3,478 -
Everything posted by bcd
Caps Lock
Thanks Pat, I created a little Marionette to do the trick. And a little Tools>Purge>Duplicate objects gets the job done. (somehow the Remove Duplicates node didn't work for me) 3d Poly Ctr to 3d Locus.vwx
Is there already a command/script that efficiently converts the center of a survey 3d Polygon x to a single 3d Locus for the creation of a Site Model? eg.:
The Curtain Wall is at drawn 8' above 0 while the cut plane is 4' above 0. Change the Cut Plane in the OIP to eg. 10'
Did you migrate your workspace. It was a prominent option in prior version.
Currently a sparse survey will produce a large triangle TIN site model. The recommend workflow to refine the triangulation is to place a matrix of 3d Loci and send to surface, then include these 3d Loci in the source data. The problem with this is that while it results in more dense triangulation - the resultant triangular mesh is coplanar with the original - and the dihedral angle between them remains unchanged. The wish is to have a SubDivide Site Model button in the OIP to automatically re-flow the surface geometry while keeping fidelity with the original survey points.
Option to disable classes in sheet layers
bcd replied to Steve Murray's question in Wishlist - Feature and Content Requests
I'm not loving this wish as it's currently described. it seems to break the Organizational paradigm somewhat; a blunt tool for the task. But it does point to an significant enhancement that should benefit all use-cases. Surely there are Sheet Layers where all Classes visible would be appropriate and others selective visibility is appropriate; in the same file. And what if you want all but one Class visible how do you set that for a single Sheet Layer? With good file structure, important Key & TitleBlock etc. information should never be in jeopardy of being hidden. Then, while the existing Saved View option seems like a solution, as it's currently implemented it's a bit of a diversion to create a Saved View and use it to access the Sheet Layer. In a similar vein moving from a Sheet Layer to a Design Layer often involves turning on /off Layers etc. to get ready to work, and again Saved Views seem to offer a solution. Perhaps the focus of the request could be to improve Saved Views, so that they become the primary way of navigating the drawing. They could be created automatically when creating a Sheet Layer, with defaults to show all/visible Classes etc.. Likewise, Design Layers would have the option to have Saved Views automatically assigned. Importantly the Saved Views UI would need to be updated significantly to elegantly and efficiently present the user with the available Saved Views which the user would generally use to access any Layers in the drawing during all stages of the work. This would leaving the existing DL and SL organization otherwise untouched. -
Cabel Looms tool
bcd replied to Jocke Fjelldal's question in Wishlist - Feature and Content Requests
Perhaps a separate Cable Path for each loom? -
I know you're on Mac, but for others on Windows, I lean towards Lumion, best bang, results, content & speed for the buck.
I'm sure a short script would solve it, but in any case It seems an unusual practice to require all Classes to be turned on in all Viewports. -
Not as automatic as you asked for but quick & easy enough nonetheless: Just create a Viewport Style selecting just Classes and enable them all. Then drop this on your Viewport, or Alternatively when creating the VP, edit Classes, and Opt-Click the visible column. Presto, or You can it globally, by Tools>Organization>Visibilities select all Viewports, enable all Classes. -
This is a terrible idea, and a seismic regression of Vectorworks' Class & Layer foundations. It's akin to telling VW Landscape users that the Site Model & Plants & Site Modifiers should be all on the same Layer, or VW Architect users that the Roof & Upper Story walls should be on the same Layer.
Filleted edges don't show in hidden line rendering.
bcd replied to line-weight's topic in General Discussion
Maybe the new option could be 'facet curves for HLR' -
Something to do with intersecting itself too much I think. If you scale it on the x slightly or change the profile to a circle it works - so I think you just need to tweak it. The one on the right as a slightly different aspect ration in plan.
It's a hidden line rendering of an extrude, with the corners clipped by a regular 18 sided polygon. It represents how, yes, we would illustrate a curved edge like this with a pencil. I think this effect would add alot of versatility to Hidden Line Renderings for exactly your case. -
I think it's just an enhancement request for the Hidden Line. To indicate curved edges with greater/lesser/no degree of linework. Oldschool but very effective. -
I understand EPSG 29902 TM65 was replaced by EPSG 29903 TM 75 by EPSG 2157 IRENET95 The question I guess is which one agrees with the transformation that the Arcgis is using for the satellite imagery. I'll run a comparison of the various coordinate systems you mention. I have a feeling that the differences between them, while real, will not be discernible with the satellite imagery that we're getting.
Last time: Thank you @Tom W. & @zoomer. This is the correct answer: ESPG: 2157 -IRENET95 / Irish Transverse Mercator Luckily, in this case, the difference between the default and the site was significant - pointing up the error and the importance of setting the correct coordinate system. I originally searched for 'Ireland' and didn't get any results. This would be a helpful VW improvement to tag the country along with the name of its coordinate system/s so that searches are more reliable.
sorry everyone - I found the gremlin don't type "system" followed by an "s" in parenthesis or you get a Forbidden Error 403 response
