WhoCanDo
459 -
Everything posted by WhoCanDo
Round top and extended round base model for 3D printing or milling
WhoCanDo replied to WhoCanDo's topic in Solids Modeling
Interesting Kevin, After a bit more testing, and you suggestion of "same direction", I think I understand my error. Because the circle wouldn't Loft, I changed it to a polygon, but because there was no "convert to polyline" tool, I also changed the polyline to polygon to match. Big mistake. They wouldn't Loft either, so I changed them both to Nurbs and that's why it lofts to a group and not a Generic Solid. I will have to remember that the polyline should never be changed to a polygon before changing to a Nurb, but a polyline or polygon can be changed directly to a Nurb. -
Hi Virtualenvirons, Even though I have created this part using multiple extrude, your questions are valuable for other components I need to draw. As per my initial post, the circle is 60mm diameter and the oval is 30mm radius and 77.49mm long. It's actually a slot. The finished height is 90mm and the wall thickness is 5mm. I would be interested in reading your step-by-step method of creating the same object with Nurbs and Lofting. -
Yes, but I couldn't "Closed" it. The Close button would not stay ticked even though it was not greyed. The loft created multiple Nurbs and grouped them. It did not merge them into one solid/surface as I was expecting. -
Nice one Tom. That will keep me going for quite a while. -
Thanks Tom. Not having done much 3D stuff, you help is wonderful. However, if I set the Shell tool to 5mm inside, how can I get it to punch through the bottom 5mm ? Is the only solution to make the object higher and subtract solids to clip of the bottom 5mm ? -
The loft is 1024 Nurbs and I can't get them to add. I tried Generic Solid but it rejected the objects. I tried Adding Objects but it rejected that too. I'm not sure what you mean by Multiple Extrudes because there would have to be thousands to create a smooth surface. The Shell is the easy bit LOL -
I thought this would be easy by creating two objects and subtracting solids, but now I find that the shape made from Nurbs ends up as a group and can't be subtracted. Therefore, I'm calling for ideas please. Here's what I am starting with .. The oval is at level 0, and the circle is 90mm higher. This circle diameter is 60 and the oval is 77.49 if anyone is interested. After several attempts, I found that the shapes had to be converted to Nurbs and the with Loft Surface tool, I could make this "solid", so I thought .. With this and another, which is smaller so I can make a 5mm wall thickness, I wanted to subtract solids to make a tube, but it's not a solid, it's a group of Nurb surfaces. I obviously went down the wrong track, so any help would be appreciated.
Zoom 3D screen image wrong after rotation
WhoCanDo replied to WhoCanDo's question in Troubleshooting
Thanks Pat, I had proposed too after inquiring for a solution, if it was available. -
Yes. Closing the file and opening it again does fix it. I don't need to close VW. The error re-occurs only after repeating the duplicate and rotation process again. The first duplicate and rotation remained constant but the second has the error. Files attached. Video Project 2.mp4 Zoom 3D screen image wrong after rotation.vwx -
"Do you want this app to make changes to your device." I get this message each time I start VW2024, by both starting the app directly, and by opening a file which opens the app. I completely uninstalled VW and reinstalled without luck.
VW2024 Zoom refresh error.mp4 This video is with the object at the origin. The first video was on a PC with Windows 10 and this one is on a laptop with Windows 11. There are no other similarities except they are the same version of VW The file is attached. Just follow the instructions and see if it happens for you. -
This has been happening in 2024 and can be quite difficult to work with. I created a 3D set of panels on the right and then picked the first panel and then duplicated it and rotated it to get the left side view. However, when you see the attached video, I am zooming in and out, and the top view flashes before returning to the side view. This is what is happening at the moment, but I also get the opposite. Sometimes I will do the same duplicate and rotate but end up with the top view, and I will only see the side view when I am zooming in and out. I've tried switching layers and back again, and choosing top plan view, but only closing the file and reopening it solves the problem. Any ideas ? Zoom Fault.mp4
When filling with the pattern, the result is correct. When filling with a tile, I would expect something similar. The pattern should not cover the cutout.
There use to be and AutoCad help sub-section, but it disappeared. My problem is that I have created a tile and I use it to represent a product. If I create a 2D shape and another within, then I subtract solids and then tile it, after exporting to .dwg, the cutout does not appear (as below left). However, if I have no fill or a pattern fill, it does work (as below middle & right). These pictures are from AutoCad after the export to .dwg
Viewport location after creation
WhoCanDo posted a question in Wishlist - Feature and Content Requests
Hi, There was one version of 2024 in which, when a viewport was created, it's location was in a similar location to the Sheets Layer. ie. In my case I draw a frame around the viewport area that I want to create as a viewport. For every version except one (can't remember which one), the viewports all end up in the middle of the Sheet Layer and on top of each other. However, in one version, I remember being surprised that the first viewport was next to the second viewport, just as I had them on the Desing Layer. Mistake or not, it was very handy. Like this .... Not this .... -
Viewport attached to object wish
Not sure how VW would approach this one, but AutoCad seems to be able to do it. When I draw something on the Design Layer, and I create a viewport, when I move something on the Design Layer, the viewport does not show as it originally did. eg. What was on the viewport .... What is on the viewport after I move the something on the Design Layer I move this left object -100, -100 on the Design Layer However, the object is in it's own viewport (a jigsaw piece). It is not associated with the 2nd viewport to the right. Obviously, if they were in the same viewport then I would expect this result. Somehow, AutoCad can make viewports of individual or selected objects and when they are moved, the viewport crop moves with it/them. This would be great to see in VW. -
Hi, As far as I am aware, Vectorscript can't print a worksheet to a pre-defined filename - I'm printing to the "Microsoft Print to PDF" printer. Therefore, can anyone come up with an idea to copy text to the Windows clipboard so that it can be pasted into the filename box when printing it? With VS's "Print ('Worksheet Name')", Windows saving convention pops up, but the filename is blank. Since I already have files of the suffix format that I want, I would just click on an existing file and that would prefill the blank filename area, and then I want to paste in the prefix. eg. suffix = "This file.pdf", prefix = "Despatch List ", result = "Despatch list This file.pdf"
I just got word from Tech Support that they have seen this, and it is being looked into.
This has not been fixed in VW2024 SP3
This has not been fixed in VW2024 SP2 If all Windows users are experiencing it, then I will make an error report and hope that the answer doesn't come back that it was a Windows update that caused it and they can do anything to fix it. However, this only happens with VW.
Good news. Slow walls has been fixed in VW2024 SP2
Hi Alana, I agree. Unified view is not as good as it was. This may happen when the layers (if your using layers) are different scales.
How on earth did that change 🤪 In 30yrs, I have never changed that, and I'm not sure I even noticed those options. 😴 Thanks Mark
Hi, Up until yesterday, my manually placed symbols had an insertion point where I set it. Something went wrong during the day because now the insertion point is at an alternate location. This only happens on one of two computers using the same stationary sheet. The black pic clearly has the insertion point offset from the coloured edited symbol (midpoint). How can I reset it for one computer only?
This has been happening for quite a while. It's annoying.
